Autosports Area
> Drag Racing
Like Tree159Likes
 Old 08-19-2015, 09:57 PM   #81
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
Guys it's because he's French, he comes off like...well like he's French.
I'm sure it's the language barrier.
Tappin
Easter Bunny (08-20-2015), mazdafreak (08-19-2015), Tomas (08-21-2015)
 Old 08-19-2015, 09:59 PM   #82
zjnspeed3's Avatar
Posts: 1,436   (View Stats)
You better be careful... Next thing you know, he is holding you down on a pool table threatening to break your arm unless you say the phrase, 'I love crèpes.'
mazdafreak likes this.
The Following 11 Users Say Thank You to zjnspeed3 For This Useful Post:
802MS3 (08-21-2015), chaser27 (08-20-2015), Dralphy (08-20-2015), Easter Bunny (08-20-2015), GARRETHEXTREME (08-20-2015), mazdafreak (08-19-2015), MS3Shadow (08-20-2015), predapio (08-20-2015), taf0422 (08-20-2015), Tomas (08-21-2015), TRBLSM (08-20-2015)
 Old 08-20-2015, 12:24 AM   #83
RE-ACTIONENGSPEED3's Avatar
Posts: 401   (View Stats)
In my opinion you have to strech the 1st gear till 8000rpm and maybe hit for 1 or 2 times the revlimiter (even you hit the limiter while spining the car up`s his mp/h) then switch to 2nd gear and make what you did last time with 3-4 more psi for 3rd and 4th ....
I wish the best .....
2008 speed3
True red.
Pte 6466 & AWD Mode on !!!!
The Following 4 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post:
chaser27 (08-20-2015), Easter Bunny (08-20-2015), Justin@Freektune (08-20-2015), Tomas (08-21-2015)
 Old 08-20-2015, 03:44 AM   #84
mrdouble99's Avatar
Posts: 256   (View Stats)
mrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the world
Well why don't you tell him sweetheart? I am sure the anticipation to know from you what slick pressure he should run is killing him.
i'm not trying to be a smartass, but i saw so many people putting random pressure in their slick to see if it work.
you don't have to do this every time since at one point you will know the clossest pressure needed.
let's say you never did a round with slick, so you don't know how they act on this strip.
you put 20psi and you do a pass to heat the tire properly, after that you lower the pressure by 1 psi after each run until you're Mph drop, as soon as you're mph drop you put back 1 psi and you're slick pressure should be optimal.
If everytime you're around 13psi before loosing mph, then you know next time you go to the track you don't have to start at 20psi.
Maybe you already knew that, but in case you didn't, now you know.
Mazdaspeed3 - sold
- Engine: Cobb AccesPort - Sure Full3 Aeros ID300 - Autotech internal - CP-e 3" cated Downpipe - CP-e xflex RMM 75A - Street: H&R spring - Koni Yellow - SPC camber kit - Team Dynamic Pro Race 1.2 18X8 et50 - BFgoodrich Gefroce KDW2 235/40R18
- Drag : 16x8 et50 FD wheel - Hoosier Quick Time Pro D.O.T. 26x9.5x16 -
- 2010 drag time : 12.737@108.51mph - 259whp@280wtq
- 2013 drag time : 12.432@111.02mph - 28?whp@3??wtq
2014 Black Mazda 6 GT MT
- Corksport Lowering Spring - Corksport LED fog Light Kit - Corksport LED Interior Light Kit - Corksport Shifter bushing
- RX8 R3 19x8 et47 wheels - Michelin PSS 245/40ZR19
- 3M Gloss Black Chrome Wrap
- Autoexe Shifter Knob
mrdouble99 is offline   Reply With Quote
The Following 4 Users Say Thank You to mrdouble99 For This Useful Post:
802MS3 (08-21-2015), chaser27 (08-20-2015), Jeremy M (08-21-2015), Tomas (08-21-2015)
 Old 08-20-2015, 09:05 AM   #85
Realgib3's Avatar
Posts: 2,443   (View Stats)
Lol at starting your slick pressure at 20psi.
Never above 10psi on those slicks. I would recommend going for around 8 personally. A little below that even may help, but without beadlocks (can't remember if you had a beadlock on the new setup?) I wouldn't go much lower that 8psi.
