![]() Join Date: Apr 2013 Location: London,OH ; Canton, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7
(Thread Starter) | Not Ranked : 0 score The Build Plan Begi Log manifold, SR20 Oem T25, Megasquirt MS3, 1100cc/Min FIC injectors, M-tuned Coolant ReRoute and Dual Feed Fuel Rail, Toyota Coil on Plug conversion Running Full sequential Spark, Homemade Down Pipe, E85 Progress Stage 1 Get car running on the Megasquirt on e85 with the Coil on Plugs. The Previous owner really didnt know what he had and didnt keep the car all that clean on the inside, he left me presents... oem Mazda ECU placement The mega-squirt has an internal map sensor that needs a vacuum source, alot of guys run it straight through the firewall. I found on my last miata that this way is a pain in the ass so i decided to do it a different way. looks a little bit more oem from the engine bay prospective. the head has been gone through at some point, sweet More to come in the following weeks
__________________ 2006 Speed 6 Cobb AP, SRI, and cat back Magnaflow 1996 Miata M-Edition, Artech Manifold/DP Combo, China 2871, MS3, 1100cc/min injectors, 93/E85, 6-Speed |
| The Following 10 Users Say Thank You to BoostedM For This Useful Post: | Ace Protege (05-29-2013), Boosted Beluga (05-29-2013), El_Diablo (06-10-2013), forcedinduktion (06-06-2013), Funkster777 (05-29-2013), Jh8909 (05-29-2013), leon78 (05-29-2013), obijack (06-01-2013), smoogs12 (05-29-2013), Tomas (07-21-2013) |
(Thread Starter) | Not Ranked : 0 score Started the day like this. finished up installing the new injectors and mtuned fuel rail. Struggled with the o2 sensors for a few hours and many torch attemps with a finally result of me-0 o2-1. its not a project around my house if you havnt spilled blood all over it after getting bandaged up, i took a look at the intake and decided since i dont live in communist California egr must disappear Final mounted the MS, ignore the blue wire i was testing a ground for the radio. Final resolution for wideband, cut a hole in the exhaust and weld a 3rd bung in. sounded easy enough till i could find the welders helmet in the sea of boxes in the garage. pulled the set it close and close your eyes method, have to say it looks like a 3 year old did it but should work till i find the helmet and can redo it. no pics of that though. should be ready to setup the tune and first fire on ms tomorrow morning.
| The Following 5 Users Say Thank You to BoostedM For This Useful Post: | aaronc7 (06-10-2013), Ace Protege (05-29-2013), Boosted Beluga (05-30-2013), Funkster777 (05-29-2013), jomc111 (05-29-2013) |
![]() Join Date: May 2011 Location: Vero Beach, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 417
| Not Ranked : 0 score Solid plan, T25 will probably leave you wanting more though.
__________________ '02 Bmw 330ci Kinda low and really slow. '94 Mazda Protege -SOLD 1.8 BPT Vf10 263whp 258wtq 13.1 @ 107 mph '05 ZX-6RR - Two Brothers slip on, GPR dampener V1, More to come |
(Thread Starter) | Not Ranked : 0 score yea i already want more and its not installed, but the 220-250ish hp ballpark keeps the rods in the block.
| Not Ranked : 0 score yep, lol if you note my numbers that's why I'm happy till I decide to do rods and pistons. T25 will probably be right around 200whp.
(Thread Starter) | Not Ranked : 0 score i squeezed what virtual dyno called 226 out of a 1.6 with a td04 based greddy kit. so i think with some cleaver timing and e85 i can make 230 happen. if not get a bigger turbo.
| The Following User Says Thank You to BoostedM For This Useful Post: | J'sSpeed3 (07-21-2013) |
| Not Ranked : 0 score well, only one way to find out! lol btw, where did you get the Mtuned Fuel rail?
