| MazdaSpeed 3/6 - Appearance MazdaSpeed 3/6 - Appearance - Show off pics of your ride, including after market body enhancements! |
![]() Join Date: Feb 2016 Location: Tyler, TX
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Would probably put it in the same location Just wondering how everyone else has theirs mounted so i can see what i would like lol If there is a thread already like this i apologize... ( I did a search and didnt find anything)
__________________ 2006 Mazdaspeed 6: BNR S3, COBB AP V3, CP-E TMIC, AUTOTECH HPFP, EGR DELETE, 3" HTP INTAKE, 3" CATLESS DOWNPIPE, JBR EBCS and RETROFITTED HEADLIGHTS |
| The Following User Says NO Thank You to MS6-Kyle For This Un-useful Post: | Vansquish (02-07-2016) |
![]() Join Date: Mar 2014 Location: Durham, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
| Not Ranked : 0 score I use a windshield mount on the bottom left hand side of my windshield, route the OBD2 cable up along the steering column to that side. I have a zip tie stopper for the cable so I can even close the little cubby on it without the wire dangling everywhere. I just use my phone mount and change out the backing plate.
__________________ 2006 Super Clean BCM MS6 Corksport Intake/TIP - Test Pipe - CS FMIC - Freektune - Autotech HPFP - 18x8 Wheels with Nitto NT05's 235/40/18 - H&R Coilovers - SPC Balljoints - CS RMM - Magnaflow CBE - DM Power Steering Cooler - CAR LED Tails - EBC Yellowstuff w/ Centric Blanks - Xcarlink w/ Bluetooth Module Waiting to be installed: Diff Braces - TMM Insert |
__________________ 2006 Mazdaspeed 6: BNR S3, COBB AP V3, CP-E TMIC, AUTOTECH HPFP, EGR DELETE, 3" HTP INTAKE, 3" CATLESS DOWNPIPE, JBR EBCS and RETROFITTED HEADLIGHTS | |
| Not Ranked : 0 score There are countless posts here about AP mount options... Here's one I did with stuff already in the garage, but the aluminum & velcro are easily found
__________________ Was a Mazdaspeed6 GT #3476 TiGray slicktop Now in a BMW 135i - double the turbos, double the fun! E82.N54 2009 / BSM / A/T / Drop-in / PR CP / Berk Street / MHD / xHP 340hp / 371tq | |
![]() Join Date: Apr 2009 Location: Wooster, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 210
| Not Ranked : 0 score i use the windshield mount for my accessport now, so i don't have to look down. the original jbr mount i've had for years, i use for my ipod.
__________________ 07 SPEED 6 W/ GEN PU MOTOR SWAP/BNR S3/ K27 OIL FEED LINE/CUSTOM OIL DRAIN LINE/COBB INJECTOR SEALS/COBB XLE/CX RACING FMIC/CORKSPORT POWER SERIES 3" EXHAUST (CATLESS)/M2 3" DOWNPIPE (CATLESS)/COBB AP V3/GRIMMSPEED EBCS/JBR 3.5" WIDE PATH INTAKE/XS POWER V3 TURBO MANIFOLD/PNP INTAKE MANIFOLD/AUTOTECH INTERNALS/3 BAR MAP SENSOR/VTCS DELETE/KOZMIC MOTORSPORTS EGR DELETE/JBR BSD & BAFFLE TRAY/JBR OCC/NGK PLUGS/SURE TORQUE R6 RMM/AWR TRANSMISSION & PASSENGER MOUNTS/SURE JUGGERNAUGHT REAR DIFF MOUNT/CORKSPORT REAR DIFF MOUNT/FIDANZA FLYWHEEL W/ LUK CLUTCH/TWM SHORT SHIFTER/SURE COUNTER SHIFT/SURE SHORTCUT/H&R LOWERING SPRINGS/KONI YELLOWS/ WHITELINE RSB/ AWR END LINKS FRONT&REAR/ CORKSPORT FRONT & REAR STRUT BARS/SPC FRONT CAMBER BALL JOINTS/BRAIDED STEEL BRAKE & CLUTCH LINES/FIBER IMAGES VENTED HOOD/CORKSPORT FRONT PLATE RELOCATE/PC VALVE COVER/TRUNK MOUNTED RED TOP/INTERIOR MODS K04 93 FREEKTUNED 271 AWHP/296TQ K04 E85 FREEKTUNED 309 AWHP/360TQ BNR S3 93 FREEKTUNED 336 AWHP/360TQ BNR S3 E85 FREEKTUNED 375 AWHP/376TQ |
![]() Join Date: Mar 2015 Location: JBA, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11
| Not Ranked : 0 score I just mounted mine on the flat part of the center under the vents. Works fine. FB_IMG_1454876385995.jpg
__________________ 2006 Mazdaspeed 6 GT - Whitewater Pearl Mica Cobb XLE bpv // HTP 3.5" WP Intake // BNR S4 // Corksport TMIC // Doc Race Manifold // Cobb 3 port EBCS // Bosch 3-Bar // Corksport internals // CPE catted 3" dp // CPE dual exit CBE w/o resonator // Denso ITV22's // Cobb AP v3 // Stoptech Slotteds // EBC Red Stuffs 333 awhp // 343 awtq so far @ 20 psi More to come... Freektune loading . . . . |
(Thread Starter) | Not Ranked : 0 score So many options.. this is gonna be a tough choice
![]() Join Date: Apr 2015 Location: Mcguire AFB, NJ
Rep Power: 0 ![]() ![]() ![]() Thanks: 2
| Neutral : +1 score My cord is ran behind the dash so I have nothing exposed. Even if the accessport is out theres is 6" of cord that sticks out
__________________ 2007 Mazdaspeed6 http://www.mazdaspeedforum.org/forum/forum/f415/42boxer-2007-mazdaspeed-6-a-191641/#post2929172 2008 Mazda 3: sold 2000 Toyota Tacoma: sold |
![]() Join Date: Jan 2013 Location: Perkinsville, VT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 367
| Not Ranked : 0 score used the mount that came with the ap and just drilled a couple holes into the console and used a couple nuts and bolts
__________________ MOD LIST UNDER CONSTRUCTION |
![]() Join Date: Sep 2014 Location: SoCal
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
| Not Ranked : 0 score This is the best Accessport mount. It's magnetic and you can just slap your Accessport onto it. Doubles as a cell phone holder. |
| CX7 owners location | Fingerlicker | CX-7 > General Lounge + New Member Welcome | 4 | 11-09-2015 10:55 AM |
| EQ location? | chry_spd | MazdaSpeed 3/6 - Car Audio & Electronics | 0 | 01-09-2013 10:43 AM |
| location | joewarner | CorkSport | 3 | 10-24-2012 05:39 PM |
| Nozzle tap location | nynhex | 2010 MS3 - Fuel, Nitrous & Water Injection | 9 | 06-13-2010 08:59 AM |
| Nozzle Location | superskaterxes | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 19 | 01-08-2009 02:25 PM |
