Miata MX-5
> Miata - Suspension & Brakes
 Old 01-13-2011, 09:10 PM   #1
No_Coin's Avatar
Posts: 2   (View Stats)
No_Coin has a spectacular aura aboutNo_Coin has a spectacular aura aboutNo_Coin has a spectacular aura about
Default Vmaxx Coilovers Installed
I'm No_Coin, I had an intro thread a while ago but all that got deleted in the forum crash deal, I'm not gonna bother with it again. ANYWAYS, it's an '01 LS (6spd, Torsen LSD) with a couple bolt ons nothing big. Normally don't have shit worth of money to put in the Miata, but Christmas came around and I purchased some VMaxx Coilovers.
To give you some background if you havn't herad of em - you can get Vmaxx's from multiple vendors like Flyin' Miata and Stratmosphere. They were somewhere near 600 duckets, and are used for anything between Audi's, VW, Miatas, and some Civics I believe. They're a bang for your buck, they're a good for the street-not so much for the track-slam the shit out of your car- kind of coilover.
On with the pics, LMK if you want more, I'll prob be adjustin' them more sometime when I'm able to go outside without gettin' raped by my own dick.
Here's "Sellers", my roomate in college, balls deep in my wheel well.
Back's a bit higher than the front, about two fingers kinda where wanted it. Maybe a bit of a rake goin on? I'll probably lower it a bit more.
Front's slammed, can't go any more without rubbing a shit ton.
Due to some extreme corrosion, ignorance, and some stubborn a-arms, this install took a hell of alot longer than I anticipated, but looking back on it, had i looked into the install and not just assumed it would be a no brainer, it would have gone alot smoother. I shouldn't have relied on Sellers
It handles a hell of a lot better, more like a go-cart than ever, super tight, alot more solid. Considering my old suspension was past its prime, this was a major improvement for me. Stock blows at like 30,000 and I'm rounding the 65k marker.
So yeah! Lemme know what you think, comments, suggestions, and flames are all welcome.
No_Coin is offline   Reply With Quote
The Following 4 Users Say Thank You to No_Coin For This Useful Post:
aaronc7 (01-13-2011), conso (01-16-2011), phillyb (01-13-2011), sellers (01-14-2011)
 Old 01-13-2011, 09:34 PM   #2
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
looking good man, im in the process of looking for a miata for my DD and maybe a little late night drifting
860whp/677wtq
2.7 V6 Ecoboost
 Old 01-13-2011, 09:35 PM   #3
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
cheap miatas are alllll over the fucking place. grab one
 Old 01-13-2011, 09:48 PM   #4
PapaSmurf's Avatar
Once i get my CPe HPFP, DP and AP. Miata searching will be my main priority.
860whp/677wtq
2.7 V6 Ecoboost
 Old 01-14-2011, 01:02 AM   #5
sellers's Avatar
Posts: 1,280   (View Stats)
sellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the world
Groans: 546
Groaned at 125 Times in 71 Posts
Fuck that suspension niggah. Whoever engineered that shit can suck a dick.
sellers is offline   Reply With Quote
 Old 01-14-2011, 08:50 AM   #6
clos561's Avatar
Posts: 1,172   (View Stats)
clos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the world
i have the same suspension, works nicely
7-Inch Jensen Flip Out Touch Screen, HKS SSQ, MS CAI, Prosport Premium Amber/White Boost Gauge,2nd Cat Gutted, Delrin TRZ MM,16 inch FD rims,TWM shifter Bushings,COBB Turbo Inlet, 28psi, rebuilt stock block, custom rods and piston heads/gaskets, underdrive pulleys, big cams, big oil filter, stage4 clutch, stage4 DISI injectors, Fuel Pump, 4inch Catless TBE with screamer pipe, external wastegate spring modification,Methanol direct twin port duty cycle injection. Tuned by Nator Performance
clos561 is offline   Reply With Quote
 Old 01-14-2011, 12:12 PM   #7
Neverlift's Avatar
Posts: 4,699   (View Stats)
Groans: 1,143
The engineers did an awesome job, it is almost idiot proof... almost.
Nice car.
Miatas will be the next 240s so get em now before they go up further in price and get ragged out.
Past Mazdas & Speeds
BeyonceSpeed3 (03-25-2011)
 Old 01-14-2011, 12:26 PM   #8
sellers's Avatar
Groans: 546
Nice car.
