![]() | | #321 | ![]() |
![]() Join Date: Jan 2011 Location: Toronto, Ontario
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 937
| Not Ranked : 0 score where did you source that corrugated aluminum?
__________________ |
![]() | | #322 | ![]() |
| Bob Ross Fanclub ![]() Join Date: Jan 2009 Location: SEFL
Rep Power: 4333 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,534
Both from ebay. https://www.ebay.com/itm/EMBOSSED-HE...72.m2749.l2649 https://www.ebay.com/itm/Aspen-Aerog...72.m2749.l2649
__________________ | |
![]() | | #323 | ![]() |
(Thread Starter) | Not Ranked : 0 score This shit with the power steering delete was a mistake. I simply cannot believe Code Monkey can turn the wheel with one hand while parking. The effort required to steer at slow speed is brutal. The only benefit I can find is that feedback at medium to high speed turns is sharper. Tried ridiculously low caster and it only made it slighlty better. I do not believe the whiteline bushings would make it much better either. At some point I'll install the whole thing back in + new steering rack. It's just no fun driving the car like this.
| The Following 3 Users Say Thank You to Tomas For This Useful Post: |
![]() | | #324 | ![]() |
| Not Ranked : 0 score ^ I came to the same conclusion. Lost about 2-3 seconds per lap on a 2-minute road course.
![]() | | #325 | ![]() |
![]() | | #326 | ![]() |
| Not Ranked : 0 score Damn bro. You've been had. SIKE!!!
![]() | | #327 | ![]() |
| Not Ranked : 0 score You get used to it but after a while you ask yourself Why?.
| The Following User Says Thank You to Code Monkey For This Useful Post: | Mauro_Penguin (09-05-2019) |
![]() | | #328 | ![]() |
| Not Ranked : 0 score Scrub radius. Deepen that offset and get the tire closer to the coil.
![]() | | #329 | ![]() |
(Thread Starter) | Not Ranked : 0 score Bought a used rack from ebay and installed it with some upgraded components. The reservoir is from KSE and has an integrated paper cartridge filter inside at the inlet. Nice unit. The PS cooler is about 6" longer than the previous one and I re-located it behind the FMIC but with a gap between it and the plastic frame that sits the radiator. I also bumped the FMIC about an inch higher so that there is gap large enough to allow air to pass below it. That means the scoop that's on the bottom of the bumper should be directing a lot more air toward it than the previous location on top of the crash bar behind the bumper. You will also notice there is an anal looking cavity on the driver's side headlight made of carbon fiber. Yes that is a true ram air intake and yes that is true CF. I hais teh ram. Nothing will yield lower intake temps than this set up although its not really compatible with wet conditions.
| The Following 5 Users Say Thank You to Tomas For This Useful Post: | 802MS3 (09-22-2019), cnyms6 (09-22-2019), Code Monkey (09-21-2019), Db09ms3 (09-20-2019), phate (09-20-2019) |
![]() | | #330 | ![]() |
![]() | | #331 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 549
| Not Ranked : 0 score Car diaper?
__________________ Stockish |
| The Following User Says Thank You to Db09ms3 For This Useful Post: | Tomas (01-06-2020) |
![]() | | #332 | ![]() |
(Thread Starter) | Not Ranked : 0 score Jes. Depends size.
| The Following User Says Thank You to Tomas For This Useful Post: | Db09ms3 (01-06-2020) |
![]() | | #333 | ![]() |
| The Following 4 Users Say Thank You to Tomas For This Useful Post: |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f233/dildo-blitz-169330/ | ||||
| Reedy's Engine Rebuild Bonanza! - Page 20 | Post #87 | Pingback | 03-04-2015 11:07 PM | |
| Blitz K3T | Twinturbo6 | MazdaSpeed 3/6 - Big Turbo Builds | 1 | 11-04-2013 02:34 PM |
| Blitz Air Filter | USAFDentist | 2010 MS3 - Turbo Induction | 6 | 02-16-2012 01:05 PM |
| Blitz Type O1 | clown_car | MazdaSpeed 3/6 - Wheels & Tires | 2 | 03-20-2009 01:26 PM |