You don't have to worry about your trap going down, since you can't trap any higher in 4th anyway, so the short track is where you can drop a couple 10th's off the ET with the same trap. I know this is all shit you know, I just had to laugh at the guy up here saying to start your slick pressure at 20lbs.
 Old 08-20-2015, 09:10 AM   #86
daafisch's Avatar
Posts: 3,553   (View Stats)
Groans: 58
The guy was just giving an example of how to tune tire pressures.
mrdouble99 (08-20-2015)
 Old 08-20-2015, 09:12 AM   #87
Realgib3's Avatar
On a rwd muscle car maybe. On a FWD turbo car, you lower till you have traction or it's unsafe to lower it anything farther. Again, mph could not matter less in an application like this.
The Following 2 Users Say Thank You to Realgib3 For This Useful Post:
mazdafreak (08-21-2015), Putin 2.3T (08-20-2015)
 Old 08-20-2015, 09:39 AM   #88
cam0070's Avatar
Posts: 66   (View Stats)
cam0070 has a brilliant futurecam0070 has a brilliant futurecam0070 has a brilliant futurecam0070 has a brilliant futurecam0070 has a brilliant futurecam0070 has a brilliant futurecam0070 has a brilliant futurecam0070 has a brilliant futurecam0070 has a brilliant futurecam0070 has a brilliant futurecam0070 has a brilliant future
I looking forward to see what times you throw down tonight. Which track are you at? You could probably get alot of NATOR support out if there isn't already.
Cobb - APv2
CP-E - Stage 1 RMM
JBR - Tru 3.5" intake, SSB, SSP, coolant bypass, EGR bypass, BSD
NGK iridium plugs
MT-90 fluid
M2 TP
autotech internals
FreekTuned 93+e40
cam0070 is offline   Reply With Quote
 Old 08-20-2015, 10:08 AM   #89
mrdouble99's Avatar
You just read what you want to read .....
for me the way you are trying to make me look like a total retard is the definition of a smartass.
it's only my experience of more than 15years and over 2000 pass of drag race with a FWD.
When you are trying to lower your ET you try everything possible even if it doesn't make sense to you.
anyway i don't have to justify myself to you
Mazdaspeed3 - sold
 Old 08-20-2015, 09:18 PM   #90
Turbo_Steve's Avatar
Posts: 944   (View Stats)
Originally Posted by mrdouble99 View Post
but the most important thing is the track prep and how they maintain the condition of the track the whole day, and that's why a did all my best time at the muscle car day at Napierville Dragway.
Well, Thursday's are Slicks only at Union Grove Dragaway (track mazdafreak runs at) and they do better prep for this. Waiting for that 1.6 60ft time.
Soon to come.
WHO KNOWS? A.D.D. FTW!
 Old 08-21-2015, 12:25 AM   #91
mazdafreak's Avatar
Posts: 2,610   (View Stats)
Groans: 124
I already ran a 1.62 60ft the week before. That's when I ran a 11.15. And then the next week I ran left lane when it's rly prepped on Thursdays cause all the drag cars run that lane and snapped my axle haha.
And 20 psi in a slick? Geez. I run 8psi and still spinning.
I'll be running tomorrow(Friday). I didn't have the new fuel cell In. Hopefully all goes as planned
713whp/569wtq!
10.72 @ 139.44! (10/1/2015)
10.43 @ 140.95! 10/9/2015
10.35 @ 140.86 (10/30/2015)
Last edited by mazdafreak; 08-21-2015 at 12:25 AM. Reason: MSF Database - Automerged Doublepost
The Following 6 Users Say Thank You to mazdafreak For This Useful Post:
ButtholeRedMS3 (08-21-2015), Easter Bunny (08-21-2015), ItsNox (08-21-2015), MS3Shadow (08-21-2015), Realgib3 (08-21-2015), Tokay444 (08-21-2015)
 Old 08-21-2015, 12:35 AM   #92
I wish the best.....
2008 speed3
True red.
 Old 08-21-2015, 06:46 AM   #93
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
I wish the besteses.
Get it right. It's "I love really thin pancakes"
Don't you ever misquote Talladega Nights again. Repent.
