![]() | | #81 | ![]() |
![]() Join Date: Apr 2013 Location: London,OH ; Canton, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7
__________________ 2006 Speed 6 Cobb AP, SRI, and cat back Magnaflow 1996 Miata M-Edition, Artech Manifold/DP Combo, China 2871, MS3, 1100cc/min injectors, 93/E85, 6-Speed |
| The Following 2 Users Say Thank You to BoostedM For This Useful Post: | Boosted Beluga (07-29-2013), obijack (07-29-2013) |
![]() | | #82 | ![]() |
![]() Join Date: Jun 2009 Location: Riverside, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,560
Groans: 50
| Not Ranked : 0 score The right way to do it.
__________________ 08 Mazdaspeed 3 Fucking FREEK TUNED and shit |
![]() | | #83 | ![]() |
(Thread Starter) | Not Ranked : 0 score Havent updated this in a while because i have just been enjoying this thing, turned it up to 10psi and have been DDing it since my dads neighbor backed into the speed ![]() tuesday i decided to take a trip and headed for my grandparents house in West Virginia. Car ran fantastic all the way there, parked it and hungout for a while. came out to this, who needs brakes anyway. so i borrowed their truck and came back home to find a new master cylinder. along the way one of the miataturbo guys pointed out my mistake, aperently i missed or a sync got screwed up setting the timing back to using the table so it was locked in at 10 degrees at all times. weird thing is it was still faster than my old car and was faster than a couple of buddies cars. their in for some trouble when i get the master cylinder fixed.
__________________ 2006 Speed 6 Cobb AP, SRI, and cat back Magnaflow 1996 Miata M-Edition, Artech Manifold/DP Combo, China 2871, MS3, 1100cc/min injectors, 93/E85, 6-Speed Last edited by BoostedM; 10-06-2013 at 07:26 AM. |
| The Following User Says Thank You to BoostedM For This Useful Post: | Boosted Beluga (08-28-2013) |
![]() | | #84 | ![]() |
| Not Ranked : 0 score Put a heatshield or blanket on that hotside
![]() | | #85 | ![]() |
(Thread Starter) | Not Ranked : 0 score I have one about half made here at the house, just havent had time to finish it. Guess what moved up on the priority list. i also have one of those dei cool mat things and cool tape to help.
![]() | | #86 | ![]() |
![]() | | #87 | ![]() |
Groans: 370
| Not Ranked : 0 score Wait, so how long were you driving this thing at static 10 degrees timing? Sent from my Nexus 7 using Tapatalk 2 |
![]() | | #88 | ![]() |
(Thread Starter) | Not Ranked : 0 score Probably about 3 weeks. I felt like a real dumbass afterward.
![]() | | #89 | ![]() |
Groans: 370
| Not Ranked : 0 score Damn, I hope you didn't mess anything up running 10* like that for extended cruises. Cruise cells it's normally in the 30 something degree range. Not trying to make you paranoid or anything-- but running very low timing will drive EGTs way up as well. I'm guessing you if went that long without issues, you'll be just fine lol. Lesson learned I guess! |
![]() | | #90 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yea I think everything is fine. I remember setting it back to the table. it didn't sync or ssomething. I imagine the car will be a whole hell of a lot faster now, and it wasn't slow stuck at 10degrees.
![]() | | #91 | ![]() |
(Thread Starter) | Not Ranked : 0 score I went back to my grandparents and switched out master cylinders, got a heat shield fabed up, added some cool tape, fixed my retard mistake timing. this is what I came up with Eventually I might add a turbo blanket and exhaust wrap. Not 100% sure I want to do that or not though. It drove fantastic all the way home.
| The Following User Says Thank You to BoostedM For This Useful Post: | jomc111 (09-02-2013) |
![]() | | #92 | ![]() |
(Thread Starter) | Not Ranked : 0 score The car has been running great, im a bit worried about destroying the 5 speed because im not easy on it. Happened to go to a ohio miata owners meet and was chatting with a guy who wants to swap from a 6 speed to the 5 speed. So im probably going to see what he wants in addition to my 5 speed. Im going to read up on the swap and what I need to to it, as well as look for a 3.9 or 3.6 gear set.
