Miata MX-5
> Miata - Engine Conversions
Like Tree8Likes
 Old 06-08-2017, 12:12 PM   #41
aackthpt's Avatar
Posts: 1,450   (View Stats)
Yes! Moar boost! And we want a build thread with every step. And kits, we want kits. LOL
2013 'speed3, silver
Stage Bro
The Following User Says Thank You to aackthpt For This Useful Post:
mituc (06-09-2017)
 Old 07-11-2017, 04:01 PM   #42
Cdnspeed6's Avatar
Posts: 139   (View Stats)
Cdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond repute
Already on it lol
Decided that the DISI isn't worth it and swapped on a 2.3 head on to the DISI block
Miata ECU plugs into the Rx8 harness, i think ill need to swap some pins around
Coles notes, do it in an NC miata, then realize its not worth it and just bolt on a turbo.
In an rx8 you basically need the front clip from an NC miata,
the nc miata subframe bolts into the Rx8 arms swap over.
Nc transmission with S2 rx8 tailshaft pretty much bolts into the rx8 and no custom driveshaft/ppf are needed.
you can swap over the Full cooling system from an NC into the 8 with minimal effort
use a Miata ecu and cluster, the cluster nearly bolts into the stock rx8 dash.
miata ecu and a Port injection imo are better for making power ECUtek is pretty slick.
mituc likes this.
2007 Speed6- Cp-e RMM, M2 Downpipe, BNRS3V2, HKS SSQV
CS FMIC, CS TIP, CS SRI, CS HPFP, H&R coilovers
Cdnspeed6 is offline   Reply With Quote
The Following 4 Users Say Thank You to Cdnspeed6 For This Useful Post:
aackthpt (07-13-2017), JSmith (07-13-2017), mituc (07-12-2017), [R]usty (07-12-2017)
 Old 07-12-2017, 07:59 AM   #43
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Awesome!
Well, i already have the Mazdaspeed3 engine, so I'm going to stick with that. Also I'd like to keep the versatility of the Versatuner, so I'll use a speed3 ECU.
How deep did you have to cut the cabin wall to make room for the DISI block + transmission?
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 07-13-2017, 08:20 PM   #44
Cdnspeed6's Avatar
it's pretty far back into the cabin, just so i could get the shifter in the oem location and line up the Miata mounts on the Miata subframe. ill say that the Hvac wont fit back in the car
Speed3 Ecus requires speed3 Cluster, speed3 cluster doesnt fit in the rx8 dash
Miata uses ECUtek which is far nicer than Versatuner.
The Following User Says Thank You to Cdnspeed6 For This Useful Post:
mituc (07-14-2017)
 Old 07-14-2017, 12:23 AM   #45
mituc's Avatar
Groans: 111
Ok, so my dream of having a 100% streetable RX8 with a DISI-T engine kind of shattered... No HVAC means no streetability and I can't register it either.
For me the only good thing now is that I didn't start the build and find all these things out on the way, but with quite a bit of time ahead of starting any investment into a chassis, labour, and so on.
Well, now I have an expensive 2.3.DISI-T engine in a mint condition with uprated parts and no chassis to put it to work into. And I'm not willing to build another speed3 or even 6... dang...
 Old 07-14-2017, 08:40 AM   #46
Cdnspeed6's Avatar
youre you just wont have any room for the HPFP, then you would need a custom turbo manifold, an ecoboost mustang intake manifold could be used,
you could also try an ecoboost mustang trans to get the shifter where you want it and push the motor further forward
mituc (07-14-2017)
Page generated in 0.27724 seconds with 21 queries