(Thread Starter) | Not Ranked : 0 score One of the Miata Turbo Site Vendors 949 Racing , looking forward to having a turbo miata again, the speed is fun but not the same as a turbo miata.
| The Following User Says Thank You to BoostedM For This Useful Post: | jomc111 (05-29-2013) |
| Not Ranked : 0 score I only see a listing for a 1.6 rail.
(Thread Starter) | Not Ranked : 0 score well that weird, if your looking for one send emillio an email hes really easy to deal with and can probably either get you one or point you in the right direction.
| The Following User Says Thank You to BoostedM For This Useful Post: | Ace Protege (05-29-2013) |
| Not Ranked : 0 score yeah, a rail has been on my to-do list for a while and I figure I'll do it when I replace my injector seals and put on a Hondata thermal gasket.
(Thread Starter) | Not Ranked : 0 score regular gas 3.99 at the station i picked up e85 from, E85 was 3.19 thats a win in my book. it starts after you fool the ms into letting it, The tune rev put on its for the gm iat that i dont have yet. i pm'd him about getting one for a maf car for the time being. Once started i found the intake has a bad leak somewhere and the exhaust is leaking around the homemade egr cap, i kinda figured it would. may mess with it tomorrow or Saturday depending on whats going on around here. anyway first idle video for you guys.
(Thread Starter) | Not Ranked : 0 score figured out the leak was partially the egr block off plate, and partially cyl 4's injector seal not seating correctly. got that fixed and the new map reverent sent me on, forgot to save the old one for when i switch to the gm iat so i will have to get that from rev again. had it idling fine have a leak around the bung i poorly installed into the exhaust, may go get a new welding mask tomorrow morning and fix it(i cant for the life of me find the one we have, its still in a box somewhere). but did a quick around the block running super rich, felt fairly good.
![]() Join Date: Nov 2010 Location: Jacksonville, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,647
| Not Ranked : 0 score Glad to see this build coming along so fast. I cannot wait to start ordering parts for my miata. I will prolly go with a gt28 series from the get go tho.
__________________ 2004 Dodge Dakota- SLT 4.7L V8- Burgundy 2013 Kawasaki Ninja 636 (Zx6r)- Green/ Black 2014 Honda Grom-Red 2014 Yamaha Grizzly 350- Blue 2007 Yamaha Raptor 700 GYTR- White- [SIGPIC][/SIGPIC] |
(Thread Starter) | Not Ranked : 0 score i have 200 buck in the manifold and turbo so i cant complain. but if i were buying stuff at normal prices i would got with the gt28 as well.
| The Following 3 Users Say Thank You to BoostedM For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score Last few pieces I need; oil sandwich plate, adjustable fuel preassure regulator, some mica mandrel bent tubing, ebc solenoid, and gm iat sensor.
| The Following User Says Thank You to BoostedM For This Useful Post: | jomc111 (06-03-2013) |
(Thread Starter) | Not Ranked : 0 score so i put off finding the welding mask till this morning, got it re-welded sorta. never again will i weld laying on my back with no room to work. looks horrible, has a small leak. luckily its getting replaced when the turbo goes on so idgaf. drove it around and got some tuning done, pissed the neighbors off and made allot of noise. all in a good days work if i do say so myself. driving it tomorrow to do some more tuning and get some more of that wonderful E85. Plan now is to add in some timing and do a virtual dyno run to see if i gained anything over stock power. if i didnt
| The Following 2 Users Say Thank You to BoostedM For This Useful Post: | Boosted Beluga (06-05-2013), jomc111 (06-05-2013) |
![]() Join Date: Jan 2012 Location: westland , mi
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 517
| Not Ranked : 0 score Im sure you will gain some , glad to hear you have it back on the road
__________________ 2012 Cadillac CTS-V ![]() 2014 focus st ![]() 2010 Taurus sho- sold 2009 speed 3 gt cwp -was once a monster -sold |
![]() | | #19 | ![]() |
(Thread Starter) | Not Ranked : 0 score thanks it felt good to drive it again, on a side note e85 smells really good but the odor hangs around for a while parked the car and came back out 1hr later and you could smell it 20-30 feet away.
