Miata MX-5
> Miata - Forced Induction
Like Tree5Likes
 Old 06-15-2013, 07:21 AM   #41
jomc111's Avatar
Posts: 585   (View Stats)
jomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the world
nice man
turbo does look brand new
2012 Cadillac CTS-V
2014 focus st
2010 Taurus sho- sold
2009 speed 3 gt cwp -was once a monster -sold
jomc111 is offline   Reply With Quote
 Old 06-18-2013, 07:14 AM   #42
BoostedM's Avatar
Posts: 178   (View Stats)
BoostedM is the leader of the worldBoostedM is the leader of the worldBoostedM is the leader of the worldBoostedM is the leader of the worldBoostedM is the leader of the worldBoostedM is the leader of the worldBoostedM is the leader of the worldBoostedM is the leader of the worldBoostedM is the leader of the worldBoostedM is the leader of the worldBoostedM is the leader of the world
Yesterday was dis assembly day, most of the stuff came apart nicely aside from 1 exhaust manifold nut, and the spacer pin in the rearend got lodged into the top of the power plant frame making it damn near impossible to get out. so its still under the car.
And i also got the reroute in, if i ever have to get to that with the trans in life is going to suck.
2006 Speed 6 Cobb AP, SRI, and cat back Magnaflow
1996 Miata M-Edition, Artech Manifold/DP Combo, China 2871, MS3, 1100cc/min injectors, 93/E85, 6-Speed
BoostedM is offline   Reply With Quote
The Following 2 Users Say Thank You to BoostedM For This Useful Post:
Boosted Beluga (06-18-2013), jomc111 (06-18-2013)
 Old 06-18-2013, 07:28 PM   #43
BoostedM's Avatar
Alot go finished today, new water pump, clutch is in, coolant reroute finished, manifold on, downpipe in ( we had to lift the motor and move the steering to get enough clearance to slide it through) lots of other little stuff
The Following 6 Users Say Thank You to BoostedM For This Useful Post:
aaronc7 (06-18-2013), Boosted Beluga (06-18-2013), Fail_6 (06-24-2013), J'sSpeed3 (08-28-2013), jomc111 (06-18-2013), obijack (06-20-2013)
 Old 06-18-2013, 07:32 PM   #44
jomc111's Avatar
Looking sexy
2012 Cadillac CTS-V
2014 focus st
 Old 06-19-2013, 03:16 PM   #45
BoostedM's Avatar
exhaust finished
The Following 4 Users Say Thank You to BoostedM For This Useful Post:
aaronc7 (06-19-2013), ajkulish (06-19-2013), Boosted Beluga (06-19-2013), jomc111 (06-19-2013)
 Old 06-20-2013, 09:44 PM   #46
BoostedM's Avatar
Worked most of today so didnt get much miata time, but did manage to get the steering rack back in, new timing belt on, turbo final mounted, wastegate on. i have to check and make sure the wastegate will work in that position it felt a bit weird. some wiring for oil temp/pressure gauges ran. only pic for the night.
Boosted Beluga (06-20-2013), jomc111 (06-21-2013)
 Old 06-24-2013, 08:45 PM   #47
BoostedM's Avatar
Started today trying to finish up the fuel system, why is it so hard to find a female 3/8 npt to 5/16 barb fitting? anyway did the fuel pump it had a walbro in it already, part number was different from my 255lph so possibly a 195. tank looked new and the tray had 0 rust on it, which was a huge bonus.
fit the fuel rail and injectors as well
The Following User Says Thank You to BoostedM For This Useful Post:
Boosted Beluga (06-25-2013)
 Old 06-24-2013, 08:54 PM   #48
jomc111's Avatar
Nice
2012 Cadillac CTS-V
2014 focus st
 Old 06-26-2013, 11:25 AM   #49
BoostedM's Avatar
So I'm working on my car and the motor mounts were ripped so Im now installing some new ones. Before the motor was sorta level from side to side, now on the reinstall the motor is tilting heavily to the passenger side. What did I do wrong? It looks like all the marks from the previous set line up with where the new set sits.
 Old 06-26-2013, 12:39 PM   #50
jomc111's Avatar
Post a picture, did you replace all of the mounts?
