| MazdaSpeed 3/6 - Troubleshoot/Diagnostics MazdaSpeed 3/6 - Troubleshoot/Diagnostics - Have a problem with the car? CEL Code? Want to discuss other issues? Come on in! |
![]() Join Date: Aug 2011
Rep Power: 0 ![]() Thanks: 13
(Thread Starter) | Not Ranked : 0 score After getting my 2007 Mazdaspeed stuck in the snow in my driveway again I noticed my ABS and Traction control light were on and would stayed on. I've driving it at least an hour already and they are still on. The abs and traction control are both not functioning now also. I have tried pushing the DSC button and it dosen't do anything. I have even unpluged the battery. I have no clue what to do and google can't find anything. I don't want to have to take it to the dealership again because that is getting real expensive. Please help if you have any idea how to fix this. Thanks. |
![]() Join Date: Nov 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
| Not Ranked : 0 score Mazdaspeed 3 or 6? It's possible that a wire to one of the wheel speed sensors or ABS plugs was damaged or came loose. Check behind each wheel for any loose or damaged wires/plugs. You may want to unplug and clean the plugs out, it may just be that a bunch of crap got into one of the plugs and it's sending a bad signal. Check the fuses too (and first), it's always possible that one of them blew.
__________________ 2007 Mazdaspeed 6 GT |
| The Following User Says Thank You to keymaster For This Useful Post: | chuckms6 (03-07-2013) |
(Thread Starter) | Not Ranked : 0 score It's a mazdaspeed 3. So there are sensors in the wheel wells or something? There was a lot of snow lodged in there. |
| Not Ranked : 0 score There are. Start with the fuses though, it's possible that one of the wires shorted or got wet and that blew a fuse. If the fuses are good, then you get to take the wheels off and check out the wiring to see if there is any damage. If you're lucky, cleaning things up will fix it, if not it's a trip to the dealership for a new sensor and calibration. It's hard to say what it might be until you start looking though, good luck.
(Thread Starter) | Not Ranked : 0 score Thanks! Any chance there are diagrams or pictures of where or what these sensors look like? |
And Lex is right, the warning lights should be generating codes that you can pull and look up...you'll need something to do that with. I think a ODBII scanner will read those as well, but don't quote me on that...that would include stuff like a Dashhawk or AP, anything that can pull codes. Auto parts stores used to read those codes for free, I recently heard some aren't doing it anymore. Check for a local meet, someone probably can help you out with that.
__________________ 2007 Mazdaspeed 6 GT | |
![]() Join Date: Jun 2012 Location: Houston, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,245
| Not Ranked : 0 score When you got stuck in the snow, did you hit anything? Check the fuses first followed by the connection to the sensor like @keymaster; said. Other then that you may have damaged the sensor it self. When I hit a curb they had to replace the sensor, hub bearing and then reset the sensor in the computer.
__________________ 2012 Liquid Silver Metallic MazdaSpeed3 with Tech Package. South Bend Clutch Stage 3 Endurance | TWM Full Replacement Shifter | Synapse Engineering BPV | Autotech Internals | Grimmspeed EBCS - 3port | NGK 1 Step Colder Plugs | CNT Catless DP and CBE w/resonator deleted | COBB AP - E35 Tune | HTP 3.5" Intake w/ AMSOIL Dry Filter and Pre-Filter | HTP Battery Tray w/ Energizer 51R | CP-E TMIC | CorkSport DISI Silicone Boost Tubes | Damond Motorsports/Saikou Michi Co. Stage2 OCC | Damond Motorsports Short Shift Plate | Sure Countershift | BOSCH 3 Bar MAP w/MattJackson86 PnP Harness | JBR Rear Sway Bar | JBR EGR Block Off Kit | JBR Manifold - TIG | JBR Throttle Body TIG & Coolant Bypass | JBR 88a RMM | JBR 88a TMM | JBR 80a PMM |JBR DISI Bypass Valve Hose | Ported and Polished Intake Manifold DIY | RX8 Wheels w/ Nitto Motivo 235/40/18 Tires | CP-E Towplate | DIY Custom 600g Shift Knob | Redline Tuning Hood QuickLIFT | 30% / 15% Tint | Craven Speed Stubby Antenna | Broadway 400mm Rear View Mirror | Debadged Mazdaspeed 3 Waiting to be installed: Devil's Own Stage 2 DVC-30 Meth Injection | Damond Motorsports Meth Throttle Body Plate On Order: Coming Soon: DIY Projects: FYCN - TEAM LBN BEERS - FYCN-TEAM MUMFORD - FYCN |
| Not Ranked : 0 score Check the fault codes. Those modules generate faults.
![]() Join Date: Sep 2019
Rep Power: 0 ![]() ![]() Thanks: 2
| Neutral : +1 score What was the reason? |
| The Following User Says NO Thank You to DadliMS3 For This Un-useful Post: | MSMS3 (10-10-2019) |
![]() Join Date: Jun 2009
| Neutral : -1 score You do know that post was six, I repeat, six years ago, right? Do you really expect him to be following the thread now? Maybe PM him, if he is even still here and still owns his car.
| The Following User Says Thank You to MSMS3 For This Useful Post: | Db09ms3 (10-11-2019) |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 549
| Neutral : +1 score
__________________ Stockish | |
| Not Ranked : 0 score He should just think before posting. Really. All of us. Not that hard to look at post dates. Keymaster’s last post of any kind was in May, 2014. If he is even here, it’s just about zero percent that he’d still be following the thread. I suggested a PM might actually reach him if he is still involved here. That was constructive.
| The Following User Says Thank You to MSMS3 For This Useful Post: | Db09ms3 (10-12-2019) |
| Display Modes | |
| traction control light on.... | countrymanjeff | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 17 | 04-01-2016 07:08 PM |
| ebrake light & traction control light come on and stay on | CTSpd6 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 6 | 09-14-2012 05:44 AM |
| Traction Control light coming on | banzairx7 | MazdaSpeed 6 - Engine, Transmission & Driveline | 5 | 03-28-2011 12:18 PM |
| Traction control & brake light coming on | dutchbuffalo | MazdaSpeed 6 - Engine, Transmission & Driveline | 21 | 01-21-2011 07:14 AM |
| Traction control light | tuners | MazdaSpeed 3/6 - Suspension & Brakes | 1 | 07-20-2009 06:14 PM |
