| MazdaSpeed 3/6 - Car Audio & Electronics MazdaSpeed 3/6 - Car Audio & Electronics - Tired of that stock stereo? Installing Nav units or mods to your current system? Come talk about it here. |
![]() Join Date: Mar 2013
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score I've just installed my koolertron stereo in my Mazdaspeed3, the problem is that there is no sound coming through the speakers. I have bose sound system. This stereo is very similar Eonon as many other uses. How do you get sound from the speakers? Can any kind person help me out there ?Mazda 3 gps - Mazda3 dvd - Mazda 3 navigation -indash mazda3 autoradio - HD screen ipod rds bluetooth handsfree |
![]() Join Date: Jul 2008 Location: Ottawa, ON Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,005
| Not Ranked : 0 score My guess is you don't have a 5 volt signal going to the amp remote wire on the Bose
__________________ 2008 Cosmic Blue Mica Mazdaspeed 3. BNR s3, CoolingMist CMGS Meth, Damond TB Plate, JBR FMIC Undermount w/ TR8, JBR 3" Fullpath, Steedspeed EM, Cobb AP v3, Stratified Tuned, Autotech HPFP Internals, CP-e Catted Downpipe, Port and Polished IM with VTCS & Full EGR Delete, Grimmspeed EBCS, 3 BAR MAP Sensor, Turbosmart Dual-port BPV, Koni Sport Yellows, Eibach Prokits, SPC Camber Arms, Cobb FSB and RSB, AWR Front Endlinks, JBR Trilogy Mounts 70a Duro, KX-F3 Full Chassis Braces, Denso Iridium ITV-22, CP-e Safe Seals, SURE TIG IM and TB, Cobb Shift Weight, TWM SS w/Bushings and Specter Hybrid knob. To be installed: SS Brake Lines. |
![]() Join Date: Mar 2011 Location: Greenwood, SC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 207
| Not Ranked : 0 score The link that you attached says it will not work with Bose without some sort of modification!
__________________ 08 MGM Speed 3=SURE Rmm/ShortCut/Anchors/Return,COBB AP/SF/TIP,TurboSmart B.O.V,BC Coilovers/SWIFT Springs,SPC R.C.A, M2 DP, CNT CBE, Autotech Internals, SSP EGR Delete, DDM 6K |
![]() Join Date: Dec 2009 Location: queens, ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 126
| Not Ranked : 0 score U have to tap into the Mazda factory harness on the wire for the Bose amp to turn the amp on & off. U can use the remote on & off from head unit, but u will have to find the Bose amp on wire it's on the main white harness . It's on the top of the plug & it's white & blue . Sorry man no pics of it. |
![]() Join Date: May 2009 Location: Orange County, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 806
Groaned at 9 Times in 5 Posts
| Not Ranked : 0 score The most direct way to splice into bose with an aftermarket HU is to convert the amplified outputs (or RCA outputs) to line level using one of the adapters below: Kanatechs Bose Adapter For Mazda PAC MAZATO Retain Mazda Bose/Centerpoint Factory Sound I'm not sure if the latter will work on your year due to Centerpoint processing. But the approach is the same as the Kanatechs adapter. Otherwise use an RCA cable, cut in half, and run from the HU to the speaker L/R inputs on the factory harness. |
| Not Ranked : 0 score Here is the pinout of the Bose harness. TOP - In order from left to right *EDIT* These are the speaker outputs grey w/ red stripe (FR-) white w/ red stripe (FR+) grey w/ black stripe (FL-) white w/ black stripe (FL+) solid grey (BR-) solid white (BR+) grey w/ white stripe (BL-) white w/ purple stripe (BL+) BOTTOM - In order from left to right *EDIT* These are the inputs to the amp solid blue (remote turn on) solid purple (FL+) green w/ white paint (FL-) solid red (FR+) *edit switched from FR-* solid green (FR-) *edit switched from FR+* brown w/ blue stripe (BL+) yellow w/ blue stripe (BL-) yellow w/ green stripe (BR+) *edit switched from BR-* white w/ blue stripe (BR-) *edit switched from BR+* Use one of those cable taps and connect the blue remote wire on your koolertron harness to this wire: solid blue (remote turn on) Here's some more details: http://d5102.wikispaces.com/FAQ#Bose
| The Following User Says Thank You to theurgy For This Useful Post: | flappypaddles (03-07-2014) |
![]() Join Date: Jul 2012 Location: South San Diego, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,074
Groaned at 9 Times in 7 Posts
| Not Ranked : 0 score Look on the eonon website, they have a how to on splicing into the Bose system
__________________ 2009 Black Speed3 - AP, JBR Powerpath stage II Sri, JBR 70 duro tmm, JBR Ssb, JBR Short shift kit, JBR RSB, JBR 5mm spacers, ETS Tmic, TWM big type-R shift knob, RX-8 wheels, CPE Stage 2 rmm, H&R Springs, Bilstein B8's to be installed : 3 Port EBCS HTP 3" intake/ MAF/ TIH Autotech internals Corksport Pmm Test pipe SBC Rear Camber Arms |
| The Following User Says Thank You to Playaj For This Useful Post: | flappypaddles (03-07-2014) |
![]() Join Date: Nov 2009 Location: Dallas, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,116
Groans: 549
__________________ it's fun to do bad things |
| The Following User Says Thank You to jack_hammer For This Useful Post: | flappypaddles (03-07-2014) |
Okey guys! thanks for all the answers! I want to do this in the easiest way! does not matter if I need to buy someone adapter for little money .. If I can make it work! So I would be incredibly grateful if someone could write a guide that works for my problem, Thank you all! | |
| The Following User Says NO Thank You to matte08 For This Un-useful Post: | jack_hammer (10-05-2013) |
(Thread Starter) | Not Ranked : 0 score Please help! |
| Not Ranked : 0 score FFS... we just gave you the damn answer.
