 Old 11-10-2017, 10:28 PM   #1
Ctown2Ctown's Avatar
Posts: 9   (View Stats)
Ctown2Ctown has a spectacular aura aboutCtown2Ctown has a spectacular aura about
Default 07 Mazdaspeed 6-cranks but doesn't start
Hi all.
I had a brake line go out on me a few weeks ago. Being a full time student with a full time job (plus some part mix ups) I didn't get a chance to fix it until yesterday. I got the new line installed, the brakes fully bled and went to take it for a test drive. Unfortunately the battery was dead. No biggie, so I jumped it. It cranked for a bit, halfway started and then died. I had advance charge the battery for me and put it in last night. Since then it has done nothing but crank without starting. It was running great before I parked it.
I can hear the fuel pump and it smells like gas after cranking it a few cycles, so it's getting fuel. The other mystery is that it's not throwing any codes. I've checked all the fuses and none are burnt. The immobilizer light is acting like normal, and everything seems to be in good operating order it just won't start. I'm just wondering if there's anything blatantly obvious that I'm missing.
2007 Mazdaspeed 6 GT-AP v2, CPE SRI, COBB TIH, AUTOTECH FP INTERNALS, CPE 3" TBE, FORGE BPV, AND ALL THE MOUNTS
Ctown2Ctown is offline   Reply With Quote
 Old 11-11-2017, 04:33 AM   #2
Djohns's Avatar
Posts: 3,944   (View Stats)
Check the battery again. If it so happens it’s drained, you either have a bad battery or a bad alternator.
2010 black mica speed3
Soon:built motor
 Old 11-11-2017, 07:01 AM   #3
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
If you smell a lot of gas and think it might be getting flooded, hold the pedal to the floor while cranking to clear it out.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 11-11-2017, 03:24 PM   #4
I let it sit for a whole day. I think it's fine but I'll try it tonight.
cranks but wont start BigRed06 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 09-20-2015 12:06 PM
MS6 Cranks but won't start HELP!!! KingJames MazdaSpeed 6 - Engine, Transmission & Driveline 16 03-23-2015 06:38 AM
Car cranks, won't start 15driley15 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 04-23-2014 04:51 PM
Ms6 cranks but wont start maniospeed6 Mazdaspeed3/6 General Discussion 4 03-26-2013 09:08 PM
Car cranks but doesn't start after valve clean InfamousSpeed6 Mazdaspeed3/6 General Discussion 11 11-29-2012 06:17 PM
Page generated in 0.24887 seconds with 22 queries
