 Old 01-20-2010, 12:06 AM   #1
Roszko's Avatar
Location: Home Base: Houston, TX. Currently: San Marcos, TX
Posts: 249   (View Stats)
Roszko is the leader of the worldRoszko is the leader of the worldRoszko is the leader of the worldRoszko is the leader of the worldRoszko is the leader of the worldRoszko is the leader of the worldRoszko is the leader of the worldRoszko is the leader of the worldRoszko is the leader of the worldRoszko is the leader of the worldRoszko is the leader of the world
Default HKS Type-1 Turbo Timer tac and speedo incompatible with 09 MS3?
I got my TT installed on my 09 MS3 at a custom body shop (786 Motoring) in Houston, and apparently the guaged wires (or something) of the speedo and tac aren't compatible with the HKS Type-1...? Has anyone heard of this or had this problem? All I know is they weren't able to do it and I think it had to do with the gauges of the wires. I didn't expect it. Most of my features on the TT are basically useless now because of this.
any help would be great
thanks
Roszko is offline   Reply With Quote
 Old 01-20-2010, 01:11 AM   #2
reddeerspeed3's Avatar
Posts: 689   (View Stats)
reddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the world
i have a type-0 that i installed myself and it works fine, not sure what other features the type-1 has. you dont need to splice into the speedo with mine, its just a security option, but if you tap the e-brake signal its not like anyone can drive away. if you need those wires connected go to a shop that specializes in remote start and they should know what needs to be done
reddeerspeed3 is offline   Reply With Quote
The Following User Says Thank You to reddeerspeed3 For This Useful Post:
Roszko (01-20-2010)
 Old 01-20-2010, 05:07 AM   #3
KR....i haz it
Blackspeed's Avatar
Posts: 2,845   (View Stats)
Blackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the world
Groans: 166
so you are saying that the size of the wires is stopping you from connecting them to the TT?
Cobb SRI | Cobb Turbo Inlet | Cobb AP |ETS TMIC 3.25" | CS Inserts |
CS Test Pipe | NGK IV22 | Blitz TT | MSD DH | TWM full replacement | PTP cdfp
While the other forum is GREAT for technical/mechanical information and how to, that place is filled with single-minded (if you aren't driving fast, you're doing it wrong), arrogant, and professional douchebags.
Blackspeed is offline   Reply With Quote
 Old 01-20-2010, 12:33 PM   #4
Roszko's Avatar
I need to check back with the shop and ask exactly what went wrong. I had to leave right then anyways to make it back to class, they said I could come back anytime. I was just seeing if any one had a similar problems. I've never heard of this before and I'm pretty sure it'll work.
From what they said is "the gauges in these new cars won't allow us to hook up your speedo and tac". They specialize in skylines, 240sx's, drifters. They've installed TT's several times, just not on MS3s.
I'll call them later today and find out exactly what the problem was
 Old 01-20-2010, 12:41 PM   #5
phantom3's Avatar
Posts: 1,223   (View Stats)
Groans: 190
I think they are refereeing to the speed and tac being part of the CANBUS. Without those wires the TT will not function in full auto mode. It will however function in manual mode.
I have a Greddy full auto TT and had the same problem. It works perfectly fine, just no auto mode.
My mission is to go fast.
Currently Designing:
The golden girdle of the gods
The CF "fuck your face" IM
phantom3 is offline   Reply With Quote
 Old 01-20-2010, 12:47 PM   #6
KR....i haz it
Blackspeed's Avatar
Groans: 166
I have the Blitz DTT which has a boost function. It uses boost as a reference for the automatic mode. If you want more functionality, sell the HKS and get the Blitz, especially if you dont have a boost gauge.
 Old 01-20-2010, 01:49 PM   #7
Roszko's Avatar
Yeah my timer works fine but only with the 2 manual modes, no auto mode either. The only problem with that is my TT only displays voltage and can't determine speed/distance/rpms/heat, etc. So I'm not able to do 0-60, 1/4mi, speed warning, RPM shift beep, or any of those functions that I was looking forward to using.
Do you have any of those functions while still not having auto?
 Old 01-20-2010, 01:56 PM   #8
KR....i haz it
Blackspeed's Avatar
Groans: 166
it doesnt have any speed functions. it has a lap timer and stopwatch and boost gauge. I can use my dashhawk for any of the other speed functions though.
