Autosports Area
Like Tree51Likes
 Old 04-24-2014, 09:10 PM   #1
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Default Dildo Blitz
EFR 7163
I haz it.
Stay tuned homos.
stanley0910 likes this.
The Following 19 Users Say Thank You to Tomas For This Useful Post:
802MS3 (04-29-2014), breakfstincluded (09-10-2014), BrianB6 (04-29-2014), ButtholeRedMS3 (12-27-2015), Code Monkey (04-24-2014), cshunter (04-27-2014), daafisch (04-29-2014), derek13p (07-28-2014), Easter Bunny (04-25-2014), Enki (11-25-2014), gmoney542 (04-27-2014), helmetface (04-29-2014), Jh8909 (04-25-2014), lazza151 (09-20-2019), Mauro_Penguin (09-10-2014), Micha (03-05-2015), ms3blackmica (04-25-2014), SofaKingAwesome (08-05-2014), WetzMS3 (04-24-2014)
 Old 04-24-2014, 09:13 PM   #2
Easter Bunny (04-25-2014), Jh8909 (04-25-2014), Tomas (04-24-2014)
 Old 04-24-2014, 09:15 PM   #3
Bob Ross Fanclub
Tomas's Avatar
^ Your gonna like what's coming.
It's going on the 6.
+ other ghey goodies.
Code Monkey likes this.
The Following 6 Users Say Thank You to Tomas For This Useful Post:
Code Monkey (04-24-2014), Easter Bunny (04-25-2014), Jh8909 (04-25-2014), Mauro_Penguin (09-10-2014), phate (04-29-2014), SofaKingAwesome (08-05-2014)
 Old 04-24-2014, 09:18 PM   #4
Already fapped.
Twice.
Easter Bunny (04-25-2014), helmetface (07-28-2014), Mase (07-29-2014), Tomas (04-25-2014)
 Old 04-24-2014, 10:08 PM   #5
Easter Bunny (04-25-2014), Tomas (04-25-2014)
 Old 04-25-2014, 01:57 PM   #6
Bob Ross Fanclub
Tomas's Avatar
Nliiitend1 likes this.
The Following 17 Users Say Thank You to Tomas For This Useful Post:
802MS3 (04-29-2014), Code Monkey (04-25-2014), Crarrs (04-26-2014), cshunter (04-27-2014), Easter Bunny (04-25-2014), helmetface (07-28-2014), Ingle (11-03-2014), jtday (04-29-2014), magicka (08-06-2014), Mase (07-29-2014), Mauro_Penguin (09-10-2014), Neverlift (09-06-2015), Nliiitend1 (07-28-2014), phate (04-29-2014), sac02 (09-18-2014), Vader (08-05-2014), WetzMS3 (04-25-2014)
 Old 04-25-2014, 02:22 PM   #7
Can you post a picture of the oil drain line that comes with the kit?
Voltwings (08-05-2014)
 Old 04-25-2014, 02:31 PM   #8
Bob Ross Fanclub
Tomas's Avatar
There is no oil drain line in the kit. Only an AN-10 fitting.
 Old 04-25-2014, 02:59 PM   #9
Can you please post how you rigged the oil drain line once the turbo goes in? The fitting is custom I assume and clears the T-case?
 Old 04-25-2014, 03:04 PM   #10
This here I know will be good if you can get past all the homoerotic stuff.
Tomas (04-29-2014)
 Old 04-29-2014, 07:50 AM   #11
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
mm mmm digressive piston and shim kits. What else are you doing with the suspension?
-06 MS6
-Corn fed 07 MS3 - Sold
 Old 04-29-2014, 09:59 AM   #12
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
you are so underrated on this forum.
'08 CWP MS3 w/ T3 3071r
The Following 6 Users Say Thank You to 802MS3 For This Useful Post:
Easter Bunny (07-29-2014), Koke382 (11-19-2014), Mauro_Penguin (09-10-2014), ms3blackmica (04-29-2014), Tomas (04-29-2014), WetzMS3 (04-29-2014)
 Old 04-29-2014, 11:41 AM   #13
Bob Ross Fanclub
Tomas's Avatar
^ I luv you too muffin.
yessum.
