Autosports Area
Like Tree8Likes
 Old 07-28-2015, 05:18 PM   #81
brandon3212's Avatar
Posts: 425   (View Stats)
I have the JBR competition RSB on my car and they do kill the understeer depending on your track layout.
It would be cool to have options to go with a lighter front sway bar to further alter the cars rotation.
07 Speed 3
 Old 10-17-2015, 07:41 PM   #82
snailD's Avatar
Posts: 3,039   (View Stats)
OOPS
 Old 10-17-2015, 07:52 PM   #83
skoski17's Avatar
Posts: 1,235   (View Stats)
Hhmmm now you have me thinking.
Too much for you
skoski17 is offline   Reply With Quote
 Old 10-17-2015, 08:14 PM   #84
snailD's Avatar
@skoski17; holy signature batman!
skoski17 likes this.
 Old 10-17-2015, 08:27 PM   #85
Yeah, his signature is WHOA!
sent from my Nexus 6P
 Old 10-17-2015, 09:25 PM   #86
skoski17's Avatar
Ya... I have been meaning to change that lol
Too much for you
 Old 10-18-2015, 08:06 AM   #87
zenit's Avatar
Posts: 1,364   (View Stats)
Originally Posted by snailD View Post
OOPS
Which endlinks are those?
 Old 10-18-2015, 10:10 AM   #88
snailD's Avatar
@grantmm; got the custom made for the AST suspension i bought off of him
 Old 10-18-2015, 07:53 PM   #89
zenit's Avatar
Still jealous.
thankfully- that rod end should be replaceable, probably for pretty cheap.
 Old 10-18-2015, 08:57 PM   #90
snailD's Avatar
Still jealous.
Yea i just cant find it locally so i need to order one
 Old 10-18-2015, 09:57 PM   #91
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
OOPS
I wouldn't just slap new rod ends in. That link is binding and it is bending due to that. Double check alignment throughout the entire range of motion to make sure the rod ends don't neck out. Binding suspension bits don't allow your suspension to work properly and can introduce some nasty behavior.
-06 MS6
-Corn fed 07 MS3 - Sold
Mauro_Penguin (10-19-2015), Nliiitend1 (10-19-2015), snailD (10-19-2015), zenit (10-19-2015)
 Old 01-13-2016, 10:29 AM   #92
KevinK2's Avatar
Posts: 907   (View Stats)
KevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the world
Groaned at 79 Times in 52 Posts
Yea i just cant find it locally ...
Just a quick note to the OP about the dyno numbers posted. They may well be overstated by the dyno CF.
The latest 2011 version of the SAE Standard for car manufacturers rated Hp & Tq, J1349, finally has a note about engine dyno tests for boosted induction, done at high elevations. The standard is the basis of the chassis dyno's "SAE correction factor", that is supposed to tell what the power would be at sea level and standard ambient pressure and temperature.
This standard was originally written for normally aspirated (no boost) engines. It does not work for boosted engines regarding the ambient pressure variable at high elevations, and Breckenridge Co at 5000 ft has an ambient pressure of only 12.2 psi. The typical SAE CF would be about 1.2 because of this NA basis. The latest version of the standard states that if the boost control system maintains the same absolute pressure at ground level as at high elevation, NO ambient pressure correction is needed. This means for a car with 20 psi of boost at ground level, the compressor would overspeed to maintain the same absolute manifold pressure at 5000 ft, making 22.5 psi boost.
For years people have used a modified version of the SAE formula for boosted engines, when dyno'd at at high elevations, to include difference in absolute manifold pressure. You can Google for more info on this.
From Delaware
Current Fleet: 04 Mazda6, 93 Rx7 TT, 76 Triumph 750 Trident
Tracked Cars: 68 Triumph GT6 (~full race prep'd), 81 Porsche 924 Turbo, 93 Rx7 twin turbo
KevinK2 is offline   Reply With Quote
 Old 01-13-2016, 04:24 PM   #93
snailD's Avatar
If you are just trying to say my dyno numbers are wrong, then say you think they are wrong lol. Just a few things.... They equal to about the same numbers as those dyno-Ing at sea level. It was dynoed in Utah at 4500ft at 1.16 cf factor and Breckenridge is at 9600ft in elevation.
 Old 01-13-2016, 04:50 PM   #94
KevinK2's Avatar
I don't know where I got 5000 ft ... I skied at Park City, close to 6k, and went for a jog and could not catch a breath! Can't imagine 9600 ft. Local air pressure just 10 psi!.
Were the boost pressure gauge numbers the same at 4500 and sea level?
From Delaware
 Old 01-13-2016, 11:36 PM   #95
snailD's Avatar
yea and i played soccer up at that altitude this summer lol.
i'm not sure i understand your question, im just comparing my numbers to others running the same if not super similar set ups with the same amount of boost pressure coming very close in numbers.
 Old 01-14-2016, 10:01 AM   #96
KevinK2's Avatar
... i'm not sure i understand your question, i'm just comparing my numbers to others running the same if not super similar set ups with the same amount of boost pressure coming very close in numbers.
