> MazdaSpeed 3/6 - Appearance
 Old 02-04-2016, 02:16 PM   #1
wes3id's Avatar
Posts: 611   (View Stats)
wes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the world
Default Venting bumper for better cooling
I decided to do some cutting on my foglight panels to get better cooling to the power steering cooler as well as FMIC pipes once i get this damn cxracing core raised up where it should be. not finished with the cutting but just a rough idea. i think it will actually look pretty good...wouldn't really be able to tell unless you look hard. I just used a dremel to cut out the lattice area and the backing on the bumper. not finished yet, but what do you guys think?
07 SPEED 6 W/ GEN PU MOTOR SWAP/BNR S3/ K27 OIL FEED LINE/CUSTOM OIL DRAIN LINE/COBB INJECTOR SEALS/COBB XLE/CX RACING FMIC/CORKSPORT POWER SERIES 3" EXHAUST (CATLESS)/M2 3" DOWNPIPE (CATLESS)/COBB AP V3/GRIMMSPEED EBCS/JBR 3.5" WIDE PATH INTAKE/XS POWER V3 TURBO MANIFOLD/PNP INTAKE MANIFOLD/AUTOTECH INTERNALS/3 BAR MAP SENSOR/VTCS DELETE/KOZMIC MOTORSPORTS EGR DELETE/JBR BSD & BAFFLE TRAY/JBR OCC/NGK PLUGS/SURE TORQUE R6 RMM/AWR TRANSMISSION & PASSENGER MOUNTS/SURE JUGGERNAUGHT REAR DIFF MOUNT/CORKSPORT REAR DIFF MOUNT/FIDANZA FLYWHEEL W/ LUK CLUTCH/TWM SHORT SHIFTER/SURE COUNTER SHIFT/SURE SHORTCUT/H&R LOWERING SPRINGS/KONI YELLOWS/ WHITELINE RSB/ AWR END LINKS FRONT&REAR/ CORKSPORT FRONT & REAR STRUT BARS/SPC FRONT CAMBER BALL JOINTS/BRAIDED STEEL BRAKE & CLUTCH LINES/FIBER IMAGES VENTED HOOD/CORKSPORT FRONT PLATE RELOCATE/PC VALVE COVER/TRUNK MOUNTED RED TOP/INTERIOR MODS
K04 93 FREEKTUNED 271 AWHP/296TQ
K04 E85 FREEKTUNED 309 AWHP/360TQ
BNR S3 93 FREEKTUNED 336 AWHP/360TQ
BNR S3 E85 FREEKTUNED 375 AWHP/376TQ
wes3id is offline   Reply With Quote
 Old 02-04-2016, 02:57 PM   #2
Having the OEM front air dam in place probably does more for cooling and airflow than this will. It could be a good option for brake ducts. I think to make much use of any airflow, you'd have to direct it towards the PS cooler in some way.
BPV not venting properly broseph09 MazdaSpeed 3/6 - Turbo Induction 13 11-23-2014 07:45 PM
hood venting mason Mazdaspeed3/6 General Discussion 90 02-18-2014 06:18 AM
fucking venting bbjoy Mazdaspeed3/6 General Discussion 19 02-11-2011 11:20 AM
Page generated in 0.23409 seconds with 22 queries
