Miata MX-5
> Miata - Engine, Transmission, Driveline
 Old 04-12-2009, 11:06 PM   #1
black-speed3-gt's Avatar
Posts: 46   (View Stats)
black-speed3-gt will become famous soon enough
Default catted DP or cattless DP?
whats better a catted DP or a cattless DP and are there any problems i will incounter with having a cattless DP??? like over boosting and check engine lights???
black-speed3-gt is offline   Reply With Quote
 Old 04-12-2009, 11:22 PM   #2
aspiring turbo guru
08_ms3_gt's Avatar
Posts: 1,040   (View Stats)
you run the risk of both overboost and CEL's with a catless DP. catted DP's have the same risks but less so.
i can't think of many reasons why a catless DP is better, besides a slight cost decrease. the pressure drop across a high-flow cat is not significantly greater than straight pipe.
if you want to keep the emissions safe-ish, add a little protection against CEL's and overboost, and avoid giving headaches to driver's behind you (fumes..), get a catted DP.
08_ms3_gt is offline   Reply With Quote
CPE Catted downpipe SPL Ftaz1 Custom Performance Engineering (cp-e.com) 17 02-04-2010 08:17 AM
catted downpipe? tbone Mazdaspeed3/6 General Discussion 3 02-03-2009 04:00 PM
cp-e catted downpipe bova MazdaSpeed 6 - Engine, Transmission & Driveline 10 12-01-2008 11:16 PM
Page generated in 0.22314 seconds with 21 queries
