Autosports Area
 Old 02-19-2018, 10:50 AM   #1
ChaunceyM's Avatar
Posts: 948   (View Stats)
ChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the world
Default Oil Cooler, Prime system?
Installing an oil cooler with a mishimoto thermostatic plate. Should I try to fill up the cooler system before I fire up the engine? I'm concerned that once the oil hits 185F for the first time and sends oil up to the radiator that pocket of air that gets pumped back in is going to create a brief starvation. And since it's thermostatically controlled, I can't just crank the engine to circulate oil. It's gotta be hot before it opens.
Corksport: SRI & TIP, Strut Tower Brace, Coilovers
CP-e: RMM
JBR: Rear Sway Bar (with Moog End Links)
TWM: Full Replacement Shifter
Cobb: AP
AutoTech: HPFP Internals
Ebay: Test Pipe
ChaunceyM is offline   Reply With Quote
The Following 2 Users Say Thank You to ChaunceyM For This Useful Post:
Db09ms3 (02-19-2018), roguemazda (02-19-2018)
 Old 02-19-2018, 12:05 PM   #2
kTaLgsTo's Avatar
Posts: 566   (View Stats)
I would personally. I also fill my oil filters half way when I install them on changes.
The Following User Says Thank You to kTaLgsTo For This Useful Post:
 Old 02-19-2018, 01:56 PM   #3
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
That is actually a very good question. I'd almost be willing to bet that at least some fluid flows through the cooler at all times. You could possibly check the seat pressure of the oil thermostat. If it's less than your normal oil pressure, it will be slightly open during normal operation...I think.
Edit: Just occurred to me...the thermostat doesn't snap open, it gradually opens as the oil warms up. So you won't get a sudden "no oil" situation.
What made you decide to install an aux oil cooler?
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
JSmith (02-19-2018)
 Old 02-19-2018, 02:43 PM   #4
shamie's Avatar
Posts: 952   (View Stats)
Mishimoto has 2 types of thermostatic plates - one is fully closed until it reaches temp (front thermostat) and one restricts most oil before it reaches temp (rear thermostat). Which one do you have?
For your question, I'd pre-fill it if you can. I'll be putting one (MMOC-DP-M) in next month but won't be able to pre-fill since the outputs will be on the side. JBR's outlets are on the bottom so no pre-filling there either. I'd also worry about that one emptying back into the pan every time you shut the engine off.
 Old 02-20-2018, 08:31 AM   #5
ChaunceyM's Avatar
Partly as a safegaurd during summer track days. Some of those July and August days have ambients in the upper 90s and it's just not something I want to worry about.
Partly just to do it. At this point I'm using the MS3 as for learning purposes. Both driving technique and physical work. There'll be plenty more stuff I'm doing 'just because' for the experience aspect of it.
Front therm.
And I didn't even think about it draining into the pan during rest. Although when the thermostat closes it should cut that off.
Before the first start I'll probably pull the top connector off and funnel in as much oil as I can. Then drive it around and hope it doesn't go pop!
CP-e: RMM
Cobb: AP
Ebay: Test Pipe
 Old 02-20-2018, 10:44 AM   #6
shamie's Avatar
How will your cooler be oriented?
 Old 02-20-2018, 11:36 AM   #7
ChaunceyM's Avatar
Right now the connections will be on the side, but depending on where exactly I mount it they might be on the bottom. If it's side, I could "easily" unscrew the top hose and fill with oil.
CP-e: RMM
Cobb: AP
Ebay: Test Pipe
 Old 02-20-2018, 12:54 PM   #8
shamie's Avatar
What cooler are you using? Do you have a FMIC?
 Old 03-17-2018, 05:21 AM   #9
ChaunceyM's Avatar
System all connected and working. No leaks and oil is definitely routed through the cooler. Making the custom hoses wasn't as tricky as I expected, although I need to get a better method of cutting the hose. Still have to connect the temp gauge, but that's not critical. I'll get it on before summer track days.
Gotta move on to brake ducts and rear caliper replacement...
CP-e: RMM
Cobb: AP
Ebay: Test Pipe
 Old 03-29-2018, 10:59 PM   #10
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
photobucket, yikes.
94 M
MS6
IS350
The Following User Says Thank You to Pu Manchu For This Useful Post:
kTaLgsTo (03-30-2018)
Prime time for big pickups Haltech Automotive News 0 01-20-2013 10:10 PM
Last chance to enter to win a Garage and Hardware Storage System from Flow Wall System! Haltech Automotive News 0 06-21-2012 10:10 AM
Megatron or Optimus Prime???? emag remrofni Mazdaspeed3/6 General Discussion 4 03-03-2011 03:26 PM
Page generated in 0.30580 seconds with 24 queries
