Autosports Area
> Drag Racing
Like Tree6Likes
  • 6 Post By PapaSmurf
 Old 01-08-2016, 06:55 AM   #1
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
Default Papasmurf's New Drag Pack
I've been wanting a nice pair of bead lock drag wheels for awhile now, I have had my eyes set on a full set of Belak's for years, if you have never heard of the company they basically are the go to drag wheels for any SFWD car.
They have recently been popping up everywhere on basically anything you can think of, GTRs, Evos, Supras etc...
I finally made the purchase when they had their black Friday deal. Basically free skinnies with the purchase of beadlock fronts.
These wheels shed from 14 lbs per wheel from the Vision Sports Stars that a lot of people run.
Belak Industries OG Style Wheel.
Front Specs.
15x9
5inch Backspacing
Single Beadlock
9.8lbs each
Rear Specs.
15x4
8.8lbs each
I will be adding some Mickey Thompson 26x10x15 slicks along with matching front runners.
860whp/677wtq
2.7 V6 Ecoboost
The Following 17 Users Say Thank You to PapaSmurf For This Useful Post:
DevinS (02-27-2016), Dralphy (01-08-2016), Easter Bunny (01-08-2016), h.h.sk1nny (11-02-2016), InkedInspector (01-08-2016), Jeremy M (01-09-2016), LumberJack (01-11-2016), Mauro_Penguin (01-08-2016), Micha (01-08-2016), mxlplx71 (01-09-2016), shaneski (01-08-2016), Snyeed (01-08-2016), SofaKingAwesome (01-08-2016), Vansquish (01-08-2016), WetzMS3 (01-08-2016), Zdraveca (01-08-2016), [R]usty (01-11-2016)
 Old 01-08-2016, 08:32 AM   #2
blackms3_71's Avatar
Posts: 2,250   (View Stats)
Front Specs.
15x9
5inch Backspacing
Single Beadlock
9.8lbs each
Rear Specs.
15x4
8.8lbs each
Yo have to shave the calipers for 15's no?
 Old 01-08-2016, 09:10 AM   #3
PapaSmurf's Avatar
depends on the backspacing, with this backspacing you shouldn't... however my old set up (Vision Wheels that most people run 4 inch backspace) I slightly filed some ridges off the caliper to get them to fit with spacers.
This set up here shouldn't need any spacer or shaving, if shaving is needed it should be minimal.
860whp/677wtq
2.7 V6 Ecoboost
 Old 01-08-2016, 09:16 AM   #4
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
Those look awesome!
PapaSmurf (01-08-2016)
 Old 01-08-2016, 09:36 AM   #5
MazdaBoy2.3's Avatar
Posts: 5,797   (View Stats)
Groans: 51
I wanna see the smurf on the track!
 Old 01-08-2016, 06:25 PM   #6
sheston's Avatar
Posts: 1,847   (View Stats)
Those look great! I'm jealous
@PapaSmurf; what does the "S" in SFWD stand for? Probably just having a brain fart, but stupid? Silly?
 Old 01-08-2016, 06:25 PM   #7
PapaSmurf's Avatar
Sport
860whp/677wtq
2.7 V6 Ecoboost
 Old 01-08-2016, 11:27 PM   #8
shaneski's Avatar
Posts: 506   (View Stats)
Getting the Skinnies for free is a hell of deal.
 Old 01-09-2016, 09:55 AM   #9
ieatboost's Avatar
Posts: 50   (View Stats)
ieatboost has a spectacular aura aboutieatboost has a spectacular aura aboutieatboost has a spectacular aura about
Groaned at 3 Times in 1 Post
drag videos or it didnt happen
AutoTech HPFP, HTP 3.5 Intake, Turbo XS DP & FMIC, Guardian Angel, Turbo XS RFL, Straight Pipe Exhaust, EGR Delete, CPE Seals, Dammond Dual OCC, Perm Plate, NGK's, BC BR Coils. Sway Bars, GT Spec Strut Bars, Rally Armor
ieatboost is offline   Reply With Quote
 Old 01-11-2016, 01:16 PM   #10
PapaSmurf's Avatar
Yeah a full set of these usually run $3K plus depending on options/powder coating etc.
I got them for $2k.
860whp/677wtq
2.7 V6 Ecoboost
 Old 01-11-2016, 06:23 PM   #11
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
Holey price check smurf man! That's some cash on go fast rims. Look sweet though.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 01-11-2016, 06:33 PM   #12
LumberJack's Avatar
Good light drag wheels aren't cheap.
My front's now that' they've been beadlocked would of been about $700-750 per wheel.
10.36@148 Fastest Gen 2
 Old 01-14-2016, 02:40 PM   #13
PapaSmurf's Avatar
Damaged wheels are damaged.
Some of the damage on the wheels when I got them. Need to send them back so they can either make me new ones or fix these. Pretty annoying.
Basically almost every bolt on the beadlock wheels have scratches around them as if someone was careless putting the centers on.
The skinnies have a couple bolts that have scratches but not as much as the bead lock wheels.
You can also see one of the beadlocks has some blemishes on it.
File Type: jpg ImageUploadedByTapatalk1452807415.474563.jpg (374.8 KB, 26 views)
860whp/677wtq
2.7 V6 Ecoboost
radbrad (04-08-2016)
 Old 04-08-2016, 03:55 AM   #14
shaneski's Avatar
@PapaSmurf; with the Vision Stars (i currently have a set) which have a center bore of 83.1mm and our hubs and the spacers are 67.1, did you run hub rings so the wheel studs aren't taking the load.
I can't find any off the shelf that are 67.1 inside dia to 83.1 outside dia.
 Old 04-08-2016, 08:49 AM   #15
PapaSmurf's Avatar
No I did not, just tightened them down while the car was up in the air.
860whp/677wtq
2.7 V6 Ecoboost
shaneski (04-09-2016)
 Old 04-08-2016, 04:01 PM   #16
LumberJack's Avatar
Neither did I, and I'm still to this date not using hub rings on either sets of my wheels.
PapaSmurf (04-08-2016), shaneski (04-09-2016)
 Old 04-09-2016, 05:32 AM   #17
shaneski's Avatar
Thank you guys !! i took mine to the track last Wednesday night and only noticed when i fitted them there the hub difference and wasn't sure about it and didn't end up running due to being paranoid...Now i can stop being a pussy and drive it like i stole it at the track.
Mopar unveiling Dodge Challenger drag race pack on July 13 Haltech Automotive News 0 07-07-2008 05:10 PM
abcink Deals (5-Pack Canon Ink $14.37, 2-Pack Lexmark Ink $32.83) Haltech Hot Deals Section 0 04-09-2008 06:40 PM
abcink Deals (4-Pack Brother Ink $21.52, 3-Pack HP Laser Toner $72.95) Haltech Hot Deals Section 0 03-28-2008 08:10 PM
abcink Deals (1-Pack Brother Laser Toner $28.08, 6-Pack Canon Ink $13.20) Haltech Hot Deals Section 0 03-26-2008 08:41 PM
abcink Deals (12-Pack Canon Ink $23.98, 1-Pack HP Laser Toner $27.95) Haltech Hot Deals Section 0 03-26-2008 01:24 AM
Page generated in 0.36461 seconds with 29 queries