On the rear Bills I am going to try a few different valving combinations. Also want to try the COB (compression only bypass) shims that Bilstein has for these. At some point I might buy the double adjustable shafts. But they are about $340 a piece and if you get the valving right aren't really needed. They are fucking kewl as shit though and easily interchangeable. The bushings for the hem joints on the housings I had to fabricate pictured below would still work.
For the fronts I don't know yet. Might do the OTS Bils converted to take apart. I am gonna wait and see how yours come out.
Nitrogen.
I hais it.
In case anyone needs to know, although I doubt it, the bushings need to be exactly 23mm wide for both the lower and the upper brackets. M12 bolt.
The Following 9 Users Say Thank You to Tomas For This Useful Post:
Code Monkey (04-29-2014), Easter Bunny (07-29-2014), Koke382 (11-19-2014), Mauro_Penguin (09-10-2014), Micha (03-05-2015), ms3blackmica (04-29-2014), phate (04-29-2014), sac02 (09-18-2014), WetzMS3 (04-29-2014)
 Old 04-29-2014, 12:34 PM   #14
Eth Fiend
phate's Avatar
Nitrogen.
I hais it.
Hmmm...what I think you're telling me is that I can invert the OTS Bils in the rear to save some unsprung weight....just need those fancy boots you have so it doesn't collect dirt. I've thought about converting to spherical bearings in my bilsteins, but I didn't measure the mounts when I had the bilsteins sitting here, and I don't think they're legal for my class, anyway.
My bils are supposedly going to be finished this week, but I don't have high hopes for this actually happening.
Very cool stuff, excited to see another MS6 with a nice setup.
-06 MS6
derek13p (07-28-2014), Mauro_Penguin (09-10-2014), Tomas (04-29-2014)
 Old 04-29-2014, 12:48 PM   #15
Bob Ross Fanclub
Tomas's Avatar
Yes, you can run monotubes up side down. Not twin tubes though.
shock boot | eBay
The Following 3 Users Say Thank You to Tomas For This Useful Post:
Easter Bunny (07-29-2014), Mauro_Penguin (09-10-2014), phate (04-29-2014)
 Old 07-27-2014, 11:08 PM   #16
Wtf, updates, I'm losing sleep here.
802MS3 (07-28-2014), Easter Bunny (07-29-2014)
 Old 07-28-2014, 12:57 PM   #17
Bob Ross Fanclub
Tomas's Avatar
Yes sir!
Dropped the tranny. Changed clutch to ferramic / kevlar.
Dropped T-case. Exchanged shafts with CX-7 T-case.
Mounted tranny back on (you may interpret that anyway you want)
Rerouted heater hoses to clear terboh WG actuator.
Currently in the process of mounting turbo and routing cooling water lines to and from turbo. Also oil drain line back into block. I now know why you wanted to see how I route the oil drain line. There is nothing aftermarket as far as AN fitting you can use on the block that will clear the T-case. All you can is chop the OEM piece and somehow have a hose joining that upstream. I will post pics of it later.
This is an experiment I did. Took an MS3 slave cylinder to the 6. The pedal feel was about 75% less. But it did not travel enough to completly release the TOP from puting pressure on the fingers of the clutch plate. The piston OD of the MS3 slacve is about twice that of the MS6 and it only works with the master cylinder of the MS3 which probably also has a bigger piston than the MS6 and so pushes a lot more fluid.
Oh and this is the panel for the gauges I posted on your thread.
The Following 11 Users Say Thank You to Tomas For This Useful Post:
802MS3 (07-28-2014), brandon3212 (09-23-2014), chaser27 (08-06-2014), Code Monkey (07-28-2014), daafisch (07-28-2014), Easter Bunny (07-29-2014), Mauro_Penguin (09-10-2014), Nliiitend1 (07-28-2014), phate (07-28-2014), Vader (08-05-2014), WetzMS3 (07-28-2014)
 Old 07-28-2014, 04:27 PM   #18
I like this solution, linky1 and linky2.