2012 Cadillac CTS-V
2014 focus st
 Old 06-26-2013, 12:53 PM   #51
ajkulish's Avatar
Posts: 412   (View Stats)
ajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the world
Groans: 40
Groaned at 15 Times in 12 Posts
that should help even out the side to side weight distribution
2006 Mazdaspeed 6 VRM
GTX3076r|Manley Pistons+Rods|AEM WMI|PnP Head|ACT 6 puck+Streetlite|COBB AP|Dramatuned|CorksportTBE|Autotech Internals|Forge v1|JBR Mounts|H&R Springs
RIP - 2007 Mazdaspeed3 GT 22V
COBB AP+SF+TIH|E30 tuned by Mark Gibson|H&R Springs|eBay Downpipe|CXRacing FMIC|KMD+Aviva|SU RMM|TurboXS Hybrid|TWM Base Bushings|Masonvi Knob
ajkulish is offline   Reply With Quote
 Old 06-26-2013, 01:06 PM   #52
BoostedM's Avatar
Replaced all 2 of them, the problem is obviously on the driver side but I'm not sure what's causing it.
 Old 06-26-2013, 01:13 PM   #53
jomc111's Avatar
wow thats way off. posibly a defect in the mount , what is the last picture off inside the mount
2012 Cadillac CTS-V
2014 focus st
 Old 06-26-2013, 01:21 PM   #54
BoostedM's Avatar
That shows where the mount should be setting but it's not moving down like it should
 Old 06-26-2013, 01:34 PM   #55
jomc111's Avatar
Ahh
2012 Cadillac CTS-V
2014 focus st
 Old 06-26-2013, 10:00 PM   #56
BoostedM's Avatar
Problem solved, the driver side had 2 different holes for the mount to fit in, it keep settling into the top one, i needed the bottom. passenger side just had an oblong single hole.
Got these mounts in the mail, and how i left it for the night. should finish up the coil on plug wiring tomorrow.
Final Checklist
  • Finish Cops
  • Finish AN Fuel Lines
  • Finish Intercooler pipework
  • Reinstall Front Bumper
  • Have Erat weld Sensor bung for IAT
  • Check Fluid Levels
  • tighten all hose connections
  • New map for IAT equipped car
  • Prime oil system and fire
Boosted Beluga (06-27-2013)
 Old 06-26-2013, 10:31 PM   #57
jomc111's Avatar
Glad you figued it out, its always the simple things the are befuddling.
Getting really close man even with a few set backs your flying threw this project
2012 Cadillac CTS-V
2014 focus st
The Following User Says Thank You to jomc111 For This Useful Post:
 Old 06-27-2013, 06:50 AM   #58
BoostedM's Avatar
yea i want to drive the thing like you wouldnt believe. also this weekend can you take a look at the tune on the speed, maybe dial out some of the throttle sensitivity. i feel like its way overly sensitive right now.
 Old 06-27-2013, 08:33 AM   #59
jomc111's Avatar
Ya ill look at it, its an easy fix
2012 Cadillac CTS-V
2014 focus st
 Old 07-03-2013, 12:25 AM   #60
BoostedM's Avatar
i can get it started but it acts as if its running on 2cyl. i have to hold the throttle to keep it running. im going to try wiring the cops in wasted spark to see if it will run correctly. sidenotes Holding good fuel pressure 50-60psi. Wideband is reading a steady 13.6 while cranking.
 Old 07-03-2013, 08:35 PM   #61
BoostedM's Avatar
Update it now runs without forcing it to
Revrant told me to change the required fuel to 3.6 since i am running e85, fixed a faulty pin on the connector i assembled for the coil on plug harness, i also fixed the intake cam ( it was 1 tooth advanced). and then it ran.
Now it is time to go through and get the clutch broken in and then tune it.
quick walkaround teaser video
Boosted Beluga (07-03-2013)
 Old 07-04-2013, 09:16 PM   #62
BoostedM's Avatar
found an exhaust leak while driving, so I disassembled it.leak was caused by uneven ceramic coating. All 4cyl were showing signs of leaking. Mostly small leaks. Leveled it out, the cleaned The gasket up, added a small amount of high temp sealer to the manifold side just as a precaution. Resealed everything and it is setting up overnight. On a side note I'm really happy with the placement of the intercooler looks like an aftermarket radiator. If I can get it tuned a bit tomorrow I am taking it to cars and coffee Saturday am.
xI Leveler Ix (07-04-2013)
 Old 07-04-2013, 09:24 PM   #63
xI Leveler Ix's Avatar
Posts: 1,752   (View Stats)
Groans: 75
This build makes me happy. I like it alot! Good luck with the rest of the mods and tweaks!
STOCK AS OF 2015...
Old Stuff....
 Old 07-04-2013, 09:56 PM   #64
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
I always end up putting some of that copper gasket spray stuff on the exhaust mani gasket.... no leaks yet. I also don't use gaskets (gasp) between the mani/turbo... just a thin, thin layer of copper rtv. zero leaks, before or after getting mani coated.
 Old 07-05-2013, 07:32 AM   #65
BoostedM's Avatar
that is exctly the way its done, so hopefuly all will be well.
