| Bob Ross Fanclub ![]() Join Date: Jan 2009 Location: SEFL
Rep Power: 4333 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,534
(Thread Starter) | Not Ranked : 0 score I haz it. Stay tuned homos.
__________________ |
| The Following 19 Users Say Thank You to Tomas For This Useful Post: | 802MS3 (04-29-2014), breakfstincluded (09-10-2014), BrianB6 (04-29-2014), ButtholeRedMS3 (12-27-2015), Code Monkey (04-24-2014), cshunter (04-27-2014), daafisch (04-29-2014), derek13p (07-28-2014), Easter Bunny (04-25-2014), Enki (11-25-2014), gmoney542 (04-27-2014), helmetface (04-29-2014), Jh8909 (04-25-2014), lazza151 (09-20-2019), Mauro_Penguin (09-10-2014), Micha (03-05-2015), ms3blackmica (04-25-2014), SofaKingAwesome (08-05-2014), WetzMS3 (04-24-2014) |
| The Following 3 Users Say Thank You to Code Monkey For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score ^ Your gonna like what's coming. It's going on the 6. + other ghey goodies.
| The Following 6 Users Say Thank You to Tomas For This Useful Post: | Code Monkey (04-24-2014), Easter Bunny (04-25-2014), Jh8909 (04-25-2014), Mauro_Penguin (09-10-2014), phate (04-29-2014), SofaKingAwesome (08-05-2014) |
| Not Ranked : 0 score Already fapped. Twice.
| The Following 4 Users Say Thank You to Code Monkey For This Useful Post: |
![]() Join Date: Jul 2013 Location: Westchester, IL
Rep Power: 4924 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,635
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP |
| The Following 2 Users Say Thank You to WetzMS3 For This Useful Post: | Easter Bunny (04-25-2014), Tomas (04-25-2014) |
| The Following 17 Users Say Thank You to Tomas For This Useful Post: | 802MS3 (04-29-2014), Code Monkey (04-25-2014), Crarrs (04-26-2014), cshunter (04-27-2014), Easter Bunny (04-25-2014), helmetface (07-28-2014), Ingle (11-03-2014), jtday (04-29-2014), magicka (08-06-2014), Mase (07-29-2014), Mauro_Penguin (09-10-2014), Neverlift (09-06-2015), Nliiitend1 (07-28-2014), phate (04-29-2014), sac02 (09-18-2014), Vader (08-05-2014), WetzMS3 (04-25-2014) |
| Not Ranked : 0 score Can you post a picture of the oil drain line that comes with the kit?
| The Following User Says Thank You to Code Monkey For This Useful Post: | Voltwings (08-05-2014) |
(Thread Starter) | Not Ranked : 0 score There is no oil drain line in the kit. Only an AN-10 fitting.
| Not Ranked : 0 score Can you please post how you rigged the oil drain line once the turbo goes in? The fitting is custom I assume and clears the T-case?
| Not Ranked : 0 score This here I know will be good if you can get past all the homoerotic stuff.
| The Following User Says Thank You to Lex For This Useful Post: | Tomas (04-29-2014) |
| Not Ranked : 0 score mm mmm digressive piston and shim kits. What else are you doing with the suspension?
| rabble rabble ![]() Join Date: Aug 2008 Location: Delawhere
Rep Power: 3168 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,400
Groans: 221
| Not Ranked : 0 score you are so underrated on this forum.
__________________ '08 CWP MS3 w/ T3 3071r |
| The Following 6 Users Say Thank You to 802MS3 For This Useful Post: | Easter Bunny (07-29-2014), Koke382 (11-19-2014), Mauro_Penguin (09-10-2014), ms3blackmica (04-29-2014), Tomas (04-29-2014), WetzMS3 (04-29-2014) |
(Thread Starter) | Not Ranked : 0 score ^ I luv you too muffin.
