Autosports Area
 Old 10-11-2016, 05:17 PM   #1
EvoFire's Avatar
Posts: 389   (View Stats)
Default Tires in the Rain
I have a set of half worn Bridgestone S-04 Pole Position that I use on the street.
I also have a set of half worn NT-01 for dry events.
Now I have a track day that will most likely be wet this Saturday. Which would be a better bet?
The Bridgestones are at a point where they don't clear puddles well at 70mph.
 Old 10-11-2016, 07:21 PM   #2
sheston's Avatar
Posts: 1,847   (View Stats)
I used to have some NT-05s that would hydroplane when the road even looked wet. I can't imaging you would be able to control the NT-01s in the rain
Maybe I just need a driver mod
 Old 10-11-2016, 08:44 PM   #3
CMajor's Avatar
Posts: 65   (View Stats)
CMajor has a reputation beyond reputeCMajor has a reputation beyond reputeCMajor has a reputation beyond reputeCMajor has a reputation beyond reputeCMajor has a reputation beyond reputeCMajor has a reputation beyond reputeCMajor has a reputation beyond reputeCMajor has a reputation beyond reputeCMajor has a reputation beyond reputeCMajor has a reputation beyond reputeCMajor has a reputation beyond repute
That's weird, I actually think my NT-05s handle pretty well in the rain haha. I will say if there's a larger puddle I feel my car hydroplane but just moderate/heavy raining I've never had an issues on flat roads.
2013 MS3 w/ tech - LSM
ZZB - 10/27/16, Let the build commence!
Car is under construction...
1969 Camaro: Next project
CMajor is offline   Reply With Quote
 Old 10-12-2016, 03:30 PM   #4
EvoFire's Avatar
I autocrossed the NT-01 when raining 2 weeks ago, and I can lift a wheel on wet tarmac.
I'm 83% sure that even on wet tarmac, if up to temperature, the NT-01 would out grip the Bridgestones. But my worry is standing water, and from the looks of the weather forecast, there will be LOTS of standing water.
 Old 10-13-2016, 12:58 PM   #5
ChaunceyM's Avatar
Posts: 948   (View Stats)
ChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the world
I tried to run my NT-01s on a cool, wet track (NJMP Thunderbolt) and it was a f'n disaster. Granted they never got up to temp, but I just couldn't trust them to bite in any turn. Straight-line braking was okay, but as soon as I'd turn I'd lose the rear end. Maybe if I softened the rear suspension it'd be better but it just wasn't enjoyable.
Corksport: SRI & TIP, Strut Tower Brace, Coilovers
CP-e: RMM
JBR: Rear Sway Bar (with Moog End Links)
TWM: Full Replacement Shifter
Cobb: AP
AutoTech: HPFP Internals
Ebay: Test Pipe
ChaunceyM is offline   Reply With Quote
The Following 2 Users Say Thank You to ChaunceyM For This Useful Post:
Code Monkey (10-13-2016), EvoFire (10-13-2016)
 Old 10-13-2016, 01:38 PM   #6
^ I have a similar experience.
 Old 10-13-2016, 02:06 PM   #7
EvoFire's Avatar
Bridgestone it is
 Old 10-13-2016, 03:15 PM   #8
ChaunceyM's Avatar
Is it sad that I actually smiled reading that Code Monkey validated my experience? Cause that happened.
Yeah, it's been a long year of lessons, both here (asking questions 15 steps beyond where my actual skill is) and the track.
CP-e: RMM
Cobb: AP
Ebay: Test Pipe
The Following User Says Thank You to ChaunceyM For This Useful Post:
 Old 10-18-2016, 05:42 AM   #9
StevenW's Avatar
Posts: 268   (View Stats)
StevenW is the leader of the worldStevenW is the leader of the worldStevenW is the leader of the worldStevenW is the leader of the worldStevenW is the leader of the worldStevenW is the leader of the worldStevenW is the leader of the worldStevenW is the leader of the worldStevenW is the leader of the worldStevenW is the leader of the worldStevenW is the leader of the world
Groaned at 8 Times in 7 Posts
Curious as to what you ended up running and how they were in the rain. Any news?
StevenW is offline   Reply With Quote
 Old 10-19-2016, 04:36 PM   #10
EvoFire's Avatar
I ended up running the Bridgestones because I didn't know if the NT-01 would bring any benefit despite all the work of hauling the setup to the track and swapping, and the forecast of up to 2" of rain.
I was a little disappointed in the morning because it was mostly dry, then the heavens opened up at around 11am and didn't stop for the whole day. Glad I didn't swap wheels and tires.
The Bridgestones are close to the wear bars now after the track day, but the only things it lost to were two STi's with newer/better tires than I did. Only in the rain would I be able to thoroughly beat E90 M3s.
In the morning when it was dry I think it would have been great to run the R-comps. When it started raining it was all over.
The Following User Says Thank You to EvoFire For This Useful Post:
StevenW (10-31-2016)
New tires , stock wheels / bring on the rain huffentuff09 Mazdaspeed3/6 General Discussion 1 11-30-2010 02:32 PM
Does Homelink Mirror rain sensor replace OEM rain sensor? Chinsel MazdaSpeed 3/6 - Car Audio & Electronics 5 02-25-2010 11:36 AM
Spoiler Alert: Rain, Rain Go Away! Downpour makes Petit Le Mans even more so Haltech Automotive News 0 09-28-2009 01:50 PM
Q Tires testing Celsius retractable-stud snow tires Haltech Automotive News 0 04-01-2008 10:40 AM
Page generated in 0.29256 seconds with 25 queries
