| MazdaSpeed 3/6 - Appearance MazdaSpeed 3/6 - Appearance - Show off pics of your ride, including after market body enhancements! |
![]() Join Date: Nov 2010 Location: Hoffman Estates IL
Groaned at 7 Times in 2 Posts
(Thread Starter) | Not Ranked : 0 score Has anyone painted their fog covers and exhaust shrouds gloss black instead of the dull look? Wondering if anyone can post pictures if they have.
__________________ 2006 ms6 titanium grey - sold 2006 ms6 liquid platnium - Sold Tmic, Intake, Inlet pipe, Test Pipe, BPV, H.I.D. Fogs, Cobb Ap 2006 ms6 velocity red mica - daily driver 2005 c6 corvette black - daily driver |
![]() Join Date: Apr 2009 Location: Wooster, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 210
| Not Ranked : 0 score i have mine painted gloss black. these are old pics but the paints holding up great. i'd take some better ones for you, but it's raining and the car is dirty.
__________________ 07 SPEED 6 W/ GEN PU MOTOR SWAP/BNR S3/ K27 OIL FEED LINE/CUSTOM OIL DRAIN LINE/COBB INJECTOR SEALS/COBB XLE/CX RACING FMIC/CORKSPORT POWER SERIES 3" EXHAUST (CATLESS)/M2 3" DOWNPIPE (CATLESS)/COBB AP V3/GRIMMSPEED EBCS/JBR 3.5" WIDE PATH INTAKE/XS POWER V3 TURBO MANIFOLD/PNP INTAKE MANIFOLD/AUTOTECH INTERNALS/3 BAR MAP SENSOR/VTCS DELETE/KOZMIC MOTORSPORTS EGR DELETE/JBR BSD & BAFFLE TRAY/JBR OCC/NGK PLUGS/SURE TORQUE R6 RMM/AWR TRANSMISSION & PASSENGER MOUNTS/SURE JUGGERNAUGHT REAR DIFF MOUNT/CORKSPORT REAR DIFF MOUNT/FIDANZA FLYWHEEL W/ LUK CLUTCH/TWM SHORT SHIFTER/SURE COUNTER SHIFT/SURE SHORTCUT/H&R LOWERING SPRINGS/KONI YELLOWS/ WHITELINE RSB/ AWR END LINKS FRONT&REAR/ CORKSPORT FRONT & REAR STRUT BARS/SPC FRONT CAMBER BALL JOINTS/BRAIDED STEEL BRAKE & CLUTCH LINES/FIBER IMAGES VENTED HOOD/CORKSPORT FRONT PLATE RELOCATE/PC VALVE COVER/TRUNK MOUNTED RED TOP/INTERIOR MODS K04 93 FREEKTUNED 271 AWHP/296TQ K04 E85 FREEKTUNED 309 AWHP/360TQ BNR S3 93 FREEKTUNED 336 AWHP/360TQ BNR S3 E85 FREEKTUNED 375 AWHP/376TQ |
(Thread Starter) | Not Ranked : 0 score if you get a chance to take some better photos can you post em?
| Not Ranked : 0 score ok, i wiped them down a little but its still dirty. painting was done several years ago
![]() Join Date: Feb 2016 Location: Blythe, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
| Not Ranked : 0 score Looks good, I like the gloss look. What hood is that?
__________________ 2007 MS6 FMIC, Garrett turbo, 3" Magna Flow TBE, 4" Intake, HP Fuel pump, COBB AP V3 |
| Not Ranked : 0 score fiber images
![]() Join Date: Feb 2009 Location: Tampa, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 503
| Not Ranked : 0 score Hey Wes I've been reading about exhaust shroud burning, seen every parted MS6 being scavenged immediately for the shroud. question, Do I need to concern myself with this issue at all, is a problem ever with stock exhaust? or just with the various catbacks second does that hood run in conjunction with the OEM scoop, or replace it. if latter, where is the grill scoop directed. if former, how well do the underhood OEM components fit the FI hood ? 3rddo you feel your 6 is less stealthy with the top scooped hood? I was in 3ID for almost 3 weeks, just long enough to drive the korean's in the alteration shop nuts. When 3AD cased colors, we went to 3ID, then crazy8's (a month) then 1AD this when the infantry commands figured out there is nowhere on the TO&E for a fucking combat aviation brigade in an infantry unit hehe much sewing of patches was done.......
__________________ A democracy, in its purest form, is well represented by a group consisting of 2 wolves and 1 rabbit. Voting on what to have for lunch |
The hood has its own built in tmic shroud scoop. i cant really remember where the grill air diverter will divert the air after install, but either way (engine bay or intercooler) is a win. oem components fit fine with the hood, no issues i noticed. I loved 3ID, best Division out of my career in the Army
__________________ 07 SPEED 6 W/ GEN PU MOTOR SWAP/BNR S3/ K27 OIL FEED LINE/CUSTOM OIL DRAIN LINE/COBB INJECTOR SEALS/COBB XLE/CX RACING FMIC/CORKSPORT POWER SERIES 3" EXHAUST (CATLESS)/M2 3" DOWNPIPE (CATLESS)/COBB AP V3/GRIMMSPEED EBCS/JBR 3.5" WIDE PATH INTAKE/XS POWER V3 TURBO MANIFOLD/PNP INTAKE MANIFOLD/AUTOTECH INTERNALS/3 BAR MAP SENSOR/VTCS DELETE/KOZMIC MOTORSPORTS EGR DELETE/JBR BSD & BAFFLE TRAY/JBR OCC/NGK PLUGS/SURE TORQUE R6 RMM/AWR TRANSMISSION & PASSENGER MOUNTS/SURE JUGGERNAUGHT REAR DIFF MOUNT/CORKSPORT REAR DIFF MOUNT/FIDANZA FLYWHEEL W/ LUK CLUTCH/TWM SHORT SHIFTER/SURE COUNTER SHIFT/SURE SHORTCUT/H&R LOWERING SPRINGS/KONI YELLOWS/ WHITELINE RSB/ AWR END LINKS FRONT&REAR/ CORKSPORT FRONT & REAR STRUT BARS/SPC FRONT CAMBER BALL JOINTS/BRAIDED STEEL BRAKE & CLUTCH LINES/FIBER IMAGES VENTED HOOD/CORKSPORT FRONT PLATE RELOCATE/PC VALVE COVER/TRUNK MOUNTED RED TOP/INTERIOR MODS K04 93 FREEKTUNED 271 AWHP/296TQ K04 E85 FREEKTUNED 309 AWHP/360TQ BNR S3 93 FREEKTUNED 336 AWHP/360TQ BNR S3 E85 FREEKTUNED 375 AWHP/376TQ | |
(Thread Starter) | Not Ranked : 0 score that looks pretty badass
| The Following User Says Thank You to Highestrich4 For This Useful Post: | wes3id (05-02-2016) |
| Engine bay pics.... i.e painted valve covers, sick installs, wiretucks, lets see what you got | drummermike58 | 2010 MS3 - Engine, Transmission & Driveline | 2 | 10-17-2012 03:03 PM |