 Old 07-09-2013, 07:53 PM   #66
BoostedM's Avatar
the coil on plugs were giving me all sorts of problems, so i went back to stock ignition and now its running great. needs tuned but its getting there.
jomc111 (07-09-2013)
 Old 07-21-2013, 10:04 AM   #67
BoostedM's Avatar
Drove from the Detroit burbs to Columbus a few days ago (one of the hottest days of the year thus far), was holding intake temps in between 95-100F 60-80% humidity and coolant temps 190-215F. So I need to do some serious ducting and maybe a thicker radiator. I'm going to start with ducting because the temp would be in the 190s around 55-68mph, above 70 it would climb to 200-210F. a couple pics, its definitely strange to see your own car following you.
I have a squeaky belt on startup for a while. New belt, water pump and the pulleys where all clean. We discovered the alternators bearings are shot, on startup it squeaks, after about 1min of idle you cannot touch the alternator pulley. Time for a new one.
Sidenotes: it pulls harder on wastegate pressure and barely tuned in boost then my first miata did completely tuned. have not ran it against the speed yet but it does feel faster.
Boosted Beluga (07-21-2013)
 Old 07-21-2013, 10:12 AM   #68
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
Got to love the power to weight ratio.
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
 Old 07-21-2013, 10:28 AM   #69
BoostedM's Avatar
Fun thing is this is a heavy pig compared to my buddys autox car. named 21 flavors
File Type: jpg 971869_10200607550804208_1559877823_n.jpg (80.2 KB, 191 views)
Boosted Beluga (07-21-2013), jomc111 (07-22-2013)
 Old 07-21-2013, 10:41 AM   #70
Groans: 50
Jesus. Why doesn't he at least prime it?
08 Mazdaspeed 3
 Old 07-21-2013, 10:45 AM   #71
BoostedM's Avatar
its funnier to go out and put down FTD in a car that looks like hell. plus they are out there for fun.
 Old 07-21-2013, 11:42 AM   #72
Love this project! That 21 flavors is a little deadly with that windscreen pointed at his throat.
ajkulish (07-21-2013), Boosted Beluga (07-21-2013), BoostedM (07-21-2013)
 Old 07-21-2013, 07:14 PM   #73
BoostedM's Avatar
thanks, means alot coming from a forum vendor.
Lex (07-21-2013)
 Old 07-27-2013, 11:18 AM   #74
BoostedM's Avatar
posted this on facebook a couple days ago and forgot to put it in my build thread.
Dat launch control
ajkulish (07-29-2013), Boosted Beluga (07-29-2013), jomc111 (07-28-2013), obijack (07-27-2013)
 Old 07-29-2013, 11:33 AM   #75
BoostedM's Avatar
not much going on as of late, my buddy and i ran the speed and the miata from a 30mph roll just for grins. the miata on wastegate(8psi) pulls about 2 car lengths on the speed. i couldn't be happier with that, i am going to turn the EBC back on and set it for about 12-14psi and do some tuning. i also turned the check engine light into something useful its now a shift light.
jomc111 (07-29-2013), obijack (07-29-2013)
 Old 07-29-2013, 01:21 PM   #76
obijack's Avatar
Posts: 1,830   (View Stats)
Awesome man. What mods are on the speed you ran? CEL for a shift light? Thats what I call ingenuity man lol.
2014 Honda Grom-Red
2014 Yamaha Grizzly 350- Blue
The Following User Says Thank You to obijack For This Useful Post:
 Old 07-29-2013, 01:55 PM   #77
BoostedM's Avatar
the speed is mostly stock. 06 speed6 with SRI, AP with an off the shelf stage 1 tune, and short throw shift kit. the miata with the megasquirt ecu the check engine light really did nothing else, the software has some built in sensor checking stuff that will cause a cel but it really doesnt give you any info. so for my purposes its pretty much useless, i have intentions on doing full custom LED gauge cluster and im going to put provisions for having both the tach and speedo light up for a shift light. but thats pretty far down on the list of things that i will be doing.
PS: butt dyno says the miata is making 200-220hp
 Old 07-29-2013, 03:41 PM   #78
obijack's Avatar
Sweet. BTW did you change your intake fuel pump?
2014 Honda Grom-Red
 Old 07-29-2013, 07:58 PM   #79
BoostedM's Avatar
on the speed, no its a newer stock one.
 Old 07-29-2013, 08:20 PM   #80
obijack's Avatar
I meant on the miata. I bought a walbro 255lph pump but some people say you do not need it with 1000cc injectors?
2014 Honda Grom-Red
Page generated in 0.60619 seconds with 28 queries
