Miata MX-5
> Miata - Forced Induction
  • 1 Post By kritz
 Old 05-22-2013, 06:52 AM   #1
Alejo_NIN's Avatar
Posts: 1,700   (View Stats)
Alejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the world
Groans: 88
Groaned at 186 Times in 83 Posts
Default '97 Turbo Miata Build - Water-toAir IC
so, i've always been fascinated with the water to air intercoolers.
they are more common than you think, for instance, the bugatti veyron has water to air, so does the fordGT and even the ford focus RS in eurpe, equipped with a water-to-air intercooler from factory...
so, i must ask...
is it worth it?
the pros i see are:
shorten piping, basically, on the miata is two 90 degree bends and the intercooler...simple enough...no pressure drop.
adding ice to water significantly reduces the temp to below ambient, quick.
water removed heat much betetr than air....why do you think they have water in the radiator?
cons
complicated setup with pumps and water lines, and heat exchangers
may be more expensive than fmic
so, that's my debate...i think it would look so much cleaner if done properly.
any ideas
here is an example:
radonelement.com
Alejo_NIN is offline   Reply With Quote
The Following User Says Thank You to Alejo_NIN For This Useful Post:
kmac (05-23-2013)
 Old 05-22-2013, 07:54 AM   #2
chuckms6's Avatar
Posts: 1,618   (View Stats)
I approve! Water to air its so much more efficient and space friendly, not to mention shorter piping. If I was too do my setup right the first time instead of parts swapping to find the right combo it would have cost me $600, and that's with -an fittings and the shitty cobra pump. If you have any questions feel free to ask.
Sent from my SAMSUNG-SGH-I727
Megan Racing Coilovers
13.7@ 96 w/1.8 60ft (SRI, AP)
The Following User Says Thank You to chuckms6 For This Useful Post:
Alejo_NIN (05-22-2013)
 Old 05-22-2013, 08:03 AM   #3
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
@kmac; Ran on in his MS3. Living where you don't have to worry about freezing is a plus. Just an added pump and heat exchanger that's it.
Nator is what it does.
The Following 2 Users Say Thank You to kritz For This Useful Post:
Alejo_NIN (05-22-2013), kmac (05-22-2013)
 Old 05-22-2013, 09:56 AM   #4
Alejo_NIN's Avatar
Groans: 88
well, one thing to note though, is that heatsoak is much, much worse on a water to air than air to air.
it can be countered by having more water, but now you are adding more weight to the car.
it can also be countered by using different chemicals, or even using dry ice around the water container to keep it from becoming too hot...but then, how long would it take to melt?
i think the beenfits outweight the cons...
i just need to convince my brother...
radonelement.com
 Old 05-22-2013, 09:58 AM   #5
kritz's Avatar
Groans: 95
Brownie faggot!
helmetface likes this.
helmetface (05-22-2013)
The Following User Says NO Thank You to kritz For This Un-useful Post:
 Old 05-22-2013, 10:02 AM   #6
chuckms6's Avatar
Once you have the right combo of parts and everything is working right heatsoak is a non issue. My car always finds a delta about 20% over ambient and stays there as long as the pump is running. It heats up during a pull simply because of stock turbo inefficiency but the temps are on par with the best air to air setups on the market, with the exception that at the beginning of a pull I'm already at the coldest bat that the air to air will reach. After a pull it goes right back to the delta temp within 10 seconds.
 Old 05-22-2013, 10:44 AM   #7
Alejo_NIN's Avatar
Groans: 88
what pump are you using?
radonelement.com
 Old 05-22-2013, 11:24 AM   #8
Mochi's Avatar
Posts: 152   (View Stats)
Mochi is the leader of the worldMochi is the leader of the worldMochi is the leader of the worldMochi is the leader of the worldMochi is the leader of the worldMochi is the leader of the worldMochi is the leader of the worldMochi is the leader of the worldMochi is the leader of the worldMochi is the leader of the worldMochi is the leader of the world
Groaned at 9 Times in 5 Posts
sub
1975 280Z Datsun - EX header, mild intake port, hotter cam, flattop pistons, black dragon muffler, 5speed swap - Retired Autox shit box
1991 240sx Nissan - shitty ebay "cold air intake", walboro 255 (Murdered by ExGF)
2008 Mazdaspeed 3 COBB V3 AP. JBR RMM. MD OCC. TRL8 w/CX RACING. JBR SHIFT WEIGHT. EVO X RIMS. MD PS COOLER. COBB SIR TIP. CORKSPORT RECIR. PURE tuned
2015 Mazda 3 - bone stock, Gen 1 speed3 rims in the front, Business in the back, 40MPG
"hold'n my dick!"
Mochi is offline   Reply With Quote
 Old 05-22-2013, 12:00 PM   #9
Do you have a build thread for your LAIC setup?
EDIT: Turns out there is a lot of great info here:
LTA Intercooler Concept Thread
In terms of space and efficiency they are great. However the pump is more prone to failure so it's something that has to be watched a little more carefully.
