MAZDASPEED Protegé
> MSP - Engine, Transmission & Driveline
 Old 12-14-2008, 02:37 AM   #1
franciscoescn's Avatar
Posts: 10   (View Stats)
franciscoescn is an unknown quantity at this point
Default Transmission problems
So my transmission started to act funny it gets all stiff when i try to shift into third and fifth gears. It only does it when i'm giong from second to third and from fourth to fifth. I have to shift really hard to get it to go in. Any advise would be helpfull thanx.
franciscoescn is offline   Reply With Quote
 Old 12-14-2008, 03:45 AM   #2
ccann26's Avatar
Posts: 238   (View Stats)
ccann26 has much to be proud ofccann26 has much to be proud ofccann26 has much to be proud ofccann26 has much to be proud ofccann26 has much to be proud ofccann26 has much to be proud ofccann26 has much to be proud ofccann26 has much to be proud ofccann26 has much to be proud of
had my trans replaced and afterwards it was hard as hell to shift .... but in all gears turned out to be the shifter cable .
ccann26 is offline   Reply With Quote
 Old 12-20-2008, 01:29 PM   #3
Hypnotized's Avatar
Posts: 184   (View Stats)
Hypnotized is a splendid one to beholdHypnotized is a splendid one to beholdHypnotized is a splendid one to beholdHypnotized is a splendid one to beholdHypnotized is a splendid one to beholdHypnotized is a splendid one to behold
Ho miles do you have on it?
Hypnotized is offline   Reply With Quote
 Old 12-20-2008, 01:49 PM   #4
redrocketz's Avatar
Posts: 1,122   (View Stats)
redrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond repute
3rd and 5th blow out all the time on MSP's you will need to rebuild almost guaranteed unfortunately.
redrocketz is offline   Reply With Quote
 Old 12-26-2008, 12:53 AM   #5
I just rebuilt the transmission like 5 months ago. The car has 80,000 miles on it and like 6,500 since i rebuilt it.
 Old 12-26-2008, 06:07 PM   #6
redrocketz's Avatar
stronger gears? the actual gears lose all their teeth I have had an entire set of teeth from 5th gear in my hand once. what mods do you have on the car? I see a FMIC in the pic. you can take the 5th gear cover off with the tranny still in the car in like an hour max and check the gear and syncros otherwise you may have blown your diff but that typically takes the whole tranny with it.
 Old 12-29-2008, 01:55 AM   #7
I have a 3 inch catback exhaust and an injen intake, syncronic bov, welded lsd from protege garage, split second afc, thunder turbo manifold, and the front mount. I don't have that many mods yet.
 Old 12-30-2008, 10:35 AM   #8
redrocketz's Avatar
hey I probably welded that damn diff... I would say if you don't think the gears are gone then try different tranny fluid if that doesn't solve it take off the side cover (black) and check the 5th gear and synchro.
 Old 04-10-2009, 12:42 PM   #9
ctbadley's Avatar
Posts: 62   (View Stats)
ctbadley is a jewel in the roughctbadley is a jewel in the roughctbadley is a jewel in the rough
hmmm...
ctbadley is offline   Reply With Quote
 Old 07-14-2009, 11:44 PM   #10
MANDO's Avatar
Posts: 11   (View Stats)
MANDO will become famous soon enough
3rd and 5th gear synchronizers are bad in my opinion.
MODS:
Medieval complete MM kit & Trani mount, Medieval Crank Pulley,HKS SSQ BOV, Forge BPV, Upgraded SMIC, Injen CAI, S.U. Hardpipes, Greddy Oil Catch Can, Magnaflow Dual 2.5" tip Muffler w/ cat back
MANDO is offline   Reply With Quote
 Old 12-06-2011, 06:34 AM   #11
StealthWyvern's Avatar
Posts: 76   (View Stats)
StealthWyvern has much to be proud ofStealthWyvern has much to be proud ofStealthWyvern has much to be proud ofStealthWyvern has much to be proud ofStealthWyvern has much to be proud ofStealthWyvern has much to be proud ofStealthWyvern has much to be proud ofStealthWyvern has much to be proud of
If its hard to shift even after a rebuild check the brake fluid cap for any cracks. these cracks will prevent the system from getting the proper presure it needs which will cause hard shifting or no shifting no matter how much you press the clutch. For the MS3 guys that MSP uses brake fluid for the clutch.
Also if your brake fluid is over filled it will cause the same issue. Take for example you recently replaced all 4 brake pads but forgot to take yoru brake fluid cap off. The fluid will be pushed up into the cap.
These cars don't have cables....
3rd gear is the most common to have issues
StealthWyvern is offline   Reply With Quote
 Old 12-19-2011, 02:21 PM   #12
Ingle's Avatar
Posts: 421   (View Stats)
Is it a rod and spring then? If not a shift cable, what would it be called?
 Old 01-05-2012, 05:04 AM   #13
Its called a shift linkage from my understandings but it is far from a shift cabel setup.
http://www.clubprotege.com/forum/att...1&d=1098299593
 Old 01-05-2012, 06:03 AM   #14
Jesus, Thread necromancer, let this old thread die....
The Following User Says NO Thank You to Raider For This Un-useful Post:
StealthWyvern (01-05-2012)
 Old 01-05-2012, 06:19 AM   #15
lmao NEVER! I hadn't been on here in awhile spanky. I think that part should be obvious.
 Old 01-05-2012, 06:27 AM   #16
Original post is over 3 years old, Dan!
 Old 01-05-2012, 06:33 AM   #17
Sssh... show how active the protege section is and your not supposed to notice that! lmao
 Old 01-05-2012, 06:34 AM   #18
Not my fault you keep going on 247...
 Old 01-05-2012, 10:40 AM   #19
and its not my fault 247 has 900 times more content for proteges then mazdaspeedforums... just saying and the protege section is well lacking and dead here just about. The crickets don't even chirp here! lol
turbo xs DP..problems? tbone MazdaSpeed 3/6 - Turbo Induction 11 11-14-2008 09:55 AM
too many problems/TXS DP tbone Mazdaspeed3/6 General Discussion 9 11-13-2008 11:35 AM
Lots-O-Problems thanotosq MazdaSpeed 3/6 - Troubleshoot/Diagnostics 9 10-15-2008 06:13 PM
G45 has HD decode problems Haltech Computers & Technology News 0 04-16-2008 10:50 AM
Problems registering? Jesse MS3GT Website Help/Feedback 4 03-07-2008 06:31 PM
Page generated in 0.35377 seconds with 28 queries
