Miata MX-5
> Miata - Forced Induction
 Old 07-21-2011, 09:59 AM   #1
clos561's Avatar
Posts: 1,172   (View Stats)
clos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the world
Default clos561 turbo miata
I used to frequent this forum (when i had a speed3) and some of you may remember me. I am close to finishing up my miata. A few weeks ago i did my intercooler pipes and currently waiting on a ebc solenoid from diyautotune then i can install all the parts i have in my room.
this will be my setup.
Stock 1.8 motor
artech log manifold w/ewg vta dump, 3inch exhaust
Emusa (ebay) t3 50 trim,
Emusa (ebay) EWG
MS2 built by brain running seq. fueling
460cc rx7 injectors
Meth/water injection
Vmaxx coil overs
FM sway bars
hard dog DD rollbar
this is my manifold and exhaust from artech
this is what i ended up with after cutting the pipes and test fitting. and no im not running internal and external wastegates.
7-Inch Jensen Flip Out Touch Screen, HKS SSQ, MS CAI, Prosport Premium Amber/White Boost Gauge,2nd Cat Gutted, Delrin TRZ MM,16 inch FD rims,TWM shifter Bushings,COBB Turbo Inlet, 28psi, rebuilt stock block, custom rods and piston heads/gaskets, underdrive pulleys, big cams, big oil filter, stage4 clutch, stage4 DISI injectors, Fuel Pump, 4inch Catless TBE with screamer pipe, external wastegate spring modification,Methanol direct twin port duty cycle injection. Tuned by Nator Performance
clos561 is offline   Reply With Quote
The Following 2 Users Say Thank You to clos561 For This Useful Post:
Dash08 (05-16-2012), Snotrocket (08-03-2011)
 Old 07-21-2011, 10:04 AM   #2
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
yay!!! another faggot!!!!
u were a mod and u are brown????? carlos i should fucken permaban your ass for the insolence
The Following 2 Users Say Thank You to rodrigo For This Useful Post:
kmac (08-03-2011), PunjabiPlaya (08-23-2011)
 Old 07-21-2011, 01:15 PM   #3
zpele's Avatar
Posts: 1,654   (View Stats)
zpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the world
Groans: 354
Groaned at 213 Times in 109 Posts
Looks good man that shit will haul. Too bad its gay!
2012 Shelby GT500 - Roush Axleback ~ JLT Oil Separator ~ JLT 123mm intake ~ Ngauge ~ Lund Tuned ~ smaller pulley ~ xpipe (loud as fuck now)
2007 Mazdaspeed6 (SOLD) - COBB SRI ~ Gutted Stock Midpipe ~ HKS BPV ~ JBR RMM ~ AWR PMM ~ AWR TMM ~ Juggernaught Rear Diff Mount ~ Dreadnaught Rear Diff Mount ~ ACT Stage 2 Clutch ~ ITV22s ~ AP(self fucking tuned in a week fuckers) ~ Autotech Internals ~ eBay Downpipe ~ Poke Sub thingy
zpele is offline   Reply With Quote
The Following User Says Thank You to zpele For This Useful Post:
kmac (08-03-2011)
 Old 07-21-2011, 06:34 PM   #4
Neverlift's Avatar
Posts: 4,699   (View Stats)
Groans: 1,143
I really love artechs work.
Past Mazdas & Speeds
 Old 07-22-2011, 12:26 AM   #5
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
wenis
 Old 08-03-2011, 12:31 AM   #6
Snotrocket's Avatar
Posts: 900   (View Stats)
any dynos?
2010 MS3 Black
395whp/386wtq
 Old 08-23-2011, 09:27 PM   #7
clos561's Avatar
finished everything almost. need to just tap my oil pan and cut a few pipes for the hot side and im done. also waiting on a hks snap ring and o ring i misplaced. no dynos yet as the car isnt running. i am expecting anywhere from 220-240 whp which i will be very happy with
 Old 08-23-2011, 09:56 PM   #8
Looks like its coming together. What do you think the dyno will show?
 Old 08-23-2011, 10:00 PM   #9
MazdaASM's Avatar
Posts: 491   (View Stats)
MazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the world
Groaned at 9 Times in 7 Posts
"finished everything almost. need to just tap my oil pan and cut a few pipes for the hot side and im done. also waiting on a hks snap ring and o ring i misplaced. no dynos yet as the car isnt running. i am expecting anywhere from 220-240 whp which i will be very happy with"
sorry could not resist
MazdaASM is offline   Reply With Quote
The Following User Says Thank You to MazdaASM For This Useful Post:
 Old 08-23-2011, 10:24 PM   #10
bigx5murf's Avatar
Posts: 235   (View Stats)
bigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond repute
Groaned at 20 Times in 10 Posts
I can never tell ricelands from fm v-maxx's in pix
bigx5murf is offline   Reply With Quote
 Old 08-24-2011, 07:48 PM   #11
Neverlift's Avatar
Groans: 1,143
Those are most definitely Vmaxx... ver. 2 I hope
I would look toward the higher end of your spectrum. Maybe even exceeding it slightly.
 Old 08-24-2011, 08:27 PM   #12
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
that has to be the worst ewg placement ever on a manifold haha.
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
 Old 08-24-2011, 08:48 PM   #13
It's log style and the 1.8 won't flow that much ... it will keep up just fine.
socks (08-25-2011)
 Old 09-06-2011, 10:55 PM   #14
clos561's Avatar
after getting a new battery and a vac line. my car is alive again. cant wait to drive it. i post some more videos once its on the road completely.
 Old 04-03-2012, 01:46 PM   #15
Roddiy's Avatar
Posts: 5,388   (View Stats)
Groans: 279
Are you not running an air intake filter on your turbo?
And just for the records:
Holy thread revival!
2010 LSM Speed3
#BakeryTuned
 Old 04-10-2012, 11:50 AM   #16
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
how's your china shit holding up?
 Old 05-08-2012, 05:31 PM   #17
clos561's Avatar
holding up good. Turbo still has zero shaft play, the wastegate doesnt have cracks or signs of failing anytime. all is good except the leaky pan i will fix when i pull motor.( and do reroute finally )
aaronc7 (05-08-2012), tddvrrn (05-08-2012)
 Old 05-08-2012, 09:08 PM   #18
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
did you ever dyno it?
 Old 05-16-2012, 06:44 PM   #19
clos561's Avatar
no i will hopefully dyno it by the end of the summer. i will start pulling my motor soon and i want to have my engine leak free before i dyno and pay for tune
 Old 05-16-2012, 06:51 PM   #20
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
Damn clos, you're older than I am on this site. Good to hear from ya. We don't see many of the OG's anymore.
Glad you're still in the game. Good luck with the build, man.
this forum serves 2 purposes
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f15/clos561-turbo-miata-86558/
How can I find a remote for an in dash car dvd player? This thread Pingback 07-21-2011 02:11 PM
Kilik2's turbo miata kilik2 Miata - Forced Induction 96 05-13-2013 01:59 AM
Page generated in 0.40975 seconds with 34 queries