![]() | | #20 | ![]() |
(Thread Starter) | Not Ranked : 0 score well 1 Launch Control rev blew the temp fix i had on the wideband bung :vash: though adding about 18% across the board on the fuel map got it really close, and VE got it the rest of the way. guess the plan is to cut out crappy pipe, go get new pipe and bung and profit.
| The Following 2 Users Say Thank You to BoostedM For This Useful Post: | Boosted Beluga (06-06-2013), jomc111 (06-06-2013) |
![]() | | #21 | ![]() |
| Ur moms boyfriend ![]() Join Date: Jul 2010 Location: Chicago, ILL
Rep Power: 1272 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 923
Groans: 70
| Not Ranked : 0 score awesome project man
__________________ [01:31 PM] SoAgg159: my dick is called "quarter mile" it's about 1/4" long and i can give about 14secs of pleasure [07:06 PM] DarkHeartMS6: yeah. I actually hope i catch my wife with another dude. gives me an excuse to open the emergency door and bail. LOL [09:13 PM] Pu Manchu: i like to take my gf through the drive thru so i can prove that i can pleasure a woman |
![]() | | #22 | ![]() |
(Thread Starter) | Not Ranked : 0 score thanks man, should get more awesome in the coming weeks. i have alot of custom stuff planed that you should be seeing soon.
| The Following 2 Users Say Thank You to BoostedM For This Useful Post: | Boosted Beluga (06-06-2013), forcedinduktion (06-06-2013) |
![]() | | #23 | ![]() |
| Not Ranked : 0 score Let me know if you need a hand after this weekend I dont have much going on
![]() | | #24 | ![]() |
In other news im selling my pieced together setup and getting this SS awesome setup. i decieded that i hate messing with exhaust, so get a good one and leave it alone. also comes with a larger turbo then i had previously so win win. oh and its pretty, and sounds healthy to.
__________________ 2006 Speed 6 Cobb AP, SRI, and cat back Magnaflow 1996 Miata M-Edition, Artech Manifold/DP Combo, China 2871, MS3, 1100cc/min injectors, 93/E85, 6-Speed | |
| The Following 2 Users Say Thank You to BoostedM For This Useful Post: | Boosted Beluga (06-07-2013), jomc111 (06-07-2013) |
![]() | | #25 | ![]() |
![]() Join Date: Feb 2012 Location: Anaheim, Orange County
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,921
| Not Ranked : 0 score How much? ![]() Sent from my SPH-L900 using Tapatalk 2
__________________ 2007 Mazdaspeed 3 GT 18x8.75 XXR 527 225/40/18r COBB AP// Finkles hypnotic sexyness 50/50 e85// HTP 3.5 Whale Penis// HTP 51R battery box// JBR Adjustable SSP//JBR 88 RMM// Grimspeed 3 port EBCS// CX Racing FMIC// CNT Racing catless DP// AT internals// Lamin-x Fog light inserts// Stiffy Ingals Mtourque Mount// Asian tower brace(lol)// CNT Racing Catback// Turbo XS RFL BOV VTA FTMFW!!// Upgrated clutch// Drilled and sloted rotors (font and back)// UNDER THE KNIFE New fucken miata build: 1993 Red Na6 Some suspension modz yo 1994 Caste White MX5 Miata - sold 1991 Smurf Blue miata - sooooooold Coilovers// Other shit |
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'm assuming you mean for the manifold and turbo stuff. You have a pm.
![]() | | #27 | ![]() |
Groans: 370
| Not Ranked : 0 score Abe/ARTech is the best. Looks almost identical to what I have. You went with the bigger muffler though! Did you build the MS3 yourself? |
![]() | | #28 | ![]() |
(Thread Starter) | Not Ranked : 0 score i bought it off mt gently used, and Rev built the ms3. im expecting it to be alot of fun.