On the rear Bills I am going to try a few different valving combinations. Also want to try the COB (compression only bypass) shims that Bilstein has for these. At some point I might buy the double adjustable shafts. But they are about $340 a piece and if you get the valving right aren't really needed. They are fucking kewl as shit though and easily interchangeable. The bushings for the hem joints on the housings I had to fabricate pictured below would still work. For the fronts I don't know yet. Might do the OTS Bils converted to take apart. I am gonna wait and see how yours come out. Nitrogen. I hais it. In case anyone needs to know, although I doubt it, the bushings need to be exactly 23mm wide for both the lower and the upper brackets. M12 bolt.
__________________ Last edited by Tomas; 04-29-2014 at 11:52 AM. | ||
| The Following 9 Users Say Thank You to Tomas For This Useful Post: | Code Monkey (04-29-2014), Easter Bunny (07-29-2014), Koke382 (11-19-2014), Mauro_Penguin (09-10-2014), Micha (03-05-2015), ms3blackmica (04-29-2014), phate (04-29-2014), sac02 (09-18-2014), WetzMS3 (04-29-2014) |
My bils are supposedly going to be finished this week, but I don't have high hopes for this actually happening. Very cool stuff, excited to see another MS6 with a nice setup.
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. | |
| The Following 3 Users Say Thank You to phate For This Useful Post: |
| The Following 3 Users Say Thank You to Tomas For This Useful Post: |
| Not Ranked : 0 score Wtf, updates, I'm losing sleep here.
| The Following 2 Users Say Thank You to Code Monkey For This Useful Post: | 802MS3 (07-28-2014), Easter Bunny (07-29-2014) |
(Thread Starter) | Not Ranked : 0 score Yes sir! Dropped the tranny. Changed clutch to ferramic / kevlar. Dropped T-case. Exchanged shafts with CX-7 T-case. Mounted tranny back on (you may interpret that anyway you want) Rerouted heater hoses to clear terboh WG actuator. Currently in the process of mounting turbo and routing cooling water lines to and from turbo. Also oil drain line back into block. I now know why you wanted to see how I route the oil drain line. There is nothing aftermarket as far as AN fitting you can use on the block that will clear the T-case. All you can is chop the OEM piece and somehow have a hose joining that upstream. I will post pics of it later. This is an experiment I did. Took an MS3 slave cylinder to the 6. The pedal feel was about 75% less. But it did not travel enough to completly release the TOP from puting pressure on the fingers of the clutch plate. The piston OD of the MS3 slacve is about twice that of the MS6 and it only works with the master cylinder of the MS3 which probably also has a bigger piston than the MS6 and so pushes a lot more fluid. Oh and this is the panel for the gauges I posted on your thread.
| The Following 11 Users Say Thank You to Tomas For This Useful Post: | 802MS3 (07-28-2014), brandon3212 (09-23-2014), chaser27 (08-06-2014), Code Monkey (07-28-2014), daafisch (07-28-2014), Easter Bunny (07-29-2014), Mauro_Penguin (09-10-2014), Nliiitend1 (07-28-2014), phate (07-28-2014), Vader (08-05-2014), WetzMS3 (07-28-2014) |
![]() Awaiting pictures.
__________________ 2006 Mazdaspeed6 EFR 7163|FMIC|South Bend|FCM coilovers|Powerbrake BBK|RPF1 18x10.5|Nitto NT01 stripped|caged|freektuned 2017 Subaru BRZ MCS TT1 coilovers|Brembo BBK|6UL 17x9|RE-71R|ACE 350|flex fuel|Delicious tuned | |
| The Following User Says Thank You to Code Monkey For This Useful Post: | Tomas (07-29-2014) |
![]() | | #19 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well yeah dude. If you are going to weld and machine parts then anything is possible. Ain't nobody got time for that.
