Autosports Area
> Drag Racing
Like Tree180Likes
 Old 07-14-2014, 03:54 PM   #121
MZRSPEED's Avatar
Posts: 550   (View Stats)
MZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the world
245/45/17 Nitto 555r. I didn't heat them up, which was a huge mistake.
Just a suggestion, but I wouldn't run them that low, they are still a radial, sidewalls aren't soft.. I was running about 22psi in mine, which were 245/50/16, so I even had a little more sidewall than you. I could ffs into 2nd at the track and only get a slight chirp.
2013 CWP - HPFP - 80d RMM - 3.5" INTAKE - CAT LESS EXTENDED DOWN PIPE - 3PORT - METH/WATER INJ D03
First 11 sec stock turbo MS3: 1.688, 7.676 @ 91.71 11.977 @ 113.85
MZRSPEED is offline   Reply With Quote
The Following 2 Users Say Thank You to MZRSPEED For This Useful Post:
Easter Bunny (07-14-2014), Ireland (07-14-2014)
 Old 07-14-2014, 04:12 PM   #122
Gr8Speed's Avatar
Posts: 5,702   (View Stats)
Thanks for the tip. Will inflate them a little more next time.
MZRSPEED (07-14-2014)
 Old 07-14-2014, 05:15 PM   #123
MTLspeed6's Avatar
Posts: 110   (View Stats)
MTLspeed6 is the leader of the worldMTLspeed6 is the leader of the worldMTLspeed6 is the leader of the worldMTLspeed6 is the leader of the worldMTLspeed6 is the leader of the worldMTLspeed6 is the leader of the worldMTLspeed6 is the leader of the worldMTLspeed6 is the leader of the worldMTLspeed6 is the leader of the worldMTLspeed6 is the leader of the worldMTLspeed6 is the leader of the world
The best way i have found to lower my BATs real quick is to remove the intercooler (takes 6 minutes lol) and hose it down/spray bottle. Preferably with ice cold water if you can bring a cooler with you.
COBB AP | COBB SRI | PG TIP | Autotech HPFP | Corksport TMIC | AWR RMM | SURE TP | 3inch single exit straight pipe exhaust | H&R springs FREEKtuned Videos of the whip : 1. https://www.youtube.com/watch?v=JnWmorhXPKo 2 https://www.youtube.com/watch?v=5JXhI4bFC44
MTLspeed6 is offline   Reply With Quote
 Old 07-14-2014, 05:32 PM   #124
Jtaylor's Avatar
Posts: 656   (View Stats)
Never even realized you were from Jacksonville. Good shit on the runs, looks like it was in Orlando.
08 MazdaSpeed3
The Following User Says Thank You to Jtaylor For This Useful Post:
 Old 07-14-2014, 05:44 PM   #125
MZRSPEED's Avatar
Yeah, Orlando has killer track prep, it's def worth the 2 hour one way drive. Gville is hit or miss, which is unfortunate since it's only 45 min away.
 Old 07-14-2014, 06:01 PM   #126
Jtaylor's Avatar
My first and only run with an intake only yielded me a 13.8 @ 103 at Gainesville..I got lucky since they had a break on the previous run so it was a fresh prep and an hour cool down time.
08 MazdaSpeed3
 Old 07-15-2014, 03:34 AM   #127
shaneski's Avatar
Posts: 506   (View Stats)
TMIC can certainly be a show stopper when idling etc before getting to the line with heatsoak building waiting for noobs that had no idea how to stage.
God bless the AP to log this stuff, they revert to high BAT settings and richen to 10.8 - 11 AFRs and pulled around 4 degrees of timing on mine, fucking meth couldn't even get shit down in time.
@MZRSPEED be interesting what you would do with meth and FMIC..having BT built engines looking over their shoulder with your lil old k04
The Following User Says Thank You to shaneski For This Useful Post:
MZRSPEED (07-15-2014)
 Old 07-15-2014, 08:45 AM   #128
Gr8Speed's Avatar
Yeah I had BATs in the 120s at WOT with a 5gph and top mount.
shaneski (07-16-2014)
 Old 01-20-2015, 01:58 AM   #129
citopz's Avatar
Posts: 3   (View Stats)
citopz can only hope to improve
Default whp guesstament
What do you think your whp was👏👏👏👏🙌😆
citopz is offline   Reply With Quote
The Following User Says NO Thank You to citopz For This Un-useful Post:
doubleflusher (01-20-2015)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f232/first-11-sec-k04-166536/
Aftermarket BOV (plumb back) make any performance differences? - Page 4 This thread Pingback 06-06-2014 11:32 PM
Page generated in 0.31029 seconds with 25 queries