| The Following User Says Thank You to BoostedM For This Useful Post: | jomc111 (09-15-2013) |
![]() | | #93 | ![]() |
Groans: 370
| Not Ranked : 0 score Why in the world does he want to get the 5 speed? Either way...jump on that!!! The swap is very easy, really nothing to it. The 5 speed and 6 speed shifters are different. The staters are different, but work fine either way (I'm using 5 speed starter with mine). Easiest thing to do would just be swap all that stuff. Since you have an NA, there might be a few wiring differences, but should be easy work to do with the trans off the car. I have an NB so it was straight plug and play wiring wise. I'm sure there's many many 6 speed into NA miata guides/write ups. While you have the transmission out of the car.... I'd inspect/replace a few things. You will certainly need/want the two shifter boots replaced: INSULATOR (NA01-64-481B) - $23.60 - NA0164481B BOOT,DUST (M513-17-480A) - $39.38 - M51317480A Other things you may not need, but maybe a good idea to replace while you're there: COVER,DUST (FE51-16-214A) - $9.95 - FE5116214A SLAVE CYLINDER (PBRNA0141920C) - $29.95 - PBRNA0141920C I'll let ya know if I think of anything else. |
![]() | | #94 | ![]() |
| Not Ranked : 0 score Isn't the 6speed a little weaker than the 5speed? I had a 2002 6speed for a few years and remember reading that, may have it backwards.
![]() | | #95 | ![]() |
Groans: 370
| Not Ranked : 0 score other way around. 6 speed is much stronger than the 5 speed. I blew my 5 speed at around 250-270whp. Back to OP real quick... you probably have 4.1 gears in your car now, so yeah, you will definitely want some longer gears at some point. 3.9s are great for a stock motor car... once you start moving to north of 300whp, at some point they become a bit short though and the 3.63s are the obvious solution... but they are quite rare and $ as you probably already know. |
![]() | | #96 | ![]() |
(Thread Starter) | Not Ranked : 0 score Hes got a 4.3 rear drive on a stock 02. He wants to do autocross so less shifting is key. I have the 4.1 gears, I drove an msm last night to get an idea what it will be like. 1st was practically useless though.
![]() | | #97 | ![]() |
Groans: 370
| Not Ranked : 0 score I take it he had a 5 speed originally to have that 4.3 rear? I had 3.9 gears with 5 speed originally on my stock engine turbo setup. It was actually quite nice, but the 5 speed just can't take it, sadly. |
![]() | | #98 | ![]() |
(Thread Starter) | Not Ranked : 0 score The plan for this car is to begin to prepare it to be on track by next season. I have a bunch of things to address before hand. Better cooling, brakes, some custom seat mounts, rollbar. Im 6'4" so I have to definitely have a low seat on the floor to be able to pass inspection.
![]() | | #99 | ![]() |
(Thread Starter) | Not Ranked : 0 score Speedway remodeled a station close enough to me and installed E85 pumps. so i switched back. Put about 20 miles on the tune and did a data log for Virtual dyno and came up with this. im fairly happy with the results. Afr's are a bit jumpy due to the fresh tune.
![]() | | #100 | ![]() |
Groans: 50
| Not Ranked : 0 score How much boost?
![]() | | #101 | ![]() |
![]() | | #102 | ![]() |
Groans: 50
| Not Ranked : 0 score Didn't look at the data log. Only v-dyno. Looks good so far.
![]() | | #103 | ![]() |
(Thread Starter) | Not Ranked : 0 score Log wasnt attached, add some boost and timing to get just shy of 250wtq.
| The Following User Says Thank You to BoostedM For This Useful Post: | Boosted Beluga (09-24-2013) |
![]() | | #104 | ![]() |
(Thread Starter) | Not Ranked : 0 score Got the car aligned, the rear needs new control arm bushings. all they could get it to do was -2.7 camber shooting for about -2. it took about 10 minutes to get it up on the rack becuse the ride height is set at 12in center of hub to fender. blasted Through The hills last weekend with some fellow miata owners. Had a fantastic time, and the car ran flawlessly. Pictures from said event In other news, the speed 6 is fixed after about 2 months of fighting with insurance companies.
| The Following User Says Thank You to BoostedM For This Useful Post: | Boosted Beluga (10-17-2013) |
![]() | | #105 | ![]() |
(Thread Starter) | Not Ranked : 0 score So with the season coming to an end I'm starting to consider my options for winter mods. So far I have 1.6 dash swap Clean up engine bay/ paint minor wire tuck 3.6 gears hopefully a 6speed Current wheels getting neogens Cspence style hidden hid headlights? Control arm bushings Brakes? Funds permitting Bigger radiator Water/meth Rollbar Track time I'm a bit worried about not making enough power to need the 3.6 gears any thoughts?
