| Fuck sushi rolls ![]() Join Date: May 2008 Location: Los Angeles
Rep Power: 12764 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,168
Groans: 356
__________________ 2007 Ms3 3071r fully bolted , retired and sold after 110k miles of abuse 2014 Black Track Pack premium , NA 4lyfe ...AED dyno tuned on E85 466.6whp / 406.8 TQ SAE |
| The Following 18 Users Say Thank You to rodrigo For This Useful Post: | 802MS3 (02-22-2015), Cheapspeed (02-23-2015), danmillerok (02-22-2015), Darksun280 (02-26-2015), DingoDave (02-28-2015), doubleflusher (02-22-2015), Elwood617 (02-23-2015), GrumpyMPS (02-22-2015), Hush (02-22-2015), Jester2552 (02-23-2015), jseams (02-22-2015), MD1032 (02-22-2015), MZRSPEED (04-08-2015), nojjy (02-26-2015), RalliartRsX (02-23-2015), RE-ACTIONENGSPEED3 (02-22-2015), SarcasticOne (02-22-2015), WetzMS3 (02-23-2015) |
![]() Join Date: Oct 2012 Location: Brisbane, Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 82
| Not Ranked : 0 score Very good 60'..........well done!
__________________ 2012 VR MPS BNR S3 and E30 fully bolted. Next up CP-E stage 2 pistons, Manley rods, few other bits and bops, extra fuel, GTX3076R to get it to 500whp............ ![]() [SIGPIC][/SIGPIC] |
Groans: 356
(Thread Starter) | Not Ranked : 0 score Should go 1.65 next month with 70 temps
![]() Join Date: Nov 2010 Location: Irvine, CA
Rep Power: 3369 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,566
Groans: 1,143
| Not Ranked : 0 score How many cars up was that 10 second car before the line? Reason I ask is, I have no idea what that looks like, so I am curious.
__________________ Past Mazdas & Speeds '04 MSM: Ohlins DFV//15x9 TRM C3M//FM FMIC//AEM SRI//Custom 3" TBE//BossFrog Clearview//Bride Gias II//Autokonexion CF Trunk v2 '94 M Edition MX5: R-package Bilsteins//15x6.5 Konig Helium//Torsen LSD//Roadstersport Race NC exhaust//MSM RSB//OEM Hardtop '06 MS6: COBB SRI/TIP//18x8 Enkei Imola//TooLateTuning Springs//SPC Balljoints//JBR RMM//Techna-Fit SS Clutch line Bimmer Challenge & Global Time Attack Project '99 BMW 328is: KW Variant3 w/ Vorshlag plates//AKG M3 Adj. Endlinks w/ 95 M3 FSB//18x9.5 +35 Advanti Optimo w/ 245/35 Hankook Z214 (C51)//E46 330i Front w/ Hawk DTC60 & E46 328i Rear w/ Hawk DTC50 & Hard Motorsport Ducting//Turner CTSCC Camber Arms//SLR Adjustable Lollipops//3 clutch 3.73 LSD//Welded 4 Point Gusseted X Brace Rollbar + Harness Bar//Sparco Ergo II w/ 6 point Schroth Clubman//Garagistic Delrin Motor & Trans Mounts, Rear Subframe, & Differential Bushings//OEM M3 Rear Subframe Reinforcement & Rear Trailing Arm Pocket Reinforcement//Z3 Steering Rack & Garagistic DSSR SSK//UUC Stage 2 Flywheel & M5 Clutch//S52 Camshafts w/ 7100 redline//M50 Intake Manifold//S50 Oilpan w/ VAC Baffle & Oil Filter Housing//CSF Radiator & Expansion Tank w/ Spal fan//3.5" MAF & Dinan CAI//#24 lb Injectors//VAC Fuel Starvation Kit//Active Autowerke GenII Header-back//OBD1 M52B28 w/ 230+whp ![]() |
Groans: 356
(Thread Starter) | Not Ranked : 0 score No clue I don't ever watch the other lane I am unaware of what they do since it has no impact on me . Looks like 3 tops .... It's funny that 1 second faster really isn't that much in car lengths
| The Following User Says Thank You to rodrigo For This Useful Post: | Neverlift (02-22-2015) |
![]() Join Date: Nov 2011 Location: Greece-Athens
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 470
| Not Ranked : 0 score I estimate with a 60 near 1.62 witch is doable on your tyre setup and lower temps you are on low 11.6... Keep up the good work...
__________________ 2008 speed3 True red. Pte 6466 & AWD Mode on !!!! 11.114@131.04 .........GTX3071.....FWD 10.62@136.64............PTE6466.....AWD [SIGPIC][/SIGPIC] |
![]() Join Date: Jan 2015 Location: College Park, Maryland
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 202
| Not Ranked : 0 score That thing is moving!! |
Groans: 356
(Thread Starter) | Not Ranked : 0 score I'll be back in March with hopefully 70 degree temp so the track sticks (without a real tire like a slick track conditions have to be warm ) .... My goal now is actuslly 1.59 sixty foot and 11.5-11.6 as is with one addition that I just purchased this morning Loose up front tight out back let's go 1.59 ... With actual powershifts unlike on the video I should grab 11.5-11.6 @ 117
![]() Join Date: Jan 2013 Location: McKinney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,778
| Not Ranked : 0 score Couldn't quite tell from the video and didn't see it listed anywhere. You still on street tires? I know you had some goal for them before moving on to slicks.