 Old 01-20-2010, 09:28 PM   #9
Roszko's Avatar
Ok, i called the shop and got a little more info. I wrote down as he was speaking, but I missed a lot, so these aren't his true words.
Apparently the MS3 converts the original speed signal, or data, at a certain point, then transfers it to the speedo. So the original data runs somewhere and is converted by something and then THAT data is displayed.
I know it's vague, but is there somewhere after or before the conversion point where the signals are compatible with the TT?
bear with me guys haha
 Old 01-20-2010, 09:37 PM   #10
ElBartoRex's Avatar
Posts: 1,186   (View Stats)
ElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the world
it should still work...
call HKS tech support and ask for Mike Quan, he practically invented those timers.
oh and the 09 MS3 is no different than any other year ECU wise so if someone has gotten it to work on an 07-08 it will work on an 09 too.
2007 Mazdaspeed3 Sport, True Red
ElBartoRex is offline   Reply With Quote
The Following User Says Thank You to ElBartoRex For This Useful Post:
Roszko (01-20-2010)
 Old 01-21-2010, 09:17 PM   #11
youknownb's Avatar
Posts: 13   (View Stats)
youknownb will become famous soon enoughyouknownb will become famous soon enough
there is a tach signal in the car ive got an 08 and my auto mode works fine. as for the speed signal I haven't had time to finish researching it but i have the complete wiring manual for the car i just need to find the time to finish it.
youknownb is offline   Reply With Quote
 Old 01-22-2010, 12:35 AM   #12
phantom3's Avatar
Groans: 190
Help us out champ.
There is no tach wire to splice. The tach signal in in the CANBUS.
Are you using an injector signal?
 Old 01-22-2010, 06:24 PM   #13
Roszko's Avatar
I've asked a few friends with speeds and they didn't even know there was an issue, so they couldn't offer any advice
I really appreciate all your guys' help, I'm still trying as well
 Old 01-30-2010, 05:30 PM   #14
Aztec(h)'s Avatar
Posts: 332   (View Stats)
Aztec(h) is the leader of the worldAztec(h) is the leader of the worldAztec(h) is the leader of the worldAztec(h) is the leader of the worldAztec(h) is the leader of the worldAztec(h) is the leader of the worldAztec(h) is the leader of the worldAztec(h) is the leader of the worldAztec(h) is the leader of the worldAztec(h) is the leader of the worldAztec(h) is the leader of the world
Don't know if you've found your answer yet, but just in case, this helped me. I have the same timer. This won't get you all the features yet, but it'll at least get you the auto timer function and the rpms. Good luck.
How to install TurboTimer with PICS!!
EDIT: BTW, I know it's a different timer in the first posts, but go to page two or three, and they talk about the HKS type-1.
Aztec(h) is offline   Reply With Quote
The Following User Says Thank You to Aztec(h) For This Useful Post:
Roszko (02-07-2010)
 Old 02-11-2010, 09:31 AM   #15
youknownb's Avatar
yea i'm at an injector it works fine but rev to 3300 while calibrating the timer.
 Old 02-26-2010, 07:25 PM   #16
Roszko's Avatar
I haven't been able to find anything else on this, but thanks guys
 Old 05-17-2010, 05:04 PM   #17
mazdaspeeder08's Avatar
Posts: 5   (View Stats)
mazdaspeeder08 is an unknown quantity at this point
i have my timer hooked up to my tach i just have no idea where to hook it up to the speedo and i have been looking for the last 2 days for stuff
mazdaspeeder08 is offline   Reply With Quote
 Old 05-17-2010, 07:00 PM   #18
Roszko's Avatar
how were you able to hook it up to your tach? cuz that's really the most important in order to set the timer to auto
Turbo timer m.a.vega1 2010 MS3 - Turbo Induction 23 01-20-2010 10:36 PM
HKS Type-0 Turbo Timer Review joos89 MazdaSpeed 3/6 - Car Audio & Electronics 9 11-18-2009 01:35 AM
Best Turbo timer? wes3id MazdaSpeed 3/6 - Car Audio & Electronics 16 05-26-2009 11:33 AM
Page generated in 0.37927 seconds with 28 queries
