Miata MX-5
> Miata - Suspension & Brakes
 Old 02-10-2013, 12:03 PM   #1
turbo test's Avatar
Posts: 798   (View Stats)
turbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the world
Groaned at 9 Times in 5 Posts
Default Looking for a cheap...
Place to buy a quality suspension set up.
I can get tokico illuminas for $460 +tax but wanted to know if anyone knows of a cheaper price/place to buy.
I know this section is pretty dead but if anyone has some info let me know.
2010 Velocity Red MS3-Eibach PRO-KIT-EVO X Rims-SU RMM-SU solid shifter bushings-CP-e HPFP-CP-e tip-CP-e cai-CP-e hks ssqv bov kit-ddm slim hid kit 35w-5000k-JBR Heavy Shift Knob-JBR RSB-AQ Motorsports catted downpipe-Magnaflow full 3in CBE- SPC camber arms (Stratified tuning) 91/e85 tuned
turbo test is offline   Reply With Quote
 Old 02-10-2013, 12:11 PM   #2
lilred's Avatar
Posts: 5,792   (View Stats)
I feel like I always have to mention @Neverlift; when it comes to miatas
tapafuck
2010 velocity red mica ms3
AP/AT internals
JBR SSP/bushings
JBR RMM
JBR stage 2 OCC
CS test pipe
Neverlift (02-10-2013), turbo test (02-10-2013)
 Old 02-10-2013, 02:29 PM   #3
Neverlift's Avatar
Posts: 4,699   (View Stats)
Groans: 1,143
Bilstein shocks
Past Mazdas & Speeds
ms3rick (02-10-2013), turbo test (02-10-2013)
 Old 02-10-2013, 05:54 PM   #4
turbo test's Avatar
I know with the illuminas most people go with fm springs
Assuming I go bilsteins would they pair up well with lets say eibach springs?
Ugh! I hate the idea of spending 3/4ths the price I bought the car for on suspension, but I cant stand the 170k worn out stock suspension anymore
 Old 02-10-2013, 10:00 PM   #5
Neverlift's Avatar
Groans: 1,143
@turbo test; I would never spend money on Illuminas (twin tube ancient technology) or FM springs (progressive).
Also, the Eibach Pro Kit is a progressive spring. This creates a moving target for the actual spring rate. I would avoid that at all costs. I may have a set of R package springs still, I will double check. I ran OEM R package Bilsteins w/ R package springs and they were fucking awesome.
I recommend calling 949 and seeing what they recommend for a spring for the Bilsteins. I am not sure if the Tein race springs will fit, but they are considerably cheaper than FM/Eibach and can be ordered in any spring rate you desire... and 949 would be able to recommend the one best suited for OFS Bilstein HD's. I'd imagine 6/4k would be good.
 Old 02-11-2013, 10:41 AM   #6
turbo test's Avatar
Well thanks for the help, I'll have to call 949racing and see what they can put together for me without breaking the bank.
Neverlift; thanks for the input
*edit* tapatalk fail at mentioning him
 Old 03-17-2013, 06:13 PM   #7
bigx5murf's Avatar
Posts: 235   (View Stats)
bigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond repute
Groaned at 20 Times in 10 Posts
hasn't been updated in awhile, but should still be useful
https://docs.google.com/spreadsheet/...hl=en_US#gid=0
bigx5murf is offline   Reply With Quote
 Old 03-18-2013, 02:15 PM   #8
jamesr242's Avatar
Posts: 725   (View Stats)
jamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the world
I got the Flyin Miata (illumina's, springs and sways) setup this winter on my 2000 and I'm pretty pleased for the money so far. I didn't want something that was too stiff since I plan on taking road trips and the car is uncomfortable enough as is. The adjust-ability and lifetime warranty is a nice thing to have for the money. Yeah, it's not balls-to-the-wall best performance available but it's a nice sporty ride compared to stock. 12.5" ride height all around, BTW.
2011 MS3 - SOLD
2000 Miata LS, Flyin Miata Turbo'd (GT2560R), 3" TBE, Megasquirt EMS, 650cc injectors
jamesr242 is offline   Reply With Quote
 Old 03-26-2013, 12:24 AM   #9
bigx5murf's Avatar
Should probably lower the front a little, or raise the rear a bit, like 1/2". Reason being miatas need that rake to handle properly, even height all around is supposed to cause oversteer at the limit.
Also, measure height at pinch rails to ground is more accurate, takes tire pressure out of the equation.
 Old 03-26-2013, 08:04 AM   #10
jamesr242's Avatar
This is just the measurement I was given at the dealer when I got an alignment. I'm not really 100% sure it's correct. I believe the kit is actually supposed to be 13" rear, 12.5" front. I need to stop being lazy and get a real measurement. Also, I believe the proper way to measure is top of wheel well to hub center which is not dependent on tire pressure.
2011 MS3 - SOLD
cheap cbe karl-hungus MazdaSpeed 3/6 - Turbo Induction 19 01-18-2012 07:44 PM
Page generated in 0.29402 seconds with 24 queries