__________________ 3rd rebuild on the way...maybe... |
Groans: 356
(Thread Starter) | Not Ranked : 0 score signature has all the modifications ..... 305/35/19 NTO5r on the stock wheels .... I can't dump out the gate so to protect drivetrain it will be always a quick slip and then dump the clutch . in this video its around 4k launch slip and dump .... hoping with 70 temps and shocks I can go higher rpm say 4300-4700 and not only cut the 60 but up my mph half a click or so we will see ....need seat time with these new tires.... my old street tires I was cutting 1.77 consistently
Groans: 356
| The Following 2 Users Say Thank You to rodrigo For This Useful Post: | DingoDave (02-28-2015), doubleflusher (02-24-2015) |
Groans: 356
(Thread Starter) | Not Ranked : 0 score Twin disc and cobrajet are here , hopefully 11.49 @ 119-120 on radials and get kicked out to finish up the car NA style
| The Following 4 Users Say Thank You to rodrigo For This Useful Post: | doubleflusher (04-18-2015), Neverlift (04-19-2015), RE-ACTIONENGSPEED3 (04-19-2015), WetzMS3 (05-03-2016) |
![]() Join Date: Jan 2012 Location: COLUMBIA MISSOURI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 63
| Not Ranked : 0 score ^^^^^^^^^^^^^^^^^^^^^^ This right hear!!! I can't stop looking at it. |
Groans: 356
__________________ 2007 Ms3 3071r fully bolted , retired and sold after 110k miles of abuse 2014 Black Track Pack premium , NA 4lyfe ...AED dyno tuned on E85 466.6whp / 406.8 TQ SAE Last edited by rodrigo; 05-02-2016 at 09:02 PM. Reason: testing shit |
| The Following User Says Thank You to rodrigo For This Useful Post: | Amnesiac (05-02-2016) |
![]() Join Date: Jan 2015 Location: Fort Worth, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 289
| Not Ranked : 0 score How do you like those SE rear struts?
__________________ 2013 VRM MS3 Freektuned--BNRS3--HTP 3" Sri--COBB apv3 & springs--CPE catted dp & safe seals--TS dual bov--AT hpfp internals--CFM rmm--JBR pmm, tmm, ssb, ebcs, TIGs, full egr delete, rsb & fmic piping/tr6--DM occ--CS cbe & ssp--SPC camber arms--Bosch 3Bar map--RA mudflaps Ambit RE82 18x9.5 +38 255/35 -v8 swap in progress- 1994 Miata DGR coilovers-Hard Dog Rollbar-STR 506 15x7.5 +15 -Sold- 2003 Protegé5 w/Hiboost turbo kit ihi vf22 turbo 5 speed -Sold- 89' FC Rx7 vert S5 13B turbo swapped |
| COCKSTRONG ![]() ![]() ![]() Join Date: Jul 2011 Location: Your Mom's House
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,809
Groans: 890
| Not Ranked : 0 score @robry; lol
__________________ Searching for something? Try MS3Shadow's Custom Search EVERY "I DON'T USE MSF" FACEBOOK RETARD EVER |
| The Following User Says Thank You to SofaKingAwesome For This Useful Post: | WetzMS3 (05-06-2016) |
![]() Join Date: Sep 2009 Location: State College, PA
Rep Power: 621 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,311
Groans: 27
Groaned at 9 Times in 7 Posts
| Not Ranked : 0 score lol trollin
__________________ 2014 Mustang GT Premium 6MT - GT Track Pack/Leather Recaros/Glass roof in Sterling Grey Metallic | Barton SS/2 Post | J&M LCA | Steeda Street UCA | JBA 3" O/R X | GT500 ABs | JLT plastic CAI | SCT xcal with AED HP custom tune SOLD2011 Mazdaspeed3 Celestial Blue Mica |
| The Following 2 Users Say Thank You to robry For This Useful Post: | SofaKingAwesome (05-06-2016), WetzMS3 (05-06-2016) |
Groans: 356
(Thread Starter) | Not Ranked : 0 score evan gonna have more luck trolling a dead mouse .... ryan is faster than me , always has been and always will be
| The Following User Says Thank You to rodrigo For This Useful Post: | robry (05-10-2016) |
![]() | | #19 | ![]() |
Groans: 356
(Thread Starter) | Not Ranked : 0 score rear shocks and front struts ... they are good , u can manipulate weight transfer quite nicely.... they arent as sophisticated as 2 way vikings but for my modest goals they were just fine