(Thread Starter) | Not Ranked : 0 score So the only thing I have to do is run a cable from my koolertron stereo system (amplifier) remote to the solid blue (bose under the seat) (remote turn on)? BOTTOM - In order from left to right * EDIT * These are the inputs to the amp solid blue (remote turn on) After that, the stereo work? |
| Not Ranked : 0 score I haven't clicked the links that you were spoonfed but the one I told you to look up on eonons website has pics. Friggin check if your connections look the same and yes it is a write-up, no one here is gonna make you one
Ok thanks, but I dont come into www.eonon.com currently .. | |
![]() | | #19 | ![]() |
Groans: 549
| Not Ranked : 0 score click the thread i linked. read it. read the threads / websites linked in that thread. follow them.
__________________ it's fun to do bad things | |
![]() | | #20 | ![]() |
(Thread Starter) | Not Ranked : 0 score Hello guys! I take a pic of my 2 connectios under the seat.. So only a cable from my koolertron amplifiler to which connector on the picture ? |
![]() | | #21 | ![]() |
| Not Ranked : 0 score The wire you need to splice into doesn't even have to be at the amp. Look at the harness in your dash, off of that harness there is a blue with silver dot wire on pin #13 . Use a scotch lock type of wire tap:
![]() | | #22 | ![]() |
Okey, every guids says different things.. so a cable from the stereo amplifier to the dash.. With a blue wire ? | |
![]() | | #23 | ![]() |
| Not Ranked : 0 score I'm done, this thread gave me cancer
| The Following 4 Users Say Thank You to Playaj For This Useful Post: |
![]() | | #24 | ![]() |
![]() | | #25 | ![]() |
| Not Ranked : 0 score You have to splice white with blue wire on factory in dash Mazda harness it has a white plug u connect into aftermarket radio. No need to splice into Bose amp. |
![]() | | #26 | ![]() |
Groans: 549
| Not Ranked : 0 score Fuck you. I have the eonon installed in my gt with Bose. I wrote a fucking thread on how to do it. I linked to the info in my thread. My thread is all you need. I linked my thread in here. If you're too stupid to click that link and educate yourself, then you don't belong here. Sent from my LG-MS770 using Tapatalk now Free
| The Following 5 Users Say Thank You to jack_hammer For This Useful Post: | blkspeed307 (10-06-2013), Playaj (10-06-2013), theurgy (10-06-2013), veritas-truth (10-06-2013), |-Goku-| (10-25-2013) |
![]() | | #27 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thanks for all the good answers I got from you. One of you got cancer .. Where is the context here? I'll just inform you that your poor response did not help me a shit and you were also wrong. But thanks so much! Send a PM to me if you want to know how to connect your koolertron to the bose sound system. |
| The Following User Says NO Thank You to matte08 For This Un-useful Post: | jack_hammer (10-24-2013) |
![]() | | #28 | ![]() |
| Not Ranked : 0 score Was it any of the answers given in this thread?
![]() | | #29 | ![]() |
![]() | | #30 | ![]() |
| Not Ranked : 0 score Don't need to get all aggro dude... chill out.
![]() | | #31 | ![]() |
Groans: 549
![]() | | #32 | ![]() |
| Not Ranked : 0 score I am cancer free now! Maybe it's cuz I don't have the shitty Bose system in my car! Sent from my SAMSUNG-SGH-I337 using Tapatalk
| how to install eonon d5102 with bose + aftermarket sub | jack_hammer | MazdaSpeed 3 - How-To's | 3 | 08-18-2014 11:05 AM |
| Bose soundsystem>>>Thoughts? | mikak88 | CX-7 > Car Audio & Electronics | 34 | 02-27-2014 07:24 AM |
| Koolertron head unit... | Beck | MazdaSpeed 3/6 - Car Audio & Electronics | 4 | 10-03-2013 12:55 PM |
| Anyone intalled Eonon D5115Z, or D5163 in a Genpu with Tech/Bose | Guyverspeed3 | 2010 MS3 - Car Audio & Electronics | 1 | 09-12-2013 02:56 AM |
