> MazdaSpeed 3/6 - Appearance
 Old 09-28-2016, 05:53 PM   #1
wes3id's Avatar
Posts: 611   (View Stats)
wes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the world
Neutral  +1 score
Default Interior led mod
I did this mod a few years ago and recently had somebody ask about doing theirs. Figured i would see if there was any interest in getting this done? I changed almost all the led's in my speed 6 to blue. here is a list of what i changed/modified
gauge cluster
stereo and climate control
climate control/stereo LCD
steering wheel buttons
door/window buttons
TCS/headlight level/ gauge brightness
Led's used are PLCC2 type (very bright) available in many different colors.
This task requires de-soldering the stock led's from the factory components, and soldering the new ones in. They are very small, i have included a picture for size reference.
07 SPEED 6 W/ GEN PU MOTOR SWAP/BNR S3/ K27 OIL FEED LINE/CUSTOM OIL DRAIN LINE/COBB INJECTOR SEALS/COBB XLE/CX RACING FMIC/CORKSPORT POWER SERIES 3" EXHAUST (CATLESS)/M2 3" DOWNPIPE (CATLESS)/COBB AP V3/GRIMMSPEED EBCS/JBR 3.5" WIDE PATH INTAKE/XS POWER V3 TURBO MANIFOLD/PNP INTAKE MANIFOLD/AUTOTECH INTERNALS/3 BAR MAP SENSOR/VTCS DELETE/KOZMIC MOTORSPORTS EGR DELETE/JBR BSD & BAFFLE TRAY/JBR OCC/NGK PLUGS/SURE TORQUE R6 RMM/AWR TRANSMISSION & PASSENGER MOUNTS/SURE JUGGERNAUGHT REAR DIFF MOUNT/CORKSPORT REAR DIFF MOUNT/FIDANZA FLYWHEEL W/ LUK CLUTCH/TWM SHORT SHIFTER/SURE COUNTER SHIFT/SURE SHORTCUT/H&R LOWERING SPRINGS/KONI YELLOWS/ WHITELINE RSB/ AWR END LINKS FRONT&REAR/ CORKSPORT FRONT & REAR STRUT BARS/SPC FRONT CAMBER BALL JOINTS/BRAIDED STEEL BRAKE & CLUTCH LINES/FIBER IMAGES VENTED HOOD/CORKSPORT FRONT PLATE RELOCATE/PC VALVE COVER/TRUNK MOUNTED RED TOP/INTERIOR MODS
K04 93 FREEKTUNED 271 AWHP/296TQ
K04 E85 FREEKTUNED 309 AWHP/360TQ
BNR S3 93 FREEKTUNED 336 AWHP/360TQ
BNR S3 E85 FREEKTUNED 375 AWHP/376TQ
wes3id is offline   Reply With Quote
 Old 09-28-2016, 06:21 PM   #2
Looks cool.
But blue light hurts your night vision more than any other light.
sent from my Nexus 6P
KiwiFlavor (03-10-2017), Vansquish (11-06-2016)
 Old 09-28-2016, 06:48 PM   #3
Jmc
Jmc's Avatar
Posts: 7   (View Stats)
Jmc will become famous soon enoughJmc will become famous soon enough
I also did this a few years ago on my 3i. I haven't tackled it on my ms6 yet simply because i find it's a pain trying to cleanly de-solder and rework as you approach the 0805 and smaller smd components.
Jmc is offline   Reply With Quote
 Old 09-28-2016, 07:33 PM   #4
wes3id's Avatar
It definitely takes some skill, steady hands, and patience. As for night vision..don't know about the ms3, but the ms6 has that nifty little switch to dim or brighten the gauges and head unit. Blue is just what I chose to do mine in, but others can choose whatever they like (red,green,blue,orange,white,etc) or a combination if they please.
 Old 11-06-2016, 08:05 AM   #5
joshuajcrouch's Avatar
Posts: 61   (View Stats)
joshuajcrouch has a spectacular aura aboutjoshuajcrouch has a spectacular aura aboutjoshuajcrouch has a spectacular aura about
Wow nice job!
joshuajcrouch is offline   Reply With Quote
 Old 03-10-2017, 08:43 AM   #6
galaxyspeed's Avatar
Posts: 17   (View Stats)
galaxyspeed has a little shameless behaviour in the past
Cool!
galaxyspeed is offline   Reply With Quote
ms6 interior andrew22888 Mazdaspeed3/6 General Discussion 2 04-13-2015 09:42 PM
New Interior RedBliss Interior 53 03-22-2012 09:39 PM
Interior LED's howdy2k2000 Interior 5 03-18-2010 03:29 PM
Interior LED help AmillieMS6 Mazdaspeed3/6 General Discussion 21 06-13-2009 09:09 AM
Page generated in 0.25490 seconds with 25 queries