The Following 5 Users Say Thank You to Tomas For This Useful Post:
802MS3 (08-21-2015), Crarrs (08-22-2015), Easter Bunny (08-21-2015), mazdafreak (08-22-2015), Yatta (08-21-2015)
 Old 08-21-2015, 07:21 AM   #94
<iframe width="560" height="315" src="https://www.youtube.com/embed/ZDqXbk_ThH0" frameborder="0" allowfullscreen></iframe>
You know " yo quiero taco bell"
Spec likes this.
802MS3 (08-21-2015), Tomas (08-21-2015)
 Old 08-21-2015, 07:28 AM   #95
Spec's Avatar
Posts: 4,472   (View Stats)
Or maybe even "El queso está viejo y pútrido. ¿Dónde está el sanitario?" the cheese is old and moldy, where is the bathroom
 Old 08-21-2015, 07:32 AM   #96
Bob Ross Fanclub
Tomas's Avatar
Why the fuck am I having such a hard time embedding youtube videos.
Spec likes this.
 Old 08-21-2015, 07:35 AM   #97
Apparently you can't make a sentence in html either.
The Following 10 Users Say Thank You to Easter Bunny For This Useful Post:
802MS3 (08-21-2015), blackmicamps6 (08-21-2015), Crarrs (08-22-2015), Dano (08-21-2015), DaUberSchwebel (08-21-2015), MS3Shadow (08-21-2015), Tokay444 (08-21-2015), Tomas (08-21-2015), udntknw (08-21-2015), Voltwings (08-21-2015)
 Old 08-21-2015, 08:56 AM   #98
Trail of Fail
Dano's Avatar
take the "s" off of https maybe?
Tomas (08-21-2015)
 Old 08-21-2015, 09:22 AM   #99
Yatta's Avatar
Posts: 1,862   (View Stats)
Attachment 209565
¿Dónde está tu hall pass? is more like it...
The Following 2 Users Say Thank You to Yatta For This Useful Post:
 Old 08-21-2015, 01:13 PM   #100
bigspender's Avatar
Posts: 854   (View Stats)
bigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the world
Groaned at 46 Times in 21 Posts
Originally Posted by ButtholeRedMS3 View Post
By no means do I have anything to do with this. I just wanted to post it for you guys who aren't on facebook. FUCKING FINALLYAttachment 208853
Sorry can't thank anyone with butt hole red in their name LOL. Nice run.
bigspender is offline   Reply With Quote
The Following User Says Thank You to bigspender For This Useful Post:
 Old 08-21-2015, 01:17 PM   #101
ButtholeRedMS3's Avatar
Posts: 784   (View Stats)
ButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the world
Name is no longer valid now that I drive a black 6. But I see your point lol
2007 BM MS6 - Sold
2010 VRM MS3 Tech - Sold
ButtholeRedMS3 is offline   Reply With Quote
The Following User Says Thank You to ButtholeRedMS3 For This Useful Post:
ItsNox (08-22-2015)
 Old 08-22-2015, 07:09 AM   #102
Justin@Freektune's Avatar
Posts: 954   (View Stats)
New times. Worked on short track last night. Still some tweaks to make. Really would like to be at 7.0 or better eighty mile. But Shawn managed to get back into 1.6x 60ft territory and shaved a little off the slip everywhere. 10.92@136
ItsNox likes this.
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
The Following 10 Users Say Thank You to Justin@Freektune For This Useful Post:
ButtholeRedMS3 (08-22-2015), cshunter (08-22-2015), Easter Bunny (08-22-2015), EwMPS (08-24-2015), MS3Shadow (08-22-2015), Raider (08-25-2015), RE-ACTIONENGSPEED3 (08-22-2015), taf0422 (08-23-2015), Tokay444 (08-22-2015), udntknw (08-22-2015)
 Old 08-23-2015, 07:52 PM   #103
mazdafreak's Avatar
Groans: 124
Improved all around, made a few adjustments and hit 04 faster. Just need to get second gear down and not spinning. And tweak front suspension since its lifting too much.
713whp/569wtq!