| The Following User Says Thank You to Tomas For This Useful Post: | Code Monkey (07-29-2014) |
![]() | | #20 | ![]() |
(Thread Starter) | Not Ranked : 0 score Okeedokee. It is done. Car runs. This terboh is pure awesome sauce. Response is almost same as stock turbo. Got a new clutch so still breaking that in. Damn steering column got separated when I dropped the subframe. What a pain in the ass to get that back in. Decided to dismount the whole steering wheel unit instead of dropping the subframe again. Juggling the steering unit with one hand while trying to stab the spline shafts of the column provided tons of joy.
| The Following 17 Users Say Thank You to Tomas For This Useful Post: | 802MS3 (08-06-2014), btstarcher (08-06-2014), chaser27 (08-06-2014), Code Monkey (08-05-2014), daafisch (08-05-2014), Downmented (09-10-2014), Easter Bunny (08-05-2014), Lex (08-05-2014), Mauro_Penguin (09-10-2014), Micha (03-05-2015), phate (08-05-2014), Pu Manchu (08-06-2014), sac02 (09-18-2014), SofaKingAwesome (08-05-2014), UnknownSuperhero (09-22-2014), Vader (08-05-2014), WetzMS3 (08-05-2014) |
![]() | | #21 | ![]() |
| Not Ranked : 0 score you didn't use the word shaft enough
| The Following 4 Users Say Thank You to Easter Bunny For This Useful Post: |
![]() | | #22 | ![]() |
(Thread Starter) | Not Ranked : 0 score shaft.
| The Following 4 Users Say Thank You to Tomas For This Useful Post: | Downmented (09-10-2014), Easter Bunny (08-06-2014), Koke382 (11-19-2014), Monotonous ONE (11-04-2014) |
![]() | | #23 | ![]() |
![]() Join Date: May 2009 Location: Russellville, AR
Rep Power: 1975 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,199
| Not Ranked : 0 score This thread is full of awesome. In for progress.
__________________ JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, Forge V2 BPV, JBR TIG's, Kozmic EGR delete, Cobb AP, PTP HPFP internals, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Swift springs, Tri Point Engineering RSB, Whiteline Anti Lift Kit, PTP Injector Seals, GenPu transmission, Fidanza flywheel, 3 BAR MAP sensor, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, sleeved block, PTP BSD SnailTune in progress |
| The Following User Says Thank You to btstarcher For This Useful Post: | Tomas (11-04-2014) |
![]() | | #24 | ![]() |
Groans: 221
| Not Ranked : 0 score more more more. we are expecting you to drive around in circles until you complete the clutch break-in, and then immediately post vids and logs.
| The Following 2 Users Say Thank You to 802MS3 For This Useful Post: | Easter Bunny (08-06-2014), Tomas (11-04-2014) |
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score I have a neat idea for repositioning the power steering fluid reservoir. Awesomeness awaits.
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score Some more advancements. Ron Davis Rad installed. This thing is massive. 36mm core thickness compared to the 16mm core thickness of the stock one. Should be much better than the Koyo rad I have on the 3 which only has a marginally thicker core. Also started fucking around with the FMIC.
| The Following 5 Users Say Thank You to Tomas For This Useful Post: | 802MS3 (09-10-2014), btstarcher (09-10-2014), Code Monkey (09-10-2014), Easter Bunny (09-10-2014), Mauro_Penguin (09-10-2014) |
![]() | | #27 | ![]() |
| Not Ranked : 0 score So the fucking tab is off on yours too.... If you feel like it, call Bill Williamson at Ron Davis at 1-800-842-5166 -- he wanted a very accurate measurement of the tab spacing on our cars, up to a 1/1000" I think, something I could not provide him with.
