Autosports Area
Like Tree51Likes
 Old 06-06-2019, 07:29 PM   #321
breakfasteatre's Avatar
Posts: 308   (View Stats)
breakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the world
that aerogel shit something you use at work?
where did you source that corrugated aluminum?
breakfasteatre is offline   Reply With Quote
 Old 06-08-2019, 03:30 PM   #322
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
No.
Both from ebay.
https://www.ebay.com/itm/EMBOSSED-HE...72.m2749.l2649
https://www.ebay.com/itm/Aspen-Aerog...72.m2749.l2649
 Old 07-03-2019, 06:34 AM   #323
Bob Ross Fanclub
Tomas's Avatar
This shit with the power steering delete was a mistake. I simply cannot believe Code Monkey can turn the wheel with one hand while parking. The effort required to steer at slow speed is brutal. The only benefit I can find is that feedback at medium to high speed turns is sharper.
Tried ridiculously low caster and it only made it slighlty better. I do not believe the whiteline bushings would make it much better either.
At some point I'll install the whole thing back in + new steering rack. It's just no fun driving the car like this.
The Following 3 Users Say Thank You to Tomas For This Useful Post:
802MS3 (09-22-2019), Code Monkey (07-03-2019), Db09ms3 (07-03-2019)
 Old 07-03-2019, 04:48 PM   #324
^ I came to the same conclusion. Lost about 2-3 seconds per lap on a 2-minute road course.
 Old 07-10-2019, 10:52 AM   #325
Bob Ross Fanclub
Tomas's Avatar
Fuck bro. I thought at the end you did like the delete?
Time for a lil update.... Did two HPDE weekends in a row, May 14-15 and 21-22.
The manual steering with less caster is amazeballs, I even switched back to a 350 mm steering wheel and can turn the wheel with one hand in parking lots once the car starts moving.
 Old 07-10-2019, 11:52 AM   #326
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Damn bro. You've been had. SIKE!!!
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 07-10-2019, 04:01 PM   #327
You get used to it but after a while you ask yourself Why?.
Mauro_Penguin (09-05-2019)
 Old 07-11-2019, 01:59 PM   #328
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Scrub radius. Deepen that offset and get the tire closer to the coil.
 Old 09-20-2019, 09:33 AM   #329
Bob Ross Fanclub
Tomas's Avatar
Bought a used rack from ebay and installed it with some upgraded components. The reservoir is from KSE and has an integrated paper cartridge filter inside at the inlet. Nice unit.
The PS cooler is about 6" longer than the previous one and I re-located it behind the FMIC but with a gap between it and the plastic frame that sits the radiator. I also bumped the FMIC about an inch higher so that there is gap large enough to allow air to pass below it. That means the scoop that's on the bottom of the bumper should be directing a lot more air toward it than the previous location on top of the crash bar behind the bumper.
You will also notice there is an anal looking cavity on the driver's side headlight made of carbon fiber. Yes that is a true ram air intake and yes that is true CF. I hais teh ram. Nothing will yield lower intake temps than this set up although its not really compatible with wet conditions.
The Following 5 Users Say Thank You to Tomas For This Useful Post:
802MS3 (09-22-2019), cnyms6 (09-22-2019), Code Monkey (09-21-2019), Db09ms3 (09-20-2019), phate (09-20-2019)
 Old 01-03-2020, 09:22 AM   #330
Bob Ross Fanclub
Tomas's Avatar
Code Monkey likes this.
cnyms6 (01-03-2020), Code Monkey (01-03-2020), Db09ms3 (01-03-2020)
 Old 01-03-2020, 10:10 AM   #331
Db09ms3's Avatar
Posts: 536   (View Stats)
Car diaper?
Stockish
The Following User Says Thank You to Db09ms3 For This Useful Post:
Tomas (01-06-2020)
 Old 01-06-2020, 05:25 AM   #332
Bob Ross Fanclub
Tomas's Avatar
Jes. Depends size.
Db09ms3 (01-06-2020)
 Old 01-07-2020, 08:01 AM   #333
Bob Ross Fanclub
Tomas's Avatar
The Following 4 Users Say Thank You to Tomas For This Useful Post:
cnyms6 (01-10-2020), Code Monkey (01-07-2020), Db09ms3 (01-08-2020), Vansquish (01-07-2020)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f233/dildo-blitz-169330/
Reedy's Engine Rebuild Bonanza! - Page 20 Post #87 Pingback 03-04-2015 11:07 PM
Blitz K3T Twinturbo6 MazdaSpeed 3/6 - Big Turbo Builds 1 11-04-2013 02:34 PM
Blitz Air Filter USAFDentist 2010 MS3 - Turbo Induction 6 02-16-2012 01:05 PM
Blitz Type O1 clown_car MazdaSpeed 3/6 - Wheels & Tires 2 03-20-2009 01:26 PM
Page generated in 0.34422 seconds with 26 queries
