Miata MX-5
> Miata - Forced Induction
 Old 10-24-2011, 05:14 AM   #81
kilik2's Avatar
Posts: 1,254   (View Stats)
kilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the world
Groans: 127
Groaned at 40 Times in 31 Posts
coolant reroute, ss clutch line, and motor mounts
devils own meth kit
low profile headlights
hard dog hard core roll bar
kilik2 is offline   Reply With Quote
The Following User Says Thank You to kilik2 For This Useful Post:
aaronc7 (10-24-2011)
 Old 10-24-2011, 02:08 PM   #82
bigx5murf's Avatar
Posts: 235   (View Stats)
bigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond repute
Groaned at 20 Times in 10 Posts
riced out roll bar ftw!
bigx5murf is offline   Reply With Quote
The Following User Says Thank You to bigx5murf For This Useful Post:
TexasSpeed3 (10-25-2011)
 Old 10-25-2011, 08:39 PM   #83
kilik2's Avatar
Groans: 127
oh all of that shit is coming off, except for the zoom-zoom sticker.
 Old 10-25-2011, 09:48 PM   #84
InFeXIoN's Avatar
Posts: 1,159   (View Stats)
InFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the world
Groaned at 42 Times in 15 Posts
BP's arent that strong unless ya build them. Even with a motor from an MSM which has a forged crank but nothing else. When you started getting to the 260-270+ mark is terriotory for zoom zoom boom because the rods are weak.
GTX3071R EWG, DNP Tubular Manifold, SSP Ported/VTCS deleted intake manifold, DCR VVT Actuator, CP-E FMIC, Cobb AP, JBR 3.5" WP Intake ||| JBR 80 Duro RMM, JBR 80 Duro PSMM ||| CNT Racing Catless full 3" DP/TP, Speed Daddy 3" CBE ||| AEM Water/Methanol Kit, Autotech FP Internals, PTP Inj Seals, Synapse Engineering Bypass Valve, Matt Jackson map sensor harness, 3 Bar map sensor, Grimmspeed 3-port EBCS, NGK 1 Step Colder Plugs ||| Sure AGS 621G, Sure Shortcut, JBR Solid Base Bushings and Weight ||| AMR Engineering Coilovers, JBR Rear Sway, JBR Rear Camber Arms, XXR 527 18x8.75 +35 Chromium Black ||| CP-E Tow Plate, Rotella T6, FoMoCo XT-M5-QS, JBR OCC, JBR EGR Delete, JBR TB Gasket, JBR TIG and Coolant Bypass, EBC Redstuff.
Build Complete!!!!
InFeXIoN is offline   Reply With Quote
 Old 10-28-2011, 12:19 PM   #85
bigx5murf's Avatar
I think all 1.8s have a forged crank. The rods are the weak spot, but 250whp is already alot of power for most uses except drag racing. Even then, you'd want to deal with gearing issues first before adding even more power.
In the end, forged rods for BP are cheap, like $300 and change for either m-tuned or eagle rods. If you shop around, you can get a spare BP block for around that price, and build it at your leisure.
I still think fuel mgmt choice is more critical for making power in a mx5. There's no simple way out like a cobb ap.
 Old 10-28-2011, 03:30 PM   #86
InFeXIoN's Avatar
I think ur right bout the 1.8s having forged. Its the msms tranny I was thinking of maybe, it was beefed up compared to all the others. The gearing on the msm kinda sucks which is why a lot of people switch to 3.63 gearing.
Sent from my HTC Vision using Tapatalk
Build Complete!!!!
 Old 10-28-2011, 03:32 PM   #87
InFeXIoN's Avatar
As for ecu, nbs really only have xede pnp for msms and or nbs all together the hydra stand alone. For the nas they have megasquirt and I believe something else..
Build Complete!!!!
 Old 10-28-2011, 04:30 PM   #88
Neverlift's Avatar
Posts: 4,699   (View Stats)
Groans: 1,143
MSM trannies only have stronger synchro's and everyone who switches to a 3.63 is a moron if they have less then 250+ whp. 3.9 is the ticket on stock turbo. You will lose the incredible 4-6 highway roll acceleration that dropped jaws though.
Glad you are finally going to a 1.8 kilik. Have you decided on a BP05 or 4W? I am struggling with that decision now.
Past Mazdas & Speeds
 Old 10-28-2011, 05:51 PM   #89
kilik2's Avatar
Groans: 127
I am going with a bp 4dub loblaw, I like the idea of vvt.
 Old 10-28-2011, 06:15 PM   #90
Neverlift's Avatar
Groans: 1,143
The bpze has the vvt. Stick on the 4W head for 10.5:1 comp... pretty decent set up even na.
aaronc7 (10-28-2011), kilik2 (10-30-2011)
 Old 10-31-2011, 07:50 PM   #91
InFeXIoN's Avatar
The gears in the msm tranny were shot peened and somethin else I believe not just synchros to make it stronger. I also agree with you on the rearend gearing.
Build Complete!!!!
 Old 11-01-2011, 12:40 AM   #92
bigx5murf's Avatar
Yea, shot-peened gears to resist surface cracking. Not sure how much it actually helps, but I think only one documented case of a msm tranny blowing up, and the same guy blew up multiple 5speeds quickly.
I was considering 3.63 gears, but the price went up significantly, and add in labor, it'll be like $1200+ to reduce your acceleration across the band. I figured for autox, I'll only really need 2nd to hit 60mph, and a redline raise would get real close to that.
Megasquirts work well on msm, begi has done a few. The only guy who documented it was using a custom MS1, on a custom parallel harness. Quite a few ppl running MS2 on msm, but for some reason none of them post about it. Guess I'll be the first, maybe.
Adaptronics is another good option, cheaper than hydra, with good support from boundary engineering.
 Old 11-02-2011, 06:30 PM   #93
InFeXIoN's Avatar
Wow just checked resources for the gears (havent looked in sometime) your right thats crazy how much they want for the gears and speedo. i dont ever remember it being 629.00 was like around 400 or less. Yea i totally forgot about adaptronics, they were just gettin into stuff when i had my msm. i remember them working on their ecu and was showing it at sema, something in the law changed about emissions or something and had to scrap out a section of the ecu and change it. Alot of people were disappointed because it was a solution everyone was waiting for.
Build Complete!!!!
 Old 11-20-2011, 10:05 PM   #94
bigx5murf's Avatar
Yea, the 3.63 gears + speedo fix went up in price a few increments already, when I was ready to buy, they jumped to $500 and change, and then I decided I'd be happy with a redline raised.
Adaptronic never really took off for the msm, although I think they were finally able to get it to pass emissions after lots of troubleshooting. The price on their e420 wasn't bad at $1k, but when they upgraded to the 440, the price went up to like $1500. Only one msm in the states documented it, the guy's in seattle. Most of the other adaptronics users are from Australia (who have 3.63 gears stock). These things are technically a piggyback, since they still need to be hooked up to the stock ecu to work.
 Old 05-13-2013, 12:51 AM   #95
Manny's Avatar
Posts: 1,185   (View Stats)
Groans: 320
is this car still gay?
The Following User Says Thank You to Manny For This Useful Post:
Neverlift (05-13-2013)
 Old 05-13-2013, 01:50 AM   #96
TheFlash's Avatar
Posts: 2,095   (View Stats)
Fail
"Sent from behind Smelson"
I drive a Mazda
The Following User Says NO Thank You to TheFlash For This Un-useful Post:
 Old 05-13-2013, 01:59 AM   #97
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
bump lol
aaronc7's Turbo Miata Build aaronc7 Miata - Forced Induction 733 07-15-2014 09:55 PM
Page generated in 0.36912 seconds with 26 queries