![]() | | #28 | ![]() |
(Thread Starter) | Neutral : +1 score Lemme see if I get this. The tab is in the wrong place. Vendor wants customer to do the legwork for correcting the problem. Customer does not get anything in return. My idea of a vendor customer relationship seems to be all wrong for thinking that the vendor should get off their fucking ass and find an MS6 shroud they can measure themselves.
| The Following 7 Users Say Thank You to Tomas For This Useful Post: | 802MS3 (09-10-2014), Downmented (09-12-2014), Easter Bunny (09-10-2014), Mauro_Penguin (09-10-2014), phate (09-10-2014), Pu Manchu (09-11-2014), Tokay444 (09-17-2014) |
![]() | | #29 | ![]() |
![]() Join Date: Sep 2012 Location: London Ontario Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 338
| Not Ranked : 0 score Sub'd for epic thread |
| The Following User Says NO Thank You to brandon3212 For This Un-useful Post: | Easter Bunny (09-17-2014) |
![]() | | #30 | ![]() |
![]() Join Date: Jun 2011 Location: Laurel, Maryland
Rep Power: 3780 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,647
Groans: 493
| Not Ranked : 0 score Go to top of thread page, Click "thread tools" and then click "subscribe to thread" This is your one freebie, never let it happen again.
__________________ //KILLAH BUILT, SPEED PERF6RMANC3, TUNED BY THE SUPERSKATER// 700HP CLUB Former World Record Mazdaspeed 60' 1.603 11.479@124mph 10second car with an 11second driver #DIX -Builds 700hp MS6, buys miata, sells said MS6! |
| The Following 7 Users Say Thank You to Downmented For This Useful Post: | brandon3212 (09-17-2014), btstarcher (09-17-2014), daafisch (09-19-2014), Easter Bunny (09-17-2014), magicka (09-17-2014), Mauro_Penguin (09-23-2014), Voltwings (09-17-2014) |
![]() | | #31 | ![]() |
| jbr makes fall-a-parts. ![]() Join Date: Jan 2011 Location: Cambridge Ontario Canada
Rep Power: 13536 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,744
Groans: 793
| Not Ranked : 0 score You're gonna need a new mani, downpipe and TiAL efr turbine housing...
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals |
| The Following User Says Thank You to Tokay444 For This Useful Post: | Tomas (11-04-2014) |
![]() | | #32 | ![]() |
| Not Ranked : 0 score What's wrong with the Full Race manifold he has now?
![]() | | #33 | ![]() |
Groans: 793
| Not Ranked : 0 score It doesn't take a TiAL v-band hotside...
| The Following 2 Users Say Thank You to Tokay444 For This Useful Post: | btstarcher (09-17-2014), Tomas (11-04-2014) |
![]() | | #34 | ![]() |
| Not Ranked : 0 score Jbweld will take care of that.
| The Following 2 Users Say Thank You to Easter Bunny For This Useful Post: | Downmented (09-18-2014), Tomas (11-04-2014) |
![]() | | #35 | ![]() |
(Thread Starter) | Not Ranked : 0 score In what and to whom are you referring?
![]() | | #36 | ![]() |
Groans: 793
| Not Ranked : 0 score In the dark, I'm referring to you.
![]() | | #37 | ![]() |
(Thread Starter) | Not Ranked : 0 score The FR mani comes with a T25 flange which fits the T25 turbine housing on the 7163. No Tial housing needed here.
![]() | | #38 | ![]() |
Groans: 793
| Not Ranked : 0 score T25 is tiny.
![]() | | #39 | ![]() |
(Thread Starter) | Not Ranked : 0 score I hais tiny penis.
![]() | | #40 | ![]() |
Groans: 793
| Not Ranked : 0 score Circumcised or non?
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f233/dildo-blitz-169330/ | ||||
| Reedy's Engine Rebuild Bonanza! - Page 20 | Post #87 | Pingback | 03-04-2015 11:07 PM | |
| Blitz K3T | Twinturbo6 | MazdaSpeed 3/6 - Big Turbo Builds | 1 | 11-04-2013 02:34 PM |
| Blitz Air Filter | USAFDentist | 2010 MS3 - Turbo Induction | 6 | 02-16-2012 01:05 PM |
| Blitz Type O1 | clown_car | MazdaSpeed 3/6 - Wheels & Tires | 2 | 03-20-2009 01:26 PM |
