MAZDASPEED Protegé
> MSP - Engine, Transmission & Driveline
 Old 01-16-2015, 08:02 AM   #1
Boilermaker19's Avatar
Posts: 6   (View Stats)
Boilermaker19 will become famous soon enough
Default MSP sputters and dies at idle
A few days ago, my MSP started having a problem at idle. When I first start it cold, she starts up okay, but once she's warm enough for the IACV to let the idle drop to normal, the car sputters and dies. I can drive it, but I sometimes have to rev it to keep it running at a lght. Once I am above 1500 RPM, everything seems fine. The Fuel trim readings are WAY negative, like -25, when she starts sputtering. The only codes are P0140 and P0037, both of which I have had since I bought the car in October. I have cleaned the MAF, shot some cleaner in the TB, and then I seafoamed her and replaced the plugs. After that, I cleaned both O2 sensors (which, BTW, are both giving a constant signal). I checked all of the vacuum lines, and they seem okay. When I ran hte seafoam, I got a lot of smoke coming from the region of the S pipe, which I recently had to have welded, but if my O2 sensor signal is constant, that can't be the problem. I am running 9 pounds boost (forged internals), an FMIC with BOV, MAF is blow-through, 12" from the throttle body, have a 3" catless exhaust and SSAFC.
Boilermaker19 is offline   Reply With Quote
 Old 01-16-2015, 08:07 AM   #2
Constant = no change? Is your AFR fluctuating or is it stuck at one value?
 Old 01-16-2015, 11:56 AM   #3
The AFR fluctuates
 Old 01-16-2015, 01:55 PM   #4
ihasmazda's Avatar
Posts: 1,011   (View Stats)
vacuum leak. check hoses.
2007 Mazdaspeed 6 GT
2003 Ford Ranger XLT
The Following User Says Thank You to ihasmazda For This Useful Post:
HFDSpace-Junk (01-17-2015)
 Old 01-17-2015, 06:10 AM   #5
HFDSpace-Junk's Avatar
Posts: 266   (View Stats)
HFDSpace-Junk is the leader of the worldHFDSpace-Junk is the leader of the worldHFDSpace-Junk is the leader of the worldHFDSpace-Junk is the leader of the worldHFDSpace-Junk is the leader of the worldHFDSpace-Junk is the leader of the worldHFDSpace-Junk is the leader of the worldHFDSpace-Junk is the leader of the worldHFDSpace-Junk is the leader of the worldHFDSpace-Junk is the leader of the worldHFDSpace-Junk is the leader of the world
^^^ I second that.
other than that, check the plug wires and coil packs. I doubt that's the problem as it really seems like a vacuum issue, but cant be too safe. and lastly, check to see that the pump is working correctly and the pickup isn't clogged.
2003.5 BLAZING YELLOW Mazdaspeed Protege
FMIC|Potenza S-04 Pole Positions|P5 Transmission W/LSD Delete (Blew 2rd/3rd/4th in MSP trans)
[COLOR="yellow"[/COLOR]
AWR MM Tetralogy (70 Duro)|Havoc bumper plates|New pads + Slotted Rotors|Iridium Plugs
Awaiting install:New pads + Slotted Rotors
2008 Black Mica MS3 Sport
I don't get mad, I fuck shit up.
I also fuck grandmothers
HFDSpace-Junk is offline   Reply With Quote
 Old 03-01-2015, 11:43 PM   #6
Illa Noize's Avatar
Posts: 122   (View Stats)
Illa Noize is a splendid one to beholdIlla Noize is a splendid one to beholdIlla Noize is a splendid one to beholdIlla Noize is a splendid one to beholdIlla Noize is a splendid one to beholdIlla Noize is a splendid one to beholdIlla Noize is a splendid one to beholdIlla Noize is a splendid one to behold
Make sure the spark plugs are gapped correctly. Also make sure ur coilpacks are working correctly and also make sure the wiring connecting to the coilpacks have a solid connection. Mine weren't and I had to glue the wires to the coilpack so the connection remains good.
Illa Noize is offline   Reply With Quote
Valves cleaned, car starts, dies after rough idle. Thoughts? slixx 2010 MS3 - Troubleshoot/Diagnostics 5 05-28-2013 05:00 PM
JBR Intake Install rough idle, dead peddle, then car dies caesura 2010 MS3 - Troubleshoot/Diagnostics 18 07-27-2012 11:18 AM
Car sputters when you put foot on gas!! gt5 MazdaSpeed 3/6 - Turbo Induction 24 03-11-2010 08:46 AM
Car sputters when you put foot on gas!! gt5 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 02-25-2010 05:37 PM
Engine Block Heater, Sticking Gas Pedal, Clunking Noise on F-150 Truck, Ford Explorer Engine Dies at Idle: Mike Allen's Haltech Automotive News 0 03-13-2009 03:30 PM
Page generated in 0.25644 seconds with 24 queries