![]() | | #106 | ![]() |
Groans: 370
| Not Ranked : 0 score I'm guessing you currently have the 4.1 gears? 6 speed and 3.9 gears is pretty nice up to 300whp I'll say. The 3.9 gears route will be much cheaper most likely. You can pick up a whole torsen 3.9 pumpkin and just swap em..sell your current setup and probably won't spend much money in the end. If you go 3.6 gears, you gotta buy the gears, and then the labor (will probably be just as much as the gears) to swap it all over. Just something else to think about. |
![]() | | #107 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well the 3.9 full pumpkin is like 6-900, the 3.6 gears are going to cost ballpark 300. Unsure about the install labor but say same cost as gears so 600 total not sure which one is the better investment.
![]() | | #108 | ![]() |
(Thread Starter) | Not Ranked : 0 score well today i took the car out for one of the last times this season, and broke it. i now have a thumping sound when i let out of the clutch. im thinking the throwout bearing or clutch is busted. wont have time/ shop space to get dug into it till january. sad day indead.
| The Following User Says Thank You to BoostedM For This Useful Post: | Boosted Beluga (11-11-2013) |
![]() | | #109 | ![]() |
![]() Join Date: Nov 2010 Location: Jacksonville, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,647
| Not Ranked : 0 score That sucks man. That is something to live by. Never, one last time lol.
__________________ 2004 Dodge Dakota- SLT 4.7L V8- Burgundy 2013 Kawasaki Ninja 636 (Zx6r)- Green/ Black 2014 Honda Grom-Red 2014 Yamaha Grizzly 350- Blue 2007 Yamaha Raptor 700 GYTR- White- [SIGPIC][/SIGPIC] |
![]() | | #110 | ![]() |
__________________ 2006 Speed 6 Cobb AP, SRI, and cat back Magnaflow 1996 Miata M-Edition, Artech Manifold/DP Combo, China 2871, MS3, 1100cc/min injectors, 93/E85, 6-Speed | |
| The Following 2 Users Say Thank You to BoostedM For This Useful Post: | Boosted Beluga (11-15-2013), obijack (11-15-2013) |
![]() | | #111 | ![]() |
__________________ 2004 Dodge Dakota- SLT 4.7L V8- Burgundy 2013 Kawasaki Ninja 636 (Zx6r)- Green/ Black 2014 Honda Grom-Red 2014 Yamaha Grizzly 350- Blue 2007 Yamaha Raptor 700 GYTR- White- [SIGPIC][/SIGPIC] | |
| The Following User Says Thank You to obijack For This Useful Post: | Boosted Beluga (11-15-2013) |
![]() | | #112 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 102
Groaned at 20 Times in 10 Posts
I have a line of a brand new set that just became available from a friend stateside, not sure how much he wants for it, but it's brand new, and he knows what they're worth. The only way to get a set at $300-400 is to import a set from Japan or Australia, without at least one other person splitting shipping with you, it won't be $300-400. I have a source in Australia if you're interested. Also, all the seals which "should" be replaced when swapping the gears, comes out to just over $200. | |
![]() | | #113 | ![]() |
![]() | | #114 | ![]() |
![]() | | #115 | ![]() |
Groans: 370
| Not Ranked : 0 score There's probably a decent chance I'll sell my 3.6 set of gears here before long, if you're not in a huge hurry. I also visit Ohio pretty often and could just bring it up with me some time (not sure where you normally live, you have 2 locations on your profile). |
![]() | | #116 | ![]() |
| Not Ranked : 0 score check this out MIATAROADSTER 3.3:1 RING AND PINION GROUP BUY Happy holidays, everyone! As some of you may remember, a 3.3:1 gear set has been a pet project of mine since at least 2008. So I'm happy to announce that I've finally found a reputable and relatively affordable source to manufacture race-caliber 3.3:1 ring and pinion sets for the Miata market. A minimum of 15 paid orders are required to make this happen, but based on the number of inquiries I've already received, this will happen. If you're active on multiple forums, you'll see me promoting this group buy on all of the ones that MiataRoadster sponsors. If interested in participating, you need contact me only once! This is a bit complicated, so please carefully read the following then email me if you'd like to place an order or want clarification on anything: BENEFITS OF THE 3.3:1 RATIO: See the attached chart comparing various final drive ratios and transmissions. (Thanks to Brian Kelley.) DELIVERY SCHEDULE: The manufacturer will provide me with a sample gear set to install and test by approximately the end of February 2014. Once it's approved, it will take about one month for the production parts to be completed. So best case scenario, don't