I was referring to that upper a arm. Made everything a bitch
 Old 01-14-2011, 01:42 PM   #9
Neverlift's Avatar
Groans: 1,143
Was the nut on that bolt a bitch?
 Old 01-14-2011, 01:50 PM   #10
sellers's Avatar
Groans: 546
Everything nut and bolt was a bitch. 10 years of corrosion. Ugh.
 Old 01-14-2011, 02:39 PM   #11
Fagwagon's Avatar
Posts: 2,090   (View Stats)
Groans: 75
i think miata is going to be my next play toy.
 Old 01-14-2011, 05:40 PM   #12
Amazon's Avatar
Posts: 2,679   (View Stats)
Amazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the world
Groans: 214
Groaned at 114 Times in 83 Posts
Originally Posted by Fagwagon View Post
i think miata is going to be my next gay toy.
fixed
Amazon is offline   Reply With Quote
The Following User Says Thank You to Amazon For This Useful Post:
PapaSmurf (01-14-2011)
 Old 01-14-2011, 09:27 PM   #13
PapaSmurf's Avatar
Originally Posted by Amazon View Post
fixed
bahahhaha
860whp/677wtq
2.7 V6 Ecoboost
 Old 02-16-2011, 08:32 AM   #14
hamsterman's Avatar
Posts: 50   (View Stats)
hamsterman is a jewel in the roughhamsterman is a jewel in the roughhamsterman is a jewel in the roughhamsterman is a jewel in the rough
looks nice
hamsterman is offline   Reply With Quote
 Old 03-25-2011, 12:57 PM   #15
BeyonceSpeed3's Avatar
Posts: 282   (View Stats)
BeyonceSpeed3 has a reputation beyond reputeBeyonceSpeed3 has a reputation beyond reputeBeyonceSpeed3 has a reputation beyond reputeBeyonceSpeed3 has a reputation beyond reputeBeyonceSpeed3 has a reputation beyond reputeBeyonceSpeed3 has a reputation beyond reputeBeyonceSpeed3 has a reputation beyond reputeBeyonceSpeed3 has a reputation beyond reputeBeyonceSpeed3 has a reputation beyond reputeBeyonceSpeed3 has a reputation beyond reputeBeyonceSpeed3 has a reputation beyond repute
please tell me youre going to change the wheels.....and go lower. just my opinion though lol
im excited for these vmaxx's/FM coilovers. might have to grab a set for my miata.
2010 Mazdaspeed3 - BC Coilovers - UR CBE & TP - CS SRI/TIP - JBarone SSP - TWM Full Replacement Shifter - SURE Wiper Delete - Cobb AP
BeyonceSpeed3 is offline   Reply With Quote
 Old 03-29-2011, 07:25 PM   #16
mighty mouse's Avatar
Posts: 62   (View Stats)
mighty mouse is a jewel in the roughmighty mouse is a jewel in the roughmighty mouse is a jewel in the rough
lower that thing and get some smaller wheels!
mighty mouse is offline   Reply With Quote
 Old 03-30-2011, 10:44 PM   #17
No_Coin's Avatar
It's liteally as low as i can go in the front without rubbing hella. I've already had to raise it a bit from when this picture was taken. I've lowered the back about a quarter of an inch. It could maybe go a bit lower, and i might do that.
but yeah i agree, I'm not a huge fan of my wheels either. I got them as soon as i got the car when i had just turned 16 (almost 5 yrs ago) and i was like "BIG RIMZ R BETTAR" and i've been stuck with them since. It's on the list of to do's.
Aaron I searched for that hardtop on and off over the course of like 4 years. It was by complete luck/chance that I found that within driving distance for 700 bucks in great condition. I'm never lettin go of it
 Old 03-29-2011, 09:58 PM   #18
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
how much for your hardtop nig?
CB pics with coilovers installed bykeryder4life Appearance - COSMIC BLUE 62 07-02-2010 02:58 PM
H&R Coilovers installed... possible issue TriO MazdaSpeed 3/6 - Suspension & Brakes 36 06-11-2010 10:35 PM
H&R coilovers & Tri-Point RSB installed w/ Pix MGM_GT3 MazdaSpeed 3/6 - Suspension & Brakes 18 04-07-2010 10:56 PM
BC Coilovers and WhiteLine Sway installed y2kc0wb0y MazdaSpeed 3/6 - Suspension & Brakes 5 10-13-2008 07:52 AM
Page generated in 0.37863 seconds with 31 queries