Alejo_NIN (05-22-2013), chuckms6 (05-22-2013)
 Old 05-22-2013, 03:06 PM   #10
chuckms6's Avatar
im using a bilge pump from walmart rated for 800gph. the more gph the better
yea, a lot of my info is in that thread. i wired my system so that my boost gauge illumination is my on indicator for my pump. cant see boost, pump aint working i have also used the bat flag table in my tune to cut load about like 160° so i feel like i have enough safeguards in place. ive had one pump failure in about two years daily driven.
 Old 05-22-2013, 06:54 PM   #11
kmac's Avatar
Posts: 1,792   (View Stats)
The more gph not always better. U can move too much fluid and not allow it to cool enough in the heat exchanger. Like if u remove your thermostat u can oveheat due to excessive flow.
First 500whp stock block mazdaspeed3 (503whp 423wtq)
<3 Tokay.
The Following 2 Users Say Thank You to kmac For This Useful Post:
Alejo_NIN (05-23-2013), spals (05-22-2013)
 Old 05-22-2013, 07:38 PM   #12
chuckms6's Avatar
I have had nothing but gains from adding gph, but I may not have reached a point of diminishing returns.
Tapatalk fucked me real good tonight...
Last edited by chuckms6; 05-22-2013 at 07:38 PM. Reason: MSF Database - Automerged Doublepost
kmac (05-23-2013)
 Old 05-23-2013, 04:45 PM   #13
Alejo_NIN's Avatar
Groans: 88
i think the key is on creating a system thwt will cool down water quicky wihtout much effort
as in positioning the radiator in a way that it gets direct, cold air.
a high efficiency, high flow fan, a good flowing radiator that will dissipate heat quickly and a mix of liquid that yields the most cooling while not being corrosive together with a good pump that can move the water quickly...i think the lenght the water has to take will allow to have MORE water while not having an overly large container and lots of aluminum tubbing to allow it to act as a dissipator as well, insulation from hot parts and to keep it away from heat sources as much as possible.
radonelement.com
 Old 08-05-2014, 02:13 AM   #14
inglouriousbasterd's Avatar
Posts: 111   (View Stats)
inglouriousbasterd has much to be proud ofinglouriousbasterd has much to be proud ofinglouriousbasterd has much to be proud ofinglouriousbasterd has much to be proud ofinglouriousbasterd has much to be proud ofinglouriousbasterd has much to be proud ofinglouriousbasterd has much to be proud ofinglouriousbasterd has much to be proud ofinglouriousbasterd has much to be proud of
Groaned at 6 Times in 3 Posts
image.jpg my setup heat soaks quickly if I'm at idle in traffic or autox hot laps. I'm gonna try a bigger ic,heat exchanger and switch to straight water with treatment. As of now my reservoir is shared with the coolant overflow.
When you decide to be something, you can be it. That's what they don't tell you in the church. When I was your age they would say we can become cops, or criminals. Today, what I'm saying to you is this: when you're facing a loaded gun, what's the difference?
inglouriousbasterd is offline   Reply With Quote
 Old 08-07-2014, 10:21 AM   #15
Neverlift's Avatar
Posts: 4,699   (View Stats)
Groans: 1,143
You necro'd this thread to post a shitty sideways picture taken with a potato? WTF brownie?
Past Mazdas & Speeds
aaronc7 (08-07-2014), Alejo_NIN (08-08-2014)
 Old 08-08-2014, 09:46 AM   #16
Alejo_NIN's Avatar
Groans: 88
now that he resurrected this, i opted to walk away
not becaus eof the dangers of having a leaking heat exchanger leak water into the intake, but because it takes too much effort to cool down the charge with all the plumbing for water, radiator, fans, etc.
just not worth it.
radonelement.com
Neverlift (08-08-2014)
 Old 11-14-2014, 03:59 AM   #17
Must be hard to turn your head from sucking all that dick.
The Following 2 Users Say NO Thank You to inglouriousbasterd For This Un-useful Post:
Neverlift (11-14-2014), rymanmazda (11-14-2014)
 Old 11-14-2014, 07:53 PM   #18
Neverlift's Avatar
Groans: 1,143
If you spent less time trying to be badass on the internet, and more time (like 15 secs) rotating your photos to ensure your post is both legible and presentable, we wouldn't be having a discussion about what I do when I am not on the internet reading bumped threads from nearly 2 years ago.
JRoc's 1990 Miata build jroc Miata - Track Cars and Racing 94 09-28-2014 06:38 PM
aaronc7's Turbo Miata Build aaronc7 Miata - Forced Induction 733 07-15-2014 09:55 PM
Miata BP Build Midnitehours Miata - Engine, Transmission, Driveline 18 06-11-2013 06:11 PM
NA Miata 1.8 Turbo Build. Big Question! Pintozoz Miata - Engine Conversions 0 04-15-2013 07:15 AM
Anyone else get water build up in trunk? SwineFLU Mazdaspeed3/6 General Discussion 4 04-28-2012 08:11 PM
Page generated in 0.38513 seconds with 28 queries
