Groans: 111
(Thread Starter) | Not Ranked : 0 score So I'm going to have a spare engine from my 3MPS (Mazdaspeed3 gen1) and instead of throwing it in a dark and cold storage I thought I could throw it in an MX5. Of course I may need to fabricate some adapter rings for the transmission, fabricate some motor mounts to mount it transversely, possibly alter the manifolds and clock the turbo (or fit a mirrored turbo), but I thought I'd find more info about what the challenges may be and didn't really find anything. So do you guys have any knowledge about anyone who did this or at least attempted it and failed, so that I can at least chase that thought away and try something else instead? Thank you!
| The Following 5 Users Say Thank You to mituc For This Useful Post: | markos213 (04-21-2017), mazdakaps (05-17-2017), MSMS3 (05-06-2017), Yamahafreak (05-11-2017), [R]usty (04-21-2017) |
![]() Join Date: Sep 2012 Location: Los Angeles, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,205
| Not Ranked : 0 score OMG do it! So much better than an LS swap.
__________________ 2010 Mazdaspeed3 w/tech Cobb AP V3 ║ JBR Tru 3" Wide Path ║ JBR Boost Tubes & BPV Hose ║ Cobb XLE BPV ║ CP-E TMIC ║ UR Racepipe ║ Magnaflow CBE ║ AutoTech Internals ║ GrimmSpeed EBCS ║ JBR RSB ║ SPC Camber Arms ║ KW V3 Coilovers ║ JBR IM+TB TIGs & TB Bypass ║ JBR SSP ║ E - Focus RMM ║ StopTech Slotted Rotors and EBC Yellow Stuff Pads ║ Techna-Fit SS Brake Lines |
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| You'll have to modify the firewall to create enough room for the CDFP, and you may well find that the head is too tall to fit beneath the hood without modification. You will also likely have to run a custom ECU.
Groans: 111
(Thread Starter) | Not Ranked : 0 score Modifying the hood a bit or even getting a custom fiberglass one should not be a real problem. Neither backporting a 3/6MPS or CX7 instrument cluster with the imobilizer and ECU and the right harness. However, a custom ECU may be an even cheaper solution, I don't know yet, I'm still in that stage when a random idea hit me at the end of the week. I guess the firewall has to be kinked a bit no matter what larger engine goes in there, right?
| The Following User Says NO Thank You to mituc For This Un-useful Post: | Vansquish (05-15-2017) |
| Not Ranked : 0 score Okay, first things first. What gen miata are you talking about?
Groans: 111
(Thread Starter) | Not Ranked : 0 score At this point I have no idea. I just want one with a hard top. The NBs have more rust, the NCs are harder to find cheap for an engine swap and probably have the engine compartment a bit narrower. So probably (but not necessarily) NA.
Also, hardtops are the most expensive part of a miata.
__________________ Built 5862: Shootin For The Stars 2006 Mazdaspeed6 GT Crystal White Pearl #07141 Damond Motorsports = PS Cooler - RMM - PMM - OCC VersaTuner = Versatune Clutchmasters = 850 Street Twindisk Corksport = RDM - CBE - RSB - TMM Insert Turbine Tech = Forward Diff Mount - FMM CP-e = Exhaust Manifold - Injector Seals PTE = JB 5862 JMF = Intake Manifold w/Custom PI Kozmic = Downpipe - 6th Port - EGR Delete Forge = V2 BPV Tial = 44mm WG Autotech = HPFP Internals HTP = 4" Intake - Battery Tray Bilstein = B6 Shocks w/Eibach springs Grimmspeed = EBCS Technafit = SS Brake Lines - SS Clutch Line Enkei = EVOX GSR 18x8.5 +38 - NT03+M 17x9.5 +38 Custom = FMIC w/TR1035 - Shifter Cables - Shifter Bushings | |
| The Following User Says Thank You to Mazdazilla6 For This Useful Post: | mituc (04-21-2017) |
Groans: 111
(Thread Starter) | Not Ranked : 0 score Yeah, I know, I simply don't like open tops, so the cabin will have to stay closed all the time. Ok, once I will finish rebuilding my engine I will start looking into an NC shell. Thanks for the advice!
| The Following User Says Thank You to mituc For This Useful Post: | Mazdazilla6 (04-22-2017) |
![]() Join Date: Jul 2011 Location: Virginia Beach, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 473
| Not Ranked : 0 score The gay one.
