Miata MX-5
> Miata - Forced Induction
 Old 01-06-2009, 08:45 AM   #1
LateralSpeed's Avatar
Posts: 27   (View Stats)
LateralSpeed is just really niceLateralSpeed is just really niceLateralSpeed is just really niceLateralSpeed is just really niceLateralSpeed is just really nice
Default Installed new intake, now having boost problems
Ok, so I got the intake installed fine but now i'm having trouble setting the boost. I have the line going from the hot piping to the boost controller then the boost controller to the wastegate actuator(like in picture in instructions). I can set it all the way open or closed and it just stays at stock boost. Just out of desperation I tried putting the boost controller on backwards and if I unscrew it all the way it stays at stock but if I tighten it all the way it will spike up high(it went to 12 and was still going but I let off) then one click lower it went to 11 like I wanted then fell back down to 8.5 in 3rd then in 4th went close to 12 then dropped down to around under 7.
Just snapped a quick pic this morning.
I also installed it this way:
Installed as you see in the last pic I could hit whatever psi I want but it would drop back down to 9ish by redline just like before the intake.
For referrence stock boost is 8.5 and I was running 11 dropping to 8.5 with a cone filter. There are people holding 14psi on the same turbo and intake.
Help?
'04 VR Mazdaspeed Miata - '05 6MT RX8 Stock
FM Downpipe-running open downpipe | FM Intake | MBC 11psi | 27x7x2.5 FMIC | Falken Azeniz rt615 215/40/17 | Autometer boost gauge | Passport Escort 9500i | removed visors | Denso Recirc Valve | Supra Injectors waiting to be installed...
LateralSpeed is offline   Reply With Quote
 Old 01-06-2009, 12:04 PM   #2
Hmm... well I took it apart and there is no spring or ball in it...? Does that make it a bleeder type? Anyway, I know that the small blue T in the 3rd picture can have a spring and ball in it, it doesn't right now. I'll try putting them in, does anyone know where I can get a small short spring and ball that will fit in it?
 Old 07-12-2010, 07:14 PM   #3
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
reviving thread!
 Old 07-13-2010, 05:03 PM   #4
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
+1 nice wheels
DaleNixon (07-19-2010)
« - | Greetings... »
Intake and MM inserts installed - now a beliver vegas79 MazdaSpeed 3 - Engine, Transmission & Driveline 14 11-22-2008 12:33 PM
After the intake was installed Lex MazdaSpeed 3/6 - ECU Computer Tuning 8 09-20-2008 02:19 PM
My Review. CP-E intake installed the_caruch MazdaSpeed 3 - Engine, Transmission & Driveline 3 09-15-2008 09:23 AM
Boost drops FMIC intake temps? kingpin748 MazdaSpeed 3/6 - Turbo Induction 4 07-17-2008 08:57 AM
Page generated in 0.25698 seconds with 22 queries