Awaiting pictures.
Tomas (07-29-2014)
 Old 07-29-2014, 08:44 AM   #19
Bob Ross Fanclub
Tomas's Avatar
Well yeah dude. If you are going to weld and machine parts then anything is possible.
Ain't nobody got time for that.
Code Monkey (07-29-2014)
 Old 08-05-2014, 08:23 AM   #20
Bob Ross Fanclub
Tomas's Avatar
Okeedokee.
It is done.
Car runs. This terboh is pure awesome sauce. Response is almost same as stock turbo. Got a new clutch so still breaking that in.
Damn steering column got separated when I dropped the subframe. What a pain in the ass to get that back in. Decided to dismount the whole steering wheel unit instead of dropping the subframe again. Juggling the steering unit with one hand while trying to stab the spline shafts of the column provided tons of joy.
802MS3 (08-06-2014), btstarcher (08-06-2014), chaser27 (08-06-2014), Code Monkey (08-05-2014), daafisch (08-05-2014), Downmented (09-10-2014), Easter Bunny (08-05-2014), Lex (08-05-2014), Mauro_Penguin (09-10-2014), Micha (03-05-2015), phate (08-05-2014), Pu Manchu (08-06-2014), sac02 (09-18-2014), SofaKingAwesome (08-05-2014), UnknownSuperhero (09-22-2014), Vader (08-05-2014), WetzMS3 (08-05-2014)
 Old 08-05-2014, 10:54 AM   #21
you didn't use the word shaft enough
Koke382 (11-19-2014), Monotonous ONE (11-04-2014), Tomas (11-26-2014), Vader (08-05-2014)
 Old 08-06-2014, 06:47 AM   #22
Bob Ross Fanclub
Tomas's Avatar
shaft.
The Following 4 Users Say Thank You to Tomas For This Useful Post:
Downmented (09-10-2014), Easter Bunny (08-06-2014), Koke382 (11-19-2014), Monotonous ONE (11-04-2014)
 Old 08-06-2014, 07:09 AM   #23
btstarcher's Avatar
Posts: 4,852   (View Stats)
This thread is full of awesome. In for progress.
SnailTune in progress
Tomas (11-04-2014)
 Old 08-06-2014, 07:29 AM   #24
rabble rabble
802MS3's Avatar
Groans: 221
more more more. we are expecting you to drive around in circles until you complete the clutch break-in, and then immediately post vids and logs.
Easter Bunny (08-06-2014), Tomas (11-04-2014)
 Old 08-06-2014, 01:42 PM   #25
Bob Ross Fanclub
Tomas's Avatar
I have a neat idea for repositioning the power steering fluid reservoir.
Awesomeness awaits.
btstarcher (08-06-2014), Mauro_Penguin (09-10-2014), Monotonous ONE (11-04-2014)
 Old 09-10-2014, 12:17 PM   #26
Bob Ross Fanclub
Tomas's Avatar
Some more advancements.
Ron Davis Rad installed. This thing is massive. 36mm core thickness compared to the 16mm core thickness of the stock one. Should be much better than the Koyo rad I have on the 3 which only has a marginally thicker core.
Also started fucking around with the FMIC.
The Following 5 Users Say Thank You to Tomas For This Useful Post:
802MS3 (09-10-2014), btstarcher (09-10-2014), Code Monkey (09-10-2014), Easter Bunny (09-10-2014), Mauro_Penguin (09-10-2014)
 Old 09-10-2014, 12:34 PM   #27
So the fucking tab is off on yours too.... If you feel like it, call Bill Williamson at Ron Davis at 1-800-842-5166 -- he wanted a very accurate measurement of the tab spacing on our cars, up to a 1/1000" I think, something I could not provide him with.
btstarcher (09-10-2014), Easter Bunny (09-10-2014), Tomas (09-10-2014)
 Old 09-10-2014, 01:22 PM   #28
Bob Ross Fanclub
Tomas's Avatar
Neutral  +1 score
Lemme see if I get this.