__________________ Speed 6 Gone for 3+ years and still not happy about it 2007 Speed 3. JBR 3" WP. AP. Autotechs. Full Maize. CP-E Stage 2 RMM, Rubber Filled OEM TMM, Nator'd TP, Moog's and DM SSP Enki - "High mixes of corn = all the wastegate all the time for great justice." |
| Not Ranked : 0 score This sounds like such a great idea. Big hp with a light engine and car, the mazda version of a cobra. I was thinking about putting a 3.5 ecoboost in a old mustang.... but read some dealership out in the boonies is doing it. Same principle.
__________________ Max Bolted and Built Stock K04 |
The Little Engine That Could...Almost - AJ Hartman Racing I would also suggest the NC miata.
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. | |
![]() Join Date: Jan 2011 Location: IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 960
| Not Ranked : 0 score Not a 2.3Disi but a shop in Japan called Odula put the L3-VE from a 2.3L MZ3 into a NC. I couldn't find any info on their site but here are pics from the feature in the car mag I have.
__________________ 07 True Red Mazdaspeed 3 GT - Totaled 2/7/2015 15 Soul Red Mazda3s GT HB |
| The Following 3 Users Say Thank You to naoandlater For This Useful Post: |
Groans: 111
(Thread Starter) | Not Ranked : 0 score So the RX8 bodywork in the engine bay needs to be cut quite a bit to fit a 2.3DISI-T engine in there. It was designed to fit 2 rotor rotary of the size of a backpack so it looks like I'm forced to go with the NC chassis which may require minimal engine bay cutting/bending.
![]() Join Date: Dec 2013 Location: Sylmar, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 65
| Not Ranked : 0 score I'm waiting to see the outcome.
__________________ |
Groans: 111
(Thread Starter) | Not Ranked : 0 score Although it seems more difficult to convert an RX8, and it's also a bit of a sacrilege, I think I'll go with the RX8 chassis simply because it has 4 seats, longer wheel base and wider track.
| The Following User Says Thank You to mituc For This Useful Post: | Vansquish (05-15-2017) |
![]() Join Date: Apr 2015 Location: Sterling Heights Michigan
Groaned at 9 Times in 7 Posts
| Not Ranked : 0 score But it weighs another 1000 lbs and almost had as much power as the MZR stock. While it may be more practical (which first of all you shouldn't be doing a full blown engine transplant for practicality), I don't think it would be nearly as satisfying. Doing this to an rx8 yields a slight improvement on an rx8. Doing this on a Miata is creating a totally different beast. I'm willing to bet it'll be the most fun thing you've ever driven not to mention a hit at any car show. Just my opinion.
__________________ Things that matter: CS "Stage 2" SRI/TIP, CS TMIC, AT HPFP, JBR 70 duro RMM, Stratified OTS +, Koni FSD's, Whiteline endlinks. Things that don't: Gen Pu wheels, CPE center pod with Prosport boost, OP, and OT gauges, Eonon G9151A. |
| The Following User Says Thank You to Bingo For This Useful Post: | sharksinspace (05-14-2017) |
| The Following User Says NO Thank You to Bingo For This Un-useful Post: | Neverlift (05-15-2017) |
Groans: 111
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI | |
![]() Join Date: May 2016 Location: Netherlands, Hierden
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 92
| Not Ranked : 0 score Personally I wouldn't go for the rx8 The mx5 looks like it would be a lot more fun driving it with the Disi. Imo Although I want to built a 3 rotor rotary mx5 one day. Verstuurd vanaf mijn EVA-L09 met Tapatalk
__________________ 2006 Mazda MPS 6, ZZB († 13th of May 2016 ), @ 312hp, 454Nm at the wheelsEngine Built: ![]() Specs: @ xxx wHp, xxxNm at wheelsWiseco, Manley H beam Rods, ARP Head studs, ARP Main studs, JBR Balance shaft removal, Total-MPS injector seals. CS hpfp internals, CS TIP, CS Rear Diff Mount, CS 3.5bar MAP, JBR SRI, JBR EGR Delete, 3" Downpipe (De-Cat) Custom build by local shop, Custom built FMIC, PERM PVC, 3 port JBR EBCS, ACT HD Clutch 6-Pad Solid w/ Streetlite Flywheel, NGK LTR7IX-11, JBR Oil Pan Baffle. Custom tuned/build K04 turbo by https://www.turbochargers.nl/ Saving for additional bolt ons (aux fuel, intake mani) RX-8 Wheels 225/40-R18 Toyo T1R, 3cm lowerd Eibach kit. initial dyno tuned by BR-performance. new tune by ????? versatuner Hope to reach 400whp in the future, first goal is to get my car driving again insta: @sp_shiningdreams www.shiningdreams.nl |
![]() | | #19 | ![]() |