I see that now, you were clear about it, but I still misread it as if you dyno'd your car at sea level too.
This is a good example of why the SAE CF (and some others) are not correct for predicting hp & tq at sea level, when dyno'd at high elevation like 4500 ft.
The trouble with Dyno's at high elevation
And an elevation vs ambient pressure table: engineeringtoolboxair-altitude-pressure-
From Delaware
 Old 02-15-2016, 09:42 PM   #97
jeffdevo's Avatar
Posts: 395   (View Stats)
jeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond repute
here are my mods, I have a few hundred to spen on mods for autocross. any additional braces that may help handling? or motor mounts?? thanks!
Corksport SRI - Corksport Rear Sway Bar - H&R Springs - Koni Yellow Struts - JBR Camber Arms - AP v2 -Autotech internals - Tork Motorsports Tuned - SST brake lines - Stoptech Sport brake and rotors w/ sst Brake lines
-Low Beam/ Fog HIDS - Lamin-X Yellow Tint on Fog Lights - TSW Mallory Wheels - Thule Bike Rack with 598 Criterium Bike Mount - GX-65 with Blendmount - Corksport RMM - Corksport Mudflaps - Corksport SRI - Corksport Rear Sway Bar - GX-65 radar laser detector - TRS Angel Eyes - Rear bumper LED Light - H&R Springs - Koni Yellow Struts - JBR Camber Arms - AP v2 -Autotech internals - Tork Motorsports Tuned - Halos - Strips - D2 Xenon Lights - SST brake lines - Stoptech Sport brake and rotors w/ sst Brake lines
[/I][/SIZE][/FONT]
jeffdevo is offline   Reply With Quote
 Old 02-15-2016, 10:05 PM   #98
Eth Fiend
phate's Avatar
If you haven't been out autocrossing every couple weekends (or more) up to this point, seat time will be the best investment.
Nliiitend1 and jeffdevo like this.
-06 MS6
Crarrs (02-16-2016), daafisch (02-16-2016), Nliiitend1 (02-16-2016), snailD (02-15-2016)
 Old 02-16-2016, 11:49 AM   #99
KevinK2's Avatar
Like Phate said, seattime is essential to improvement. If they have extra runs for a few bucks after the competition is over, invest! I did not see a race alignment on your list of mods ... if not already done, research and do it. How long have you been Autoxing?
There are HPDE's held at tracks near Atlanta, like Road Atlanta. Best to find one with more tight turns. You may need to add full race pads up front, and back off the rear bar setting. But when I was competing for a class win in the local autox, I would do HPDEs that improved my braking skills. Every time I did one, I was faster at the next autox, relative to my close rivals.
HPDE, Road Atlanta
From Delaware
The Following User Says Thank You to KevinK2 For This Useful Post:
 Old 02-16-2016, 02:50 PM   #100
KevinK2's Avatar
OOPS
It looks like an extra wide tapered spacer was used for extra offset of the rod-end (vs oem offset) on the right side of the pic. This increases the bending load on the joint. If that much offset is needed, make sure you use a 12.9 strength bolt, torqued to the max allowed. Look up on the net metric bolt "torque table" 8.8 10.9 12.9, etc
also make sure you use high strength rod ends, and check for no binding as Phate described.
EDIT: I think Phate is correct about a binding issue. When you lowerd the suspension, you often need shorter end links. And the front ones that came with the C/O system may not have been adjusted right for your car. I think you mentioned the car did not feel right with the new suspension.
I doubt the end links were not up for an oem front bar, if adjusted properly. But for someone looking for heavy duty end links, this place uses oem tie rod ends that are sealed and not designed to get loose with wear: http://www.powergridinc.com/swaybar.asp
From Delaware
 Old 02-17-2016, 12:13 AM   #101
jeffdevo's Avatar
HPDE, Road Atlanta
we caught the last SCCA race of the season last fall at bremerton Motorsports park in Washington. Planning on going to a few events this spring and summer. Fortunately got my wife involved too and she had a great time! Its my DD, I will look up a race alignment.
We also bumped up the tire pressure to about 40 psi to minimize sidewall tire compression.
Def want more seat time and will def pay for extra time on the course too!
[/I][/SIZE][/FONT]
 Old 02-17-2016, 09:21 PM   #102
blackms3_71's Avatar
Posts: 2,250   (View Stats)
Hey, ill be moving to washington in the bermerton area and would love to come out for some auto x
 Old 02-17-2016, 11:03 PM   #103
jeffdevo's Avatar
check out this link. Autocross Solo Events In Washington - Where2Race
hit me up if you go!
blackms3_71 likes this.
[/I][/SIZE][/FONT]
 Old 03-18-2016, 07:17 PM   #104
miata_racer's Avatar
Posts: 8   (View Stats)
miata_racer will become famous soon enough
Budget driving to me would be what I started with:
Corksport camber plates and a JBR Race rear bar. Then wide wheels and tires. 17x9 and 245/40-17s fit pretty easy up front. Fender lip rolling required. Out back I'd do the same actually.
Whiteline offset upper rear bushings.
