MAZDASPEED Protegé
> MSP - General Lounge + New Member Welcome
 Old 10-17-2011, 07:28 AM   #1
StealthWyvern's Avatar
Posts: 76   (View Stats)
StealthWyvern has much to be proud ofStealthWyvern has much to be proud ofStealthWyvern has much to be proud ofStealthWyvern has much to be proud ofStealthWyvern has much to be proud ofStealthWyvern has much to be proud ofStealthWyvern has much to be proud ofStealthWyvern has much to be proud of
Default Annoying Dash Rattle Locations?
I've been trying to track down this annoying passenger dash rattle i get that’s extremely annoying.
Locations that I’ve found that sound like its coming from the dash area.
1) The plastic cowl by the wipers.
2) The plastic part that’s attached to the fender by the door. You can see this part when the door is open.
http://www.mazdaspeedforum.org/forum/foru...5-rattler2.jpg
http://www.mazdaspeedforum.org/forum/foru...p5-rattler.jpg
3) A peice of metal under the wiper cowl that runs front to back on the car. If you tap on it with your hand you will hear it rasp. I jammed a zipstrip (green zipstrip in video clip) between it and the other peice of metal. And no more rattle dash noise by the passenger side airbag around 2.2k-2.6k rpms!!
video-2011-10-31-17-42-21-1.mp4 video by StelathWyvern - Photobucket
Anyone know of any other known locations? Before anyone says anything its not my glove box. Its sitting in my back floor board while I track this thing down. The ash tray has also been removed.
UPDATE: Fixed that #3 above.. got the two peices of metal welded together.. man that little issue makes a shit ton of noise! I can tell a MAJOR difference even with all my carpet out in my car! After you weld it cover it up with some paint.. All I had was silver paint. Please note before you weld this together make sure you have all leafs cleared out of the cowl aera and just do the part away from the glass. The shop that did it for me almost had a fire issue due to the insulation under the dash from welding the panel under the windsheild for me.
StealthWyvern is offline   Reply With Quote
 Old 10-17-2011, 07:36 AM   #2
blue 2011's Avatar
Posts: 17   (View Stats)
blue 2011 will become famous soon enough
i hope to find out too mine started when weather cooled down car only has 5k on it i just got it
blue 2011 is offline   Reply With Quote
 Old 10-17-2011, 07:41 AM   #3
This is the protege section blue. lol
 Old 10-31-2011, 06:18 PM   #4
updated with a new rattle location!
 Old 05-26-2013, 03:52 AM   #5
updated fix for a rattle location
 Old 05-02-2015, 08:11 AM   #6
cmaj91's Avatar
Posts: 1   (View Stats)
cmaj91 is an unknown quantity at this point
Default Protege Rattle under right side of dash
Hi,
I think I have the exact same rattle but cannot view the video that you had once posted. Can you repost or send to me a private message showing the rattle location under the cowl ?
Was yours under the passenger side of the dash ?
Thanks,
Mark
cmaj91 is offline   Reply With Quote
 Old 01-31-2016, 06:56 AM   #7
Originally Posted by cmaj91 View Post
Hi,
Thanks,
Mark
CMJA91 - The "dash" rattle location turned out to be under the wiper cowl on the passenger side. You have two pieces of metal that touched that I tested by sticking a ziptie in-between to isolate them. Once I figured out that spot I had them welded together. Its not pretty but hey it works and that stupid spot is fixed.
I had a friend try welding this and her welder was to hot and burned right through it. I later had a friend fill it and re-weld it with a proper welder instead of a stick welder but the below shows the two pieces that caused the rattling/buzz noiec that sounds like its in the dash. That hole goes back up under the dash.
 Old 01-31-2016, 10:21 AM   #8
K3N
K3N's Avatar
Posts: 86   (View Stats)
K3N has a reputation beyond reputeK3N has a reputation beyond reputeK3N has a reputation beyond reputeK3N has a reputation beyond reputeK3N has a reputation beyond reputeK3N has a reputation beyond reputeK3N has a reputation beyond reputeK3N has a reputation beyond reputeK3N has a reputation beyond reputeK3N has a reputation beyond reputeK3N has a reputation beyond repute
There is one other to look for. It's where the bumper and fender connects. It's a plastic bracket that degrades after time.
Sent from my XT1585 using Tapatalk
BNR Stage 3 Turbo // Stratified Boost Dial // Grimmspeed EBCS // TWM Stage 2 STS kit // ETS TMIC // BC Coilovers // SPC Joints // Forge BPV // Whiteline 24mm rear sway bar // Cobb AP // Cobb SRI // Cobb TIP // GT Spec Trail Braces // GT Spec Front Tower strut brace // Corksport Dual Exhaust // CPE Diff Brace // AWR Tranny Mount // AWR Rear Mount // AWR Right motor Mount // Denso ITV 22's
K3N is offline   Reply With Quote
 Old 04-14-2016, 10:53 AM   #9
Not on a protégé.. I think you are thinking about the 3 and 6.
 Old 04-14-2016, 12:03 PM   #10
K3N
K3N's Avatar
>,< Tapatalk gets me once again! I thought this was a speed 6.
How to get rid of that annoying e-brake rattle apena85 MazdaSpeed 3 - How-To's 35 12-17-2014 05:10 AM
Annoying RATTLING NOISE in the dash of my new MS3!!! cocktailfruit MazdaSpeed 3/6 - Troubleshoot/Diagnostics 26 04-27-2014 01:30 AM
Dash rattle turd burglar MazdaSpeed 3/6 - Troubleshoot/Diagnostics 12 03-27-2011 03:21 AM
Annoying interior rubbing sound, DS dash area. demonspeed MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 08-04-2009 06:53 PM
Rattle in my dash area?? thebbqbar MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 12-03-2008 09:14 AM
Page generated in 0.29925 seconds with 24 queries