| Not Ranked : 0 score I feel like an E tuned DISI in a miata would be a blast...as well as a death trap.. Tiny tires, no weight and RWD...Mmmmm
![]() | | #20 | ![]() |
![]() Join Date: May 2016 Location: Kansas
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Same principal as an LS swapped miata but instead of a rumbling v8, it's a sick nasty disi! +1 vote on the miata instead of rx8 Sent from my HTC One_M8 using Tapatalk
__________________ Cobb AP // ko4 @ 18.5 psi // custom tmic // wiseco pistons // Manley rods // bsd // forge bpv // Megan racing suspension // atp upper catless dp stock lower stock exhaust minus resonator// 06 rx 8 wheels wrapped in potenza sport 235/40/r18 // 292 whp 346wtq freektune on 91 oct // shift plate // red rally armor // |
![]() | | #21 | ![]() |
| Not Ranked : 0 score I'm 38 and i was thinking about which fast roadster i could get for my 40ishh crisiss ![]() a turbo miata was on the top of the list.....But i was more looking at the approach of keeping it PI..I was expecting a speed manifold would bolt on the LF engine from the 2006+ model. So it would have been easy to put LF head on the dizi bottom or swap the crank/rod and piston into the 2L bloc if the head isn't fully compatible. And Re-use most of my speed parts on it...even a k04 would be nice to start. But i heard the exaust flange of the LF may be different. I have no idea but i have seen a PI head on a dizi bloc....There seem to be some ready to connect megaskirt standalone for miata. If it come with a base program it could be an easy thing. On the other hand, it would need a stronger and wider rear axle to keep it on the road like with an LS swap...
| The Following User Says Thank You to Jeff23spl For This Useful Post: | _SPEED3GT_ (05-14-2017) |
![]() | | #22 | ![]() |
Groans: 111
I always likes cars with a bit of practicality so that is the reason why my dream is to put the DISI-T in an RX8.
![]() | | #23 | ![]() |
![]() Join Date: Oct 2013 Location: Detroit, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 509
| Not Ranked : 0 score If you use the NC then you also have the option to go PRHT instead of separate hardtop... best of all worlds in some ways. I considered an LS swap to one until I sat in one (don't fit) though I have to wonder if it could be made to work with some standard fat-guy mods like foamectomy/handle removal/etc.
__________________ 2013 'speed3, silver Stage Bro |
![]() | | #24 | ![]() |
![]() Join Date: Aug 2012 Location: Middle Coast
Rep Power: 263 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
Groans: 126
| Not Ranked : 0 score I vote for MX5. In for results.
__________________ Genpoo stuff |
![]() | | #25 | ![]() |
| Not Ranked : 0 score but is the rx8 engine same weight of a L serie engine? If you take both shell without engine, is the RX8 remain just 100kg heavier ? Maybe the difference would increase? i don't know but i heard few times that the rx engine was designed to be lightweight so the swap may add more weight to the rx8 than it would on the miata ?
![]() | | #26 | ![]() |
Groans: 111
The weight distribution should not be compromised too much because most of the engine will sit slightly below the front axle so it should be kind of a front-mid engine car, kind of like the S2k (the S2k has the whole engine positioned below the front axle). I'm still waiting for an answer from the Romanian Automotive Homologation Authority and if they say I can individually homologate an RX8 with this engine then I'll do it. Otherwise I'll get an MX5 NC with engine issues (I was surprised to find there are quite a few with rattling 1.8 litre engines) and convert it, but only as a last option.
![]() | | #27 | ![]() |
| Not Ranked : 0 score Hell yes this would be awesome.