Alignment I'd do about -2.5 up front (some can't get over -2.2 or so) and zero toe. Out back do -1.5 and a smidge of toe out.
This should work nice on even stock shocks and springs. For an upgrade and not much more money ($1000 vs nearly $400 for the CS camber plates) get some custom valved BC coilovers. Streetable rates like 10k front and rear will be pretty similar balance. Go up to a 12 or 14k rear to get some good rotation going.
I daily drove my 2008 on their ER series doubles on 10k/14k. The car weighed about 2690-2700 so the 300+ extra lbs on the MS3 should make it smooth. I'll be much stiffer on mine
David Hedderick
2008 MZ3 - former STF national car
2009 MZ5 - family hauler and local goof off AX vehicle
2012 MS3 - 2016 STX Pro-Solo and track car.
Houston, TX
miata_racer is offline   Reply With Quote
The Following User Says Thank You to miata_racer For This Useful Post:
Nliiitend1 (03-19-2016)
 Old 03-19-2016, 07:29 AM   #105
Rose City Speed6's Avatar
Posts: 55   (View Stats)
Rose City Speed6 is a name known to allRose City Speed6 is a name known to allRose City Speed6 is a name known to allRose City Speed6 is a name known to allRose City Speed6 is a name known to allRose City Speed6 is a name known to all
Groaned at 3 Times in 1 Post
I've had my MS6 for less than two months. It has stock suspension. Wheels are stock. The tires are 225s, but they are mismatched. Yokos on the front, Federals on the rear.
I just competed in a local autocross and was surprised that it is quite tail-happy. Definitely fun to drive, but I want more balance. I'm sure the tires factor heavily into this tendency. Does the stock MS6 tend towards oversteer? What will balance it out?
Rose City Speed6 is offline   Reply With Quote
 Old 03-19-2016, 09:40 AM   #106
KevinK2's Avatar
The MS6 tends to understeer in an AutoX. This thread is mostly related to the MS3, look at this MS6 suspension forum that is found at the bottom right of this page, labeled "forum jump".
official-mazdaspeed-6-suspension-Forum
and search it and the many threads in it. This one in particular:
Phate's MS6-suspension-data-diy-bilstein-coilovers. Phate is an expert autoxer, and all tasks are DIY with pics.
And in tight money days, I had hard and softer tire pairs for my old GT6 that I moved front to rear to get more or less oversteer.
From Delaware
The Following 2 Users Say Thank You to KevinK2 For This Useful Post:
Nliiitend1 (03-19-2016), Rose City Speed6 (03-20-2016)
 Old 04-19-2016, 04:52 PM   #107
ViperTGB's Avatar
Posts: 133   (View Stats)
ViperTGB has a reputation beyond reputeViperTGB has a reputation beyond reputeViperTGB has a reputation beyond reputeViperTGB has a reputation beyond reputeViperTGB has a reputation beyond reputeViperTGB has a reputation beyond reputeViperTGB has a reputation beyond reputeViperTGB has a reputation beyond reputeViperTGB has a reputation beyond reputeViperTGB has a reputation beyond reputeViperTGB has a reputation beyond repute
Here's a very simple, yet very effective, alignment that works great for street/AutoX use:
Front: -2.0 camber, 0 toe
Rear: -1.0 camber, 0 toe
This will keep your tires lasting a somewhat reasonable amount of time. If you want more of an autoX setup then you'll want more camber up front, around -3.0.
But just like everyone else is saying: seat time, seat time, seat time. Nothing will improve your times faster than a driver mod.
jeffdevo likes this.
CS SRI w/ TIP (removed) | 70a JBR RMM | .125 JBR RSB | Cobb AP | Damond SSP | CS OCC
AutoX Tires: Bridgestone Potenza RE71R
Official MS3 AutoXer of Florida
ViperTGB is offline   Reply With Quote
 Old 05-27-2017, 09:44 PM   #108
the_red_baron's Avatar
Posts: 16   (View Stats)
the_red_baron is an unknown quantity at this point
Hate to resurrect an old thread but apparently I don't have enough posts yet to send PMs. Guess I need to fix that. Viper, in an older thread you had stated you were running 1/4" toe all around but here you're suggesting 0 toe. I'm assuming that's because here you're saying it would be optimal for street/autox. It's been over a year now since you posted this, do you still feel this would be a good set up? Based on limited information I managed to cram into my head regarding suspension, it sounds good, but I find it interesting that a number of guys on here are running 1/16 toe up front with 0 in the rear. They're willing to wear out their front tires a bit more to reduce understeer when racing I suppose.
the_red_baron is offline   Reply With Quote
best bang for buck IVIike13 2010 MS3 - Suspension & Brakes 31 02-09-2012 03:02 PM
bang for your buck mods rkwill MazdaSpeed 6 - Engine, Transmission & Driveline 27 11-21-2010 03:04 PM
Need the best bang for the buck HP mod combo... 94jedi MazdaSpeed 3/6 - Turbo Induction 31 04-24-2008 08:29 AM
Page generated in 0.52074 seconds with 33 queries
