Miata MX-5
> Miata - Forced Induction
Like Tree5Likes
 Old 12-30-2013, 06:20 AM   #121
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
Swap pads for street and track? Or you lazy like me and wouldn't want to do that?
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
 Old 12-30-2013, 07:33 AM   #122
BoostedM's Avatar
Posts: 178   (View Stats)
BoostedM is the leader of the worldBoostedM is the leader of the worldBoostedM is the leader of the worldBoostedM is the leader of the worldBoostedM is the leader of the worldBoostedM is the leader of the worldBoostedM is the leader of the worldBoostedM is the leader of the worldBoostedM is the leader of the worldBoostedM is the leader of the worldBoostedM is the leader of the world
I think that's the plan, don't really have the desire to burn up a set of 130$ pads on the street.
2006 Speed 6 Cobb AP, SRI, and cat back Magnaflow
1996 Miata M-Edition, Artech Manifold/DP Combo, China 2871, MS3, 1100cc/min injectors, 93/E85, 6-Speed
BoostedM is offline   Reply With Quote
The Following User Says Thank You to BoostedM For This Useful Post:
Boosted Beluga (12-30-2013)
 Old 12-30-2013, 08:48 PM   #123
BoostedM's Avatar
Pulled the trans and found that the pilot bearing had failed, my buddy had a spare so we reassembled and put the 6 speed in. Also fixed a coolant leak on the back side of the head.
 Old 12-31-2013, 11:23 PM   #124
bigx5murf's Avatar
Posts: 235   (View Stats)
bigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond repute
Groaned at 20 Times in 10 Posts
My friend who tracks his lightly modified MSM uses EBC yellows, on centric c-teks rotors. He says he goes 5 sessions at streets of willow with no brake fade at all. The only down side is the pads squeal unless you brake hard, and they're rough on rotors, odds of warping rotors early is pretty high. They also dust a lot, I remember touching his wheel and making a clean line, then going on a shake down run with him, one highway exit and back, that clean line was black. He says cold braking isn't bad either, but you do have to brake harder.
I had hawk HP+ on a protege years ago. I remember on a 20 degree day, I couldn't even stop my car from rolling back my driveway. Also the dust used to make my lug nuts seize up.
I'm currently running stoptech street performance on centric premium rotors, it's great on the street, and autox. But I haven't done track days. I have a friend running a turbo NA with the same brake setup. He says at streets of willow, it'll start fading after 3-4 sessions. But he's still on stock NA brakes, not the sports brakes package, so the rotors and pads are much smaller.
bigx5murf is offline   Reply With Quote
 Old 01-05-2014, 07:28 AM   #125
KWhite's Avatar
Posts: 49   (View Stats)
KWhite is a splendid one to beholdKWhite is a splendid one to beholdKWhite is a splendid one to beholdKWhite is a splendid one to beholdKWhite is a splendid one to beholdKWhite is a splendid one to beholdKWhite is a splendid one to beholdKWhite is a splendid one to behold
Carbotech pads, decent price with great resistance to fade and they work great on the street. I ran mine on US129 for around 5 runs on a 90 degree day with absolutely no fade. Plus they didn't turn my wheels black :-)
KWhite is offline   Reply With Quote
 Old 01-15-2014, 09:45 PM   #126
BoostedM's Avatar
The miata is taking a back seat for a few weeks, the ranger ive had since high school and sold to my dad got wrecked during the bad storm we got within the last couple weeks. Had to take my speed 6 up to him so he has something that can move in the snow, while I fix a exploder.
Grille, headlight, sidemarker light, front bumper, front driverside fender, door, the bed is shifted, possible frame damage, tail light, amd rear bumper are all damaged beyond repair. Pretty much totalled... more sentimental value then is probably worth fixing.
Before and after picks.
