 Old 04-17-2009, 04:05 AM   #1
TongMan's Avatar
Posts: 444   (View Stats)
TongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond repute
Default Viper 5901 w/ Remote Start Installed!!
I just got my alarm installed by a local shop dude. It took him 5 hours to do the install. Everything works great! Alarm is working great. Remote start is awesome...the only negative about it is that I can never park in gear anymore...oh well...anyone else got a remote start installed on their Speed3 or Speed6?
2009 Crystal White Pearl Mazdaspeed3 Sport **SOLD**
2010 Monterey Blue Nissan 370z Base w/ Sport Package 6MT
TongMan is offline   Reply With Quote
 Old 04-17-2009, 04:07 AM   #2
MZRDISI4's Avatar
Posts: 1,430   (View Stats)
MZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the world
Groans: 94
Groaned at 38 Times in 19 Posts
How much was the install labor? I think I want this but without the remotestart.
"We already have the Speed6 replacement" "It's just called the CX-7 now"
back at http://www.mcx7.com bitches, spam free
MZRDISI4 is offline   Reply With Quote
 Old 04-17-2009, 04:09 AM   #3
TongMan's Avatar
$225 for labor
 Old 04-17-2009, 06:28 AM   #4
nerv81's Avatar
Posts: 38   (View Stats)
nerv81 will become famous soon enough
Groaned at 9 Times in 2 Posts
I used to install alarms/remote starts. I had one in my Spec-V until I accidentally left it in gear one night. Next morning when I started it, I felt the house shake. Come outside and I see the car smashed into the garage. Talk about an epic fail. Congrats, just be careful.
Also, did they bypass the clutch with a relay? Some places get lazy and just jump the wire. Problem with that is your cruise control won't work cause the car always thinks the clutch is being pressed. Good luck and enjoy.
nerv81 is offline   Reply With Quote
 Old 04-17-2009, 07:18 AM   #5
killa cam's Avatar
Posts: 450   (View Stats)
killa cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the world
is it possible to take pics of the install? i have a 5900 brand new in the box, i just havn't had time to install. i wonder where he put all the little boxes and stuff. it's probably worth it to just take it to a shop, but i have a problem trusting other people with my baby
killa cam is offline   Reply With Quote
 Old 04-17-2009, 01:18 PM   #6
TongMan's Avatar
This guy who did my install have done two previous alarm installs for both my tC and my Si. I have the Viper 5900 installed on the Si and the Viper 771 installed on the tC. The guy bypassed the clutch with a relay for me. I say that if you know how to do the install then install it yourself, but if you don't then go to someone you trust to do the install.
 Old 04-17-2009, 01:23 PM   #7
m4tic's Avatar
Posts: 4,928   (View Stats)
do MS3/MS6's have an "in-gear" sensor? on my legacy gt, i relay grounded the starter so the car wouldnt start in gear, but out of gear i could start without the clutch
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
 Old 04-17-2009, 01:36 PM   #8
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Take it back and tell him to hook up the neutral safety wire.
It is black/orange in pin 1S at the PCM under the hood. If he hooks up the neutral safety wire properly the RS won't even attempt to crank the car unless your in neutral..
 Old 04-17-2009, 01:42 PM   #9
TongMan's Avatar
anyone got pics of the neutral safety wire? Do I have to buy a hundred dollar relay for that?
 Old 04-17-2009, 01:50 PM   #10
Groans: 60
You don't need any parts. The alarm already has a neutral safety wire input, but the installer just grounded it--If he connects it to the car's neutral safety wire it will work as DEI actually intended it to.
The Following User Says Thank You to SSinstaller For This Useful Post:
xcoldricex (04-17-2009)
 Old 04-17-2009, 05:29 PM   #11
TongMan's Avatar
cool i will call my installer up and let him know.