The Following 14 Users Say Thank You to mazdafreak For This Useful Post:
brandon3212 (08-24-2015), ButtholeRedMS3 (08-23-2015), dan7225 (08-25-2015), Dano (08-24-2015), Easter Bunny (08-24-2015), EwMPS (08-24-2015), Hush (08-23-2015), Justin@Freektune (08-24-2015), mxlplx71 (08-24-2015), MZRSPEED (09-27-2015), qtrmile beast (08-31-2015), RE-ACTIONENGSPEED3 (08-24-2015), snailD (08-23-2015), Tacheny (08-23-2015)
 Old 08-23-2015, 10:40 PM   #104
ItsNox's Avatar
Posts: 3,076   (View Stats)
http://youtu.be/Ba9mpaQ8abI
Car looks/sounds soooo fking mean in that last vid. Love it!
'06 Mazdaspeed 6 GT
- Miltuned
Georgia Motherfucking Nator
The Following 2 Users Say Thank You to ItsNox For This Useful Post:
Justin@Freektune (08-24-2015), mazdafreak (08-23-2015)
 Old 08-24-2015, 01:21 AM   #105
Ramrod711's Avatar
Posts: 196   (View Stats)
Ramrod711 is the leader of the worldRamrod711 is the leader of the worldRamrod711 is the leader of the worldRamrod711 is the leader of the worldRamrod711 is the leader of the worldRamrod711 is the leader of the worldRamrod711 is the leader of the worldRamrod711 is the leader of the worldRamrod711 is the leader of the worldRamrod711 is the leader of the worldRamrod711 is the leader of the world
That car sounds like how I imagine Angels fart.
Car Ramrod
M2 DP-HPFP-HTP 3.5-FULLY MOUNTED-TR8 FMIC-3in Exhaust-FreekTuneE85-GRIMMSPEED EBCS
Ramrod711 is offline   Reply With Quote
The Following 3 Users Say Thank You to Ramrod711 For This Useful Post:
Easter Bunny (08-24-2015), Justin@Freektune (08-24-2015), mazdafreak (08-24-2015)
 Old 08-24-2015, 10:06 PM   #106
skoski17's Avatar
Posts: 1,235   (View Stats)
So much sex!
Too much for you
skoski17 is offline   Reply With Quote
The Following 2 Users Say Thank You to skoski17 For This Useful Post:
Justin@Freektune (08-25-2015), mazdafreak (08-24-2015)
The Following User Says NO Thank You to skoski17 For This Un-useful Post:
kevin2.3 (08-25-2015)
 Old 08-25-2015, 01:31 AM   #107
HighwayUFO's Avatar
Posts: 33   (View Stats)
HighwayUFO is a jewel in the roughHighwayUFO is a jewel in the roughHighwayUFO is a jewel in the roughHighwayUFO is a jewel in the rough
Mazdafreak, please stop, a penis can only get so erect........
Ok, carry on.
HighwayUFO is offline   Reply With Quote
The Following User Says Thank You to HighwayUFO For This Useful Post:
mazdafreak (08-26-2015)
 Old 08-25-2015, 05:51 AM   #108
MSP611's Avatar
Posts: 2,291   (View Stats)
this is nutz!!! good ole hood exit... now lets see what @PapaSmurf; and tht 6466 has to say about this if he can run at lower elevation.
big congratz tho' been waiting on this since 2009 lol
In progress:
 Old 08-25-2015, 06:13 AM   #109
mazdafreak and MZRSPEED like this.
PTE 6062
633HP/523TQ
h.h.sk1nny (08-27-2015), mazdafreak (09-16-2015), MZRSPEED (09-27-2015), qtrmile beast (08-31-2015)
 Old 09-24-2015, 10:26 AM   #110
cam0070's Avatar
when are ya headed back to the track next? Got any plans to change suspension before your next run? do you have an air lift kit?
Cobb - APv2
CP-E - Stage 1 RMM
NGK iridium plugs
MT-90 fluid
M2 TP
autotech internals
FreekTuned 93+e40
 Old 09-25-2015, 09:42 PM   #111
mazdafreak's Avatar
Groans: 124
Planning on next week. Been way too busy with work lately and temps were too high to go out.
I tightened the front. We'll see what happens. And just coilovers
713whp/569wtq!