![]() | | #29 | ![]() |
Groans: 370
| Not Ranked : 0 score Nice. I'm looking for an excuse to jump from my MS2/DIYPNP to MS3, but I can't quite justify it. Don't have VVT, which is probably the biggest selling point for MS3 right now over MS2. |
![]() | | #30 | ![]() |
(Thread Starter) | Not Ranked : 0 score i just went with the basic ms3. i bought the turbo stuff off fowlermotorsports, he said it should be here Friday so hopefully next week i will be installing. no big deal if its not here friday i still have to do the 949 stage 1 clutch and mtuned coolant reroute so i will be busy for a couple days.
![]() | | #31 | ![]() |
![]() Join Date: Jun 2012 Location: Detroit MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 236
Groans: 40
Groaned at 15 Times in 12 Posts
| Not Ranked : 0 score i was very confused reading the last few posts.... i guess ms3 has a couple different meanings haha
__________________ 2006 Mazdaspeed 6 VRM GTX3076r|Manley Pistons+Rods|AEM WMI|PnP Head|ACT 6 puck+Streetlite|COBB AP|Dramatuned|CorksportTBE|Autotech Internals|Forge v1|JBR Mounts|H&R Springs RIP - 2007 Mazdaspeed3 GT 22V COBB AP+SF+TIH|E30 tuned by Mark Gibson|H&R Springs|eBay Downpipe|CXRacing FMIC|KMD+Aviva|SU RMM|TurboXS Hybrid|TWM Base Bushings|Masonvi Knob |
![]() | | #32 | ![]() |
MS Labs ECU Comparison Sheet
| The Following User Says Thank You to BoostedM For This Useful Post: | obijack (06-12-2013) |
![]() | | #33 | ![]() |
Groans: 40
| Not Ranked : 0 score yeah i caught on to that after i read MS2 haha
![]() | | #34 | ![]() |
![]() | | #35 | ![]() |
| Not Ranked : 0 score What are the pros and cons of megasquirt compared to hydra or AEM?
![]() | | #36 | ![]() |
(Thread Starter) | Not Ranked : 0 score price - megasquirt is cheaper Functionality - functions just as well if not better Most of miata turbo use megasquirt so there is a huge knowledge base i believe megasquirt is open source so there are different people doing vastly different things with hardware and firmware.
| The Following User Says Thank You to BoostedM For This Useful Post: | obijack (06-13-2013) |
![]() | | #37 | ![]() |
(Thread Starter) | Not Ranked : 0 score Sold the original setup i had yesterday. surprisingly enough it fit all into a large flat rate box. weighted in at 27lbs. drove it a little bit today, so picture time.
| The Following User Says Thank You to BoostedM For This Useful Post: | jomc111 (06-15-2013) |
![]() | | #38 | ![]() |
(Thread Starter) | Not Ranked : 0 score Got home and about cried when i saw the box. thanks ups But started unpacking and all was undamaged, thankfully. so without further interruption, some fap material for tonight. i dont think this turbo has ever been on a car For comparison
__________________ 2006 Speed 6 Cobb AP, SRI, and cat back Magnaflow 1996 Miata M-Edition, Artech Manifold/DP Combo, China 2871, MS3, 1100cc/min injectors, 93/E85, 6-Speed Last edited by BoostedM; 07-29-2013 at 09:16 AM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says NO Thank You to BoostedM For This Un-useful Post: | Boosted Beluga (06-14-2013) |
![]() | | #39 | ![]() |
Groans: 370
| Not Ranked : 0 score what turbo is that? |
![]() | | #40 | ![]() |
(Thread Starter) | Not Ranked : 0 score 2871 clone, just a bit bigger than the sr20 turbo i was going to us.
| The Following User Says Thank You to BoostedM For This Useful Post: | Boosted Beluga (06-14-2013) |
| Display Modes | |