Last edited by BoostedM; 01-15-2014 at 09:48 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-16-2014, 01:34 AM   #127
Groans: 50
Ouch
08 Mazdaspeed 3
 Old 01-17-2014, 04:32 PM   #128
jomc111's Avatar
Posts: 585   (View Stats)
jomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the world
that sucks
2012 Cadillac CTS-V
2014 focus st
2010 Taurus sho- sold
2009 speed 3 gt cwp -was once a monster -sold
jomc111 is offline   Reply With Quote
 Old 01-28-2014, 11:43 AM   #129
BoostedM's Avatar
Picked up a 3.9 R&P for cheap, thinking about skipping Laguna Seca and building the motor. ive had that really bad gut feeling that the motors is gonna take a shit while im in california if i dont build it. So im thinking
Eagle or Manley H beam Rods
Supertech Pistons 9.5-10:1 depending on what i can get
Boundary Engineering Oil pump
clevite or ACl bearings
ARP Head Studs
99 head with some port and polish work.
eventually build the head with some big cams and bigger valves(maybe next year)
In other news i have a GoPro now so expect video when the weather turns.
 Old 01-28-2014, 02:41 PM   #130
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
I'd recommend the 8.6 pistons for boost. With pump gas, you will be knock limited always.. no reason to keep bumping the compression up. It's been proven time and time again that the BP motors love timing, and a low CR build will make more power everywhere if tuned right and is safer/easier to tune.
 Old 01-28-2014, 06:05 PM   #131
BoostedM's Avatar
I was planing most of the time e85. Pump gas for road trips. idk havent ordered anything yet. may drop compression to 9:1 and run E85 and see what happens.
 Old 01-30-2014, 04:23 AM   #132
aaronc7's Avatar
Groans: 370
E85 I must have missed that.... in that case disregard what I said!
 Old 01-31-2014, 08:24 AM   #133
BoostedM's Avatar
I was leaning toward 9.5:1 so it will still have decent performance on pump when I have to run it.
 Old 02-05-2014, 08:07 AM   #134
BoostedM's Avatar
i was thinking about working on it today. mother nature decided otherwise.
File Type: jpg 1551568_10201828059049272_447738803_n.jpg (38.9 KB, 91 views)
 Old 03-12-2014, 12:30 PM   #135
BoostedM's Avatar
yesterday it was sunny and 65F out so i decided to go finish the little things and bring it home. first drive with the 6speed and 4.1 gearing makes it feel like rowing a boat on down the road. the car definitely needs a 3.6 rear end. filled it up with e85 and enjoyed driving it for a day. did a quick little pull against my buddy who was driving my speed6, put bus lengths on it, couldnt be happier with that result. today its 28 and snowing. ohio sucks...
Boosted Beluga (03-12-2014)
 Old 03-18-2014, 09:42 PM   #136
BoostedM's Avatar
so i forgot how bad it was for me to drive the miata. im kinda thinking i need to get something more comfortable and bigger as a toy... my chiropractor really hates when i drive the miata because i have the spine of an old man and im probably to tall for the car to begin with. i am 21 i really dont see it getting better as i get older. so i am thinking about selling the miata. it kinda sucks but i think it will keep my back in better condition.
Boosted Beluga (03-19-2014)
 Old 03-19-2014, 10:29 AM   #137
Groans: 50
08 Mazdaspeed 3
 Old 03-19-2014, 12:29 PM   #138
BoostedM's Avatar
http://www.mazdaspeedforum.org/forum/foru...9/#post2502854
 Old 09-21-2016, 10:50 PM   #139
nolig2278's Avatar
Posts: 1   (View Stats)
nolig2278 has a little shameless behaviour in the past
Default Coil on Plugs
Hi
Did you ever get the coil on plugs working with the megasquirt? I am looking to replace my stock BPT ignition.
thanks
nolig2278 is offline   Reply With Quote
The Following User Says NO Thank You to nolig2278 For This Un-useful Post:
Neverlift (09-22-2016)
Page generated in 0.38162 seconds with 27 queries