The Following User Says Thank You to mazdafreak For This Useful Post:
RE-ACTIONENGSPEED3 (09-27-2015)
 Old 10-02-2015, 11:34 AM   #112
mazdafreak's Avatar
Groans: 124
So this happened
713whp/569wtq!
The Following 22 Users Say Thank You to mazdafreak For This Useful Post:
brandon3212 (10-02-2015), ButtholeRedMS3 (10-02-2015), cam0070 (10-02-2015), Code Monkey (10-02-2015), Cyclops (10-02-2015), dan7225 (10-02-2015), Darth_Nuruodo (10-02-2015), Easter Bunny (10-02-2015), h.h.sk1nny (10-02-2015), Hush (10-02-2015), ItsNox (10-02-2015), Jtaylor (10-05-2015), Justin@Freektune (10-02-2015), Koke382 (10-02-2015), kolosok17 (10-02-2015), mazdaspeedmyk (10-02-2015), MS3Shadow (10-02-2015), Neverlift (10-03-2015), nindoja (10-02-2015), Pu Manchu (10-02-2015), RE-ACTIONENGSPEED3 (10-02-2015), Snyeed (10-02-2015)
 Old 10-02-2015, 11:47 AM   #113
ItsNox's Avatar
For some reason the video is loading slow as fuck. I'm halfway in, just saw the burn out. GOD I LOVE HOOD DUMP
Edit: No shit a jet was flying over my house during the video and i mixed the sound of your turbo up with it. "did a jet just fly over? nah it was that video. No wait, theres the plane. NICE"
'06 Mazdaspeed 6 GT
- Miltuned
 Old 10-02-2015, 11:49 AM   #114
mazdafreak's Avatar
Groans: 124
Works fine for me. Idk.
713whp/569wtq!
 Old 10-02-2015, 11:55 AM   #115
cam0070's Avatar
It sounded like you were spinning in 4th? really?
Cobb - APv2
CP-E - Stage 1 RMM
NGK iridium plugs
MT-90 fluid
M2 TP
autotech internals
FreekTuned 93+e40
 Old 10-02-2015, 11:57 AM   #116
wow
Congrats...........
2008 speed3
True red.
The Following 2 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post:
Justin@Freektune (10-02-2015), mazdafreak (10-02-2015)
 Old 10-02-2015, 03:39 PM   #117
mazdafreak's Avatar
Groans: 124
Fucked second gear up, but we're still dialing it in
Koke382 likes this.
713whp/569wtq!
The Following 3 Users Say Thank You to mazdafreak For This Useful Post:
ButtholeRedMS3 (10-02-2015), ItsNox (10-02-2015), Justin@Freektune (10-02-2015)
 Old 10-02-2015, 03:50 PM   #118
Koke382's Avatar
Posts: 4,361   (View Stats)
Damn. Legit. And you stay humble as fuck too. Lol. Others would be bragging like no others. Nice work man.
Sent from my LGLS991 using Tapatalk
Justin@Freektune likes this.
2007 Mazdaspeed 3 GT
18x8.75 XXR 527 225/40/18r
New fucken miata build:
1993 Red Na6
Some suspension modz yo
Coilovers// Other shit
The Following 3 Users Say Thank You to Koke382 For This Useful Post:
ItsNox (10-02-2015), Justin@Freektune (10-02-2015), mazdafreak (10-02-2015)
 Old 10-02-2015, 04:00 PM   #119
mazdafreak's Avatar
Groans: 124
Lmao. I am. I'm calm. I let my followers do all talking bragging for me. Justin's wife said I need to cheer up hahaha
713whp/569wtq!
The Following 4 Users Say Thank You to mazdafreak For This Useful Post:
Easter Bunny (10-03-2015), Jackis (11-09-2015), Justin@Freektune (10-02-2015), Koke382 (10-02-2015)
 Old 10-02-2015, 04:05 PM   #120
Koke382's Avatar
Haha. That's good. Makes it all even better. Congrats man.
1993 Red Na6
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f232/10-963-136-79-a-191993/
We finally did it. First ever Mazdaspeed 3 hits 10.9 1/4 mile. : mazda This thread Refback 08-13-2015 10:08 AM
Page generated in 0.61290 seconds with 41 queries