![]() | | #28 | ![]() |
Groans: 111
(Thread Starter) | Not Ranked : 0 score Ok, it's going to be an RX8, I will be able to homologate this sacrilege.
| The Following User Says Thank You to mituc For This Useful Post: | Vansquish (06-07-2017) |
![]() | | #29 | ![]() |
| Not Ranked : 0 score Hell yea! How much power are you trying to push? Sent from my HTC One_M8 using Tapatalk
![]() | | #30 | ![]() |
Groans: 111
(Thread Starter) | Not Ranked : 0 score We'll see. It will have a built engine running a GTX3071R (gen1) turbo, so don't expect less than 350bhp. For starters I will not add WMI but I will push the factory fuelling system as much as I can. My intention is to get a GTX3071R gen2 for my 3MPS and put the current turbo in the RX.
![]() | | #31 | ![]() |
the challenge isn't to make power with a L3VDT, all the secrets are in this forum but to swap the dizi in that frame. There is nothing ready for it, it will be as much complicated to install it, as it would be to install even a TDI engine or any other in it. Everything will need to be custom made but he already have the engine and the knowledge around it. BTW Even with a stock turbo and tune, the car would be faster...And i don't expect Mituc will keep it stock
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... Last edited by Jeff23spl; 06-07-2017 at 02:54 PM. | |
![]() | | #32 | ![]() |
| Not Ranked : 0 score You're right. The power question is the easy part lol. Plenty of formulas. I was just curious add to what the minimum might be Sent from my HTC One_M8 using Tapatalk
![]() | | #33 | ![]() |
| Not Ranked : 0 score Even a stock bottom end, relatively easy mods, DISI running E30 doing in the 350/350 range would be AMAZING in a RX-8. Actually if there were a good kit for mounting it, getting the cluster and such to work, and mating the trans to it I'd try to find a roller and order a motor from Edge to build one myself, because that sounds like stupid amounts of fun for the cost. You can find $3k or less RX-8 rollers without much work at all. Honestly other than having to get it custom I think the mechanical stuff might be child's play compared to getting the cluster thing to work, from what I read. Didn't the guys who put the DISI into a Mazda 5 have to keep the ms3 cluster in the glove box just to make the DISI work right?
![]() | | #34 | ![]() |
You can make a cluster page for: RPM, Speed, Gaz level, Engine temp. Boost level and some more to look at engine health in another page... I would be more afraid of the air bags devices or anything else that you keep from the RX8 but controlled by the speed computer....ABS and stability control, Fuel tank level sensor, VSS etc...
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... | |
![]() | | #35 | ![]() |
| Not Ranked : 0 score If there was a kit I'd be all over this because I've got a roller rx-8 in my area for about $1500. I would aim for like 600 to the rear wheels. Plus my car is paid off next month so I'd have more funds for that project.
![]() | | #36 | ![]() |
Groans: 111
(Thread Starter) | Not Ranked : 0 score This guy here did it somehow: https://www.youtube.com/watch?v=TObmPdSiIgw https://www.youtube.com/watch?v=0YpBWf5LffI I'm still trying to make him tell me more, but he isn't that eager to reply.
| The Following User Says Thank You to mituc For This Useful Post: | aackthpt (06-08-2017) |
![]() | | #37 | ![]() |
__________________ 2013 'speed3, silver Stage Bro | |
![]() | | #38 | ![]() |
Groans: 111
First we need to make it work and then look pretty ...and the versatune the fuck out of it!
![]() | | #39 | ![]() |
| Not Ranked : 0 score Did you offer him a handjob in return? It's the considerate thing to do.
![]() | | #40 | ![]() |
![]() Join Date: Oct 2012 Location: Colorado Springs, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 757
| Not Ranked : 0 score the second video appears to show a ‘stock’ mps ECU... so interested in how they defeated the need for the gauge cluster....
__________________ mods: \\// AT HPFP // AccessPort // CS S2 TIP, SRI and TMIC // CPe S2 RMM // Synapse BPV // Mazda gutted secondary cat // S-OTS+ 91S2 // HKS TP DLi II // Wilwood DP6 13” brakes // TCE 2 piece rear rotors // Maxwell SuperCap/LiFePO4 cell \\// waiting for install: \\// CPE Catted DP // CS Battery Box // Devils Own Meth kit // H&R Coilovers \\// |
| Display Modes | |