Update: So I called up my installer and he said that he did just grounded the alarm's neutral safety input wire. I asked him to connect the neutral safety wire on the alarm to the neutral safety wire on the car's ECU. He said that he could do that, but he needs to know where the car's neutral wire is located. So where is it located?
 Old 04-17-2009, 05:55 PM   #12
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
i have one installed with remote start, i also have it so it will still start if the car is in gear and would like to fix that.... and my factory alarm isn't bypassed, what is the wiring for that?
thanks for the help ssinstaller!
 Old 04-17-2009, 06:48 PM   #13
BoostedAutobot
arcticms3's Avatar
Posts: 130   (View Stats)
arcticms3 is a name known to allarcticms3 is a name known to allarcticms3 is a name known to allarcticms3 is a name known to allarcticms3 is a name known to allarcticms3 is a name known to all
I have the 5900, but I did not get the remote start installed because I had no use for it. I did however get the turbo timer hooked up and its a great peace of mind to be able to arm the alarm while the turbo timer is still going.
arcticms3 is offline   Reply With Quote
 Old 04-21-2009, 01:52 AM   #14
TongMan's Avatar
my installer is asking me where the cars nuetral safety wire is at and I don't know where it's at.
 Old 04-21-2009, 08:26 AM   #15
Groans: 60
It's at the ECM under the hood, or he could search for it in the transmission harness.
 Old 04-21-2009, 01:48 PM   #16
MS6 Alan's Avatar
Posts: 453   (View Stats)
MS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the world
I'm strongly considering installing a 5901 on my MS6 in the near future. I'm sick of the 5 foot range on the OEM transmitter.
I'm surprised these shops installed the alarms on a manual trans, especially bypassing the neutral safety switch. About 5 years ago I couldn't find an installer that would touch remote start on a manual, so I did it myself.
Anyone have the MS6 wiring chart? I keep finding diagrams for the M6 but im not sure how much they differ with the advanced keyless system on the MS6.
'06 Mazdaspeed6 GT - Titanium Gray
- ATP 3076r - CP-e XCel Intake - CP-e FMIC - CP-e 4" TIP - COBB AccessPORT - Medieval EWG Manifold - Tial 44mm EWG - ATP Downpipe - Custom 3" Dual Magnaflow CBE - JBR EGR Block Off - HKS SSQV BPV - mrlilguyCDFP (KMDv1) - Denso ITV-22 Plugs - F2 BSD & Baffle - CP-e Upper Rear Diff Mount - TurbineTech Forward Rear Diff Mount - TurbineTech Front Motor Mount - AWR Rear Motor Mount - Tanabe Strut Tower Brace - Technafit SS Clutch Line - RPM Sport Springs .75/1.1 - TWM Stage 2 SS w/bushings - COBB Shift Weight - Défi-Link BF Boost Gauge - Innovate LC-1 Wideband - Hardwired Passport 8500 X50 - AuxMod Basic for CarPC -
MS6 Alan is offline   Reply With Quote
 Old 04-21-2009, 03:34 PM   #17
Team Überfrazn
labikesrcool's Avatar
Posts: 782   (View Stats)
labikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the world
can you change that remote to be vibrate only? their website isn't all that clear if it can be set to vibrate only mode.
"My car won't start!"
"Well, maybe there's a killer after you."-Mitch Hedberg
I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming.
- Mitch Hedberg
labikesrcool is offline   Reply With Quote
 Old 04-21-2009, 04:15 PM   #18
Addikted To Boost's Avatar
Posts: 1,837   (View Stats)
well guys i could be wrong but according to the ecu pinout diagram the neutral switch is a black wire with an orange stripe in location 1S.
09 MGM MS3
The Following User Says Thank You to Addikted To Boost For This Useful Post:
TongMan (04-21-2009)
 Old 04-21-2009, 05:11 PM   #19
TongMan's Avatar
thanks for the diagram layouts...I will contact my installer and have him hook up the neutral safety wire!