The tab is in the wrong place.
Vendor wants customer to do the legwork for correcting the problem.
Customer does not get anything in return.
My idea of a vendor customer relationship seems to be all wrong for thinking that the vendor should get off their fucking ass and find an MS6 shroud they can measure themselves.
The Following 7 Users Say Thank You to Tomas For This Useful Post:
802MS3 (09-10-2014), Downmented (09-12-2014), Easter Bunny (09-10-2014), Mauro_Penguin (09-10-2014), phate (09-10-2014), Pu Manchu (09-11-2014), Tokay444 (09-17-2014)
 Old 09-16-2014, 07:12 PM   #29
brandon3212's Avatar
Posts: 425   (View Stats)
Sub'd for epic thread
The Following User Says NO Thank You to brandon3212 For This Un-useful Post:
Easter Bunny (09-17-2014)
 Old 09-17-2014, 06:32 AM   #30
Downmented's Avatar
Posts: 3,040   (View Stats)
Groans: 493
Go to top of thread page, Click "thread tools" and then click "subscribe to thread"
This is your one freebie, never let it happen again.
700HP CLUB
11.479@124mph
#DIX
The Following 7 Users Say Thank You to Downmented For This Useful Post:
brandon3212 (09-17-2014), btstarcher (09-17-2014), daafisch (09-19-2014), Easter Bunny (09-17-2014), magicka (09-17-2014), Mauro_Penguin (09-23-2014), Voltwings (09-17-2014)
 Old 09-17-2014, 08:16 AM   #31
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
You're gonna need a new mani, downpipe and TiAL efr turbine housing...
"Exclusivity" - CP-enis
Demodded.
The Seals
Tomas (11-04-2014)
 Old 09-19-2014, 06:09 AM   #32
Bob Ross Fanclub
Tomas's Avatar
In what and to whom are you referring?
 Old 09-17-2014, 12:32 PM   #33
btstarcher's Avatar
What's wrong with the Full Race manifold he has now?
Tomas (11-04-2014)
 Old 09-17-2014, 05:15 PM   #34
Tokay444's Avatar
Groans: 793
It doesn't take a TiAL v-band hotside...
Demodded.
The Seals
btstarcher (09-17-2014), Tomas (11-04-2014)
 Old 09-17-2014, 08:12 PM   #35
Jbweld will take care of that.
Downmented (09-18-2014), Tomas (11-04-2014)
 Old 09-19-2014, 07:34 AM   #36
Tokay444's Avatar
Groans: 793
In the dark, I'm referring to you.
Demodded.
The Seals
Tomas (11-04-2014)
 Old 09-19-2014, 11:57 AM   #37
Bob Ross Fanclub
Tomas's Avatar
The FR mani comes with a T25 flange which fits the T25 turbine housing on the 7163.
No Tial housing needed here.
btstarcher (09-19-2014), daafisch (09-19-2014), Downmented (09-22-2014)
 Old 09-21-2014, 03:23 PM   #38
Tokay444's Avatar
Groans: 793
T25 is tiny.
Demodded.
The Seals
 Old 09-21-2014, 05:36 PM   #39
Bob Ross Fanclub
Tomas's Avatar
I hais tiny penis.
 Old 09-21-2014, 06:24 PM   #40
Tokay444's Avatar
Groans: 793
Circumcised or non?
Demodded.
The Seals
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f233/dildo-blitz-169330/
Reedy's Engine Rebuild Bonanza! - Page 20 Post #87 Pingback 03-04-2015 11:07 PM
Blitz K3T Twinturbo6 MazdaSpeed 3/6 - Big Turbo Builds 1 11-04-2013 02:34 PM
Blitz Air Filter USAFDentist 2010 MS3 - Turbo Induction 6 02-16-2012 01:05 PM
Blitz Type O1 clown_car MazdaSpeed 3/6 - Wheels & Tires 2 03-20-2009 01:26 PM
Page generated in 0.78818 seconds with 31 queries