expect to receive your set before March-April 2014. If you don't think you're patient enough to pay up front and wait that long, then please don't. GROUP BUY PRICE: $550 (MSRP after this initial group buy is expected to be at least $650) DEALER PRICING: Dealers are welcomed to contact me for wholesale pricing for group buy orders and future orders assuming there's enough demand to make these gears available in an ongoing manner. PAYMENT SCHEDULE: To participate in the group buy, your payment in full for the gears (payment for optional upgrades is not required initially) must be received by Monday morning 12/16/13. PICTURES: As the actual parts have not been made yet, the next best thing I can show you for illustration is the image above of a 3.6:1 Mazda gear set, which looks identical to the planned 3.3:1 except for the number of teeth on the pinion and ring gears. SPEEDOMETER & ODOMETER DISPLAYS: There's no solution for displaying accurate speedometer and odometer readings for this gear ratio with the mechanical speedo drive system used on the NA, so consider this gear ratio as for "off road use only." For the electronic speedo drive system used on the NB and NC, there are aftermarket options like the YellowBox synchronizer to modify the signal between the stock sender and the instrument cluster display. TECHNICAL SPECS: Location of manufacturer: Taiwan Manufacturing process: forging, CNC milled Material: 8620 Nickel-Chromium-Molybdenum Steel Treatments: carburized (AKA case hardened) heat treatment Hardness: ISO 6508-1 Rockwell C Scale HRC 60-63 Tensile strength range: 700-1100 MPa UPGRADE OPTIONS: When we're closer to the ship date for the gears, I'll post a menu of optional parts and services that can be ordered later, as a separate purchase from the gear set. I can supply genuine Mazda rebuild components and kits (bearings, seals, input flange/harmonic dampener, etc.), ARP fastener kits, machined billet crush tube, reinforcement saddle caps, YellowBox, WPC treatment, cryogenic treatment, coatings, and installation services for NA, NB, and NC. WARRANTY: These are competition parts and, as such, no warranties are implied or offered. No refunds or returns will be processed once parts are shipped. In the unlikely case of a manufacturing defect preventing proper setup of the gears, a replacement gear set will be provided ASAP at my expense once the original parts are returned to me for inspection and deemed defective by me. TO ORDER: Email me at Bill@MiataRoadster.com with your complete real name, your forum name (so I can cross-reference your identities and not count you multiple times), your complete shipping address, and I'll send you a quote to review and approve. Once you approve your quote, I'll send you payment instructions. Thanks for your interest! Bill |
| The Following User Says Thank You to bigx5murf For This Useful Post: | Boosted Beluga (11-27-2013) |
![]() | | #117 | ![]() |
(Thread Starter) | Not Ranked : 0 score well all the go fast goodies are going on hold for now, while i get all the safety and track stuff ready. hopefully hit the first track day at mid-ohio in may and then in september i will be taking a vacation and heading out with a group from ohio to hit the Mazda Lugana Seca track event. 5300 miles round trip, and a little over a week of traveling and hitting some of the miata venders shops while there. should be a good time.
| The Following User Says Thank You to BoostedM For This Useful Post: | Boosted Beluga (12-16-2013) |
![]() | | #118 | ![]() |
(Thread Starter) | Not Ranked : 0 score Just got back from picking up a 40k mile 6 speed trans for get this 450$. Pretty good deal if I do say so myself.
![]() | | #119 | ![]() |
![]() Join Date: Jul 2013 Location: OH-Akron/Dayton
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 45
| Not Ranked : 0 score Read your thread on CR, I like the autocross car looks fun. I got a 95 miata and speed3.
__________________ AP|RMM|TP|HPFP|E40 |
![]() | | #120 | ![]() |
(Thread Starter) | Not Ranked : 0 score my buddy came and picked up the car today, its sitting at his shop ready to drop the trans out tomorrow and see what happened. while its there i have a hard dog hardcore DD roll bar and a 90 dash to put in, as well as taking the soft top out for good. we are also putting the 6speed in i picked up for a cool $450 and some small cleanup items i want to get accomplished. Im looking into brake pads and i cant really decide what i want to do, im leaning toward Hawk HPs because it is a street car but will see some track time as well. Input?
