  • 1 Post By Raider
 Old 01-14-2013, 07:36 AM   #1
fritzm's Avatar
Posts: 3   (View Stats)
fritzm is on a distinguished road
Default Airbag Light Fix
The airbag light ( Gen1 MS3 2007) showed up now and then over the past year, and recently stayed on all the time. After a new bulb didn't work, I switched the glove box bulb with the passenger airbag light (bulb). Driven for two days now and the aribag light is gone! Hopefully a longterm fix! Now on to the CEL !
fritzm is offline   Reply With Quote
 Old 07-14-2013, 05:40 AM   #2
Rob777's Avatar
Posts: 1   (View Stats)
Rob777 is an unknown quantity at this point
How'd you go with this? And what do you mean changed the bulbs?? Where?
My light just came on after going too fast into a corner..
Thanks
Rob777 is offline   Reply With Quote
 Old 07-15-2013, 06:35 AM   #3
fritzm's Avatar
Try a new light bulb first ( I couldn't find in one to match). So I switched the Glove box light bulb with the Air bag light bulb and all is well. The airbag bulb is easy, just pull the out cup holder (no screws ) then the cover around the shifter (again no screws) then pull out the ashtray to reveal the screws to get out the lighter panel, really easy. The glove box come out by removing the trim above the glove box to reveal some screws and also a couple underneath the dash. Just switch out the bulbs from one to the other and you should be good.
 Old 07-15-2013, 07:04 AM   #4
Police - Grammarhead
Vansquish's Avatar
So what you're saying is that you didn't actually fix anything, and that all you did was switch the bulbs so that the airbag light can't illuminate because it doesn't have the same power requirements as the glovebox light.
Moreover, whatever sensor has triggered the airbag light to illuminate is still malfunctioning and could be causing an unsafe condition where it might not work if you have an accident.
Great idea...
1. Do you have anything sitting on the seat? If so, and if it's less than 100lbs, you might be triggering the Passenger weight sensor to shut the passenger airbag off.
2. If you don't have weight on that seat, then there's a pretty good chance you have either a failed SRS module or a failed Passenger weight sensor, and you'll need to go to a dealer to find out which.
Also, @fritzm; if you couldn't find the "right bulb" you weren't trying hard enough. Call onlinemazdaparts.com (yes, call them), and they'll tell you what part number you're looking for.
 Old 07-15-2013, 07:10 AM   #5
There was a guy who test drove a MS3 with a bag light on. Turn out it was salvaged and the whole front was replaced.
Vansquish (07-15-2013)
 Old 07-15-2013, 07:28 AM   #6
fritzm's Avatar
This is the trouble with many in the import world. You are not experienced enough or have been too spoiled by technology to gain an appreciation for out of the box thinking or the logic that often the simplest idea is the best. You don't know how to drive fast so you add the all this aftermarket bolt on crap to gain a few horsepower and to make your car loud. Yet, put you on the Tail of the Dragon or a even 1/4 mile and all you can do is make noise. This fix worked and according to the dealer is a common problem and has nothing to do with sensors.
The Following User Says Thank You to fritzm For This Useful Post:
predapio (07-15-2013)
The Following 2 Users Say NO Thank You to fritzm For This Un-useful Post:
Raider (07-15-2013), Vansquish (07-15-2013)
 Old 07-15-2013, 07:31 AM   #7
I don't know why the airbag light comes on...Oh, wait.
brownie noob OP, you gave NO FUCKING BACKGROUND other than airbag light on, airbag light off.
Pointless (07-15-2013), Vansquish (07-15-2013)
 Old 07-15-2013, 07:40 AM   #8
But to add to this, Mister Menchinger, the airbag light is set to go off if there is a malfunction in the airbag circuit. That is what it is supposed to do. Replacing it with different bulbs is not fixing the problem, only masking them. If you talked to your dealer, then why didn't they fix it there, instead of having you swap bulbs?
You talk a lot of crap for an old man.
This is coming from the president of a company, too. Oh, airbag light coming on? Swap bulbs until it does not come back on. Yeah, new cars suck.
Probably drives