Miata MX-5
> Miata - Forced Induction
 Old 11-10-2010, 01:47 PM   #1
Neverlift's Avatar
Posts: 4,699   (View Stats)
Groans: 1,143
Default MSM Turbine / 16g Compressor
I asked this to miataturbo.net and did not receive a solid answer or even one attempt to answer this so I figured I would post this over here since I know there are some brilliant FI heads.
There are documented ways of using the TD05 turbine with the 16g compressor on an MSM motor.
I would like to know if there would be any benefits to using a 16g compressor with the stock IHI turbine, and if there would be anything I would need to look out for in doing so aside from rerouting of the IC piping.
If no one has the knowledge to pass on, I will just turn this into a DIY and post my findings.
Past Mazdas & Speeds
 Old 11-25-2010, 08:52 PM   #2
bigx5murf's Avatar
Posts: 235   (View Stats)
bigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond repute
Groaned at 20 Times in 10 Posts
I think Blouch turbo used to offer this service for MSM.
FM used to offer it as part of their big enchilada kit, but removed citing inconsistencies in resulting power gains.
bigx5murf is offline   Reply With Quote
 Old 11-27-2010, 04:39 PM   #3
Neverlift's Avatar
Groans: 1,143
Blouch does the TD05/16g
 Old 06-08-2011, 11:38 AM   #4
bigx5murf's Avatar
My new BNR trubo
we got a new option, might wanna check out BNR
 Old 06-09-2011, 05:57 PM   #5
Neverlift's Avatar
Groans: 1,143
Anyone know if or what backing plate would be needed to run the 16g comp w/ the IHI turbine?
 Old 06-09-2011, 06:02 PM   #6
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
1250?????
Get a garrett for cheaper....
 Old 03-26-2012, 09:35 AM   #7
inglouriousbasterd's Avatar
Posts: 111   (View Stats)
inglouriousbasterd has much to be proud ofinglouriousbasterd has much to be proud ofinglouriousbasterd has much to be proud ofinglouriousbasterd has much to be proud ofinglouriousbasterd has much to be proud ofinglouriousbasterd has much to be proud ofinglouriousbasterd has much to be proud ofinglouriousbasterd has much to be proud ofinglouriousbasterd has much to be proud of
Groaned at 6 Times in 3 Posts
1250?????
what the fuck happened ?i remember when 16g's were cheap as fuck around $600.00 but that was ten years ago and i was still into dsm's . I'd get the evo III for a little more with 45cfm more flow.
When you decide to be something, you can be it. That's what they don't tell you in the church. When I was your age they would say we can become cops, or criminals. Today, what I'm saying to you is this: when you're facing a loaded gun, what's the difference?
inglouriousbasterd is offline   Reply With Quote
 Old 06-09-2011, 09:44 PM   #8
bigx5murf's Avatar
He probably wants to keep stock manifold + dp
 Old 03-26-2012, 10:32 PM   #9
bigx5murf's Avatar
These aren't regular 16gs. They're 16gs somehow fitted to a stock msm turbo, there's machine work involved.
 Old 04-25-2014, 12:20 AM   #10
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
oh hai
CX-7 AC compressor fail thread bzwyatt CX-7 > Issues & Troubleshooting 30 07-15-2011 05:25 PM
Compressor surge v2 Dash08 MazdaSpeed 3/6 - Turbo Induction 6 05-31-2009 08:21 AM
Compressor surge babcockxmx MazdaSpeed 3/6 - Turbo Induction 25 05-17-2009 11:00 AM
compressor surge? k0m MazdaSpeed 3 - Engine, Transmission & Driveline 3 04-30-2009 10:21 AM
Page generated in 0.28952 seconds with 24 queries
