MAZDASPEED Protegé
> MSP - Engine, Transmission & Driveline
 Old 06-10-2009, 05:41 AM   #1
jayson's Avatar
Posts: 1   (View Stats)
jayson is an unknown quantity at this point
Default engine shutting down
Looking for ideas as to why when approaching a stop sign and pushing in on the clutch the car shuts down. Not doing this every time but not sure what to do at this point. Anyone else having similar problems?
jayson is offline   Reply With Quote
 Old 06-10-2009, 05:47 AM   #2
buddhabum's Avatar
Posts: 254   (View Stats)
buddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond repute
Does it do this when you take it out of gear? Or leave it in gear whilest stopping? If it dies while the car is in-gear and the clutch is depressed as far as you can push, then it'll prolly need to be adjusted. If it just dies when you press the clutch and slow down out of gear than thats weird. Any CELs?
'06 MS6 Black Mica
Street Unit Block, CP Pistons (9.0:1), Pauter Rods, CPBoost Top-mounted Turbo Exhaust Manifold w/ Tial 38mm External Wastegate, Custom 3", CP-E FCF (No Boost cut, 3.25" MAF), CP-E PnP Standback V2, CP-E HPFP, CP-E FMIC Core w/ Custom piping, Denso Spark Plugs, Custom Inlet w/ 3.25" MAF Housing, VCTS Delete, EGR Block-off, Saikou Michi OCC, Fidanza Flywheel, HD Signature 18x8" MSR Wheels, HTR Z III's 235/40/18, BS Delete, TWM Stage 2 SS Kit, Dashhawk, Perrin EBCS.
buddhabum is offline   Reply With Quote
 Old 06-17-2009, 08:10 AM   #3
Yel3_5MSPro's Avatar
Yel3_5MSPro is an unknown quantity at this point
Default Similar Problem
My MS Protege started stalling between gear changes (down shifting and upshifting) and at lights, for several months now. Last week got a CEL but no reader to tell me the code.
Totally Stock Car with 101,000 miles. Fuel Economy at 30 on highway, still.
Yel3_5MSPro is offline   Reply With Quote
 Old 06-17-2009, 08:16 AM   #4
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
my buddy's turbo MP3 (think he has the same setup as a MSP) will die if you push the clutch in while slowing down. I think it has to do with the BOV venting too much or something? try adjusting it if you can.
'08 CWP MS3 w/ T3 3071r
Pulsar Spark Plug Replacement, Pinging Engine, Jeep Liberty Engine Stalls, Windows Are Stuck, Blower Motor Runs On Low O Haltech Automotive News 1 04-13-2012 09:13 PM
pda of engine LiEast MazdaSpeed 3 - How-To's 8 07-05-2009 03:04 AM
Engine Block Heater, Sticking Gas Pedal, Clunking Noise on F-150 Truck, Ford Explorer Engine Dies at Idle: Mike Allen's Haltech Automotive News 0 03-13-2009 03:30 PM
Pulsar Spark Plug Replacement, Pinging Engine, Jeep Liberty Engine Stalls, Windows Are Stuck, Blower Motor Runs On Low O Haltech Automotive News 0 07-10-2008 11:10 AM
Page generated in 0.24198 seconds with 23 queries