 Old 04-27-2009, 05:04 PM   #20
wisniaPl's Avatar
Posts: 933   (View Stats)
wisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond repute
where did you get it?? how is the alarm is it very sensitive?? Im looking to get one but I dont know which oneto get...and one last thing does it require key to be placed to use remote start or something??
wisniaPl is offline   Reply With Quote
 Old 04-28-2009, 12:46 AM   #21
TongMan's Avatar
the sensitivity can be adjusted to your liking...up to level 15, which mine is set at because it was not mounted to the firewall. You will have to cut open one programmer key and extract the chip then mount it somewhere close to the key ignition area. My extracted key is still useable.
 Old 04-29-2009, 03:59 PM   #22
wisniaPl's Avatar
what you ahve to do to the key??
 Old 04-29-2009, 05:28 PM   #23
TongMan's Avatar
slice the plastic piece in half vertically and extract the small immobilizer chip from the key, then mount the chip close to the place where you insert your key.
 Old 04-29-2009, 06:12 PM   #24
Groans: 60
There are several different parts available that will bypass the immobilizer without having to destroy a key.
 Old 04-29-2009, 07:04 PM   #25
TongMan's Avatar
my key still works...just that the immobilizer chip had been extracted. just put the black plastic fob back together after taking the chip out.
 Old 04-30-2009, 11:32 AM   #26
Hitman007's Avatar
Posts: 16   (View Stats)
Hitman007 has a spectacular aura aboutHitman007 has a spectacular aura about
If you ever need info on Bypass's here is a good site
XpressKit.com
Hitman007 is offline   Reply With Quote
 Old 04-30-2009, 12:51 PM   #27
ILL3ST
xcoldricex's Avatar
anyone know how to bypass the factory alarm? my viper is installed but if i try to remote start without disabling the alarm the factory alarm goes off.
 Old 04-30-2009, 02:41 PM   #28
Groans: 60
6/MS6 Factory Alarm Arm/Disarm:
blue or blue/white ;BCM, 24 pin plug, pin 7J
Meter this wire while turning the key in the driver door key cylinder. Arm is negative trigger thru a 1000 ohm resistor. Disarm is a straight negative trigger. MUST use relays. The BCM (Body Control Module) is in the driver kick panel.
3/MS3 Factory Alarm Disarm:
black/white ;driver kick or PJB, brown 32 pin plug (J-06), pin AA
The PJB (Passenger Junction Box) is behind the glove box. Meter this wire while turning the key in the driver door key cylinder. Disarm is a straight negative trigger.
The Following 2 Users Say Thank You to SSinstaller For This Useful Post:
labikesrcool (05-01-2009), xcoldricex (05-03-2009)
 Old 05-01-2009, 06:50 PM   #29
MZRDISI4's Avatar
Groans: 94
Hmm so you can get this installed without the remote start? That's something I'd really like because I don't want it but I do love this alarm.
 Old 05-03-2009, 10:31 PM   #30
SPD6Tuner's Avatar
Posts: 391   (View Stats)
SPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant future
I got a remote installed on my speed6. I love it so I dont have to run outside on those cold days, but I cant leave my car in gear like im used to. I hope I dont forget oneday and accidently start it while in gear.
SPD6Tuner is offline   Reply With Quote
 Old 05-04-2009, 07:15 AM   #31
TongMan's Avatar
good thing that we have the neutral safety wire on our ecu's.
Tim Bailey Remote Tune aaronc7
Cobb Access Port/Maps
50 01-11-2009 01:14 PM
remote start Ftaz1 Mazdaspeed3/6 General Discussion 11 01-05-2009 06:41 PM
Looking at the Viper 5301V Alarm/Remote Start/Turbo Timer install info mordant80 MazdaSpeed 3/6 - Car Audio & Electronics 3 10-08-2008 07:52 AM
Logitech Harmony 550 Remote Control $69.99 Haltech Hot Deals Section 0 03-26-2008 09:50 AM
Page generated in 0.48235 seconds with 34 queries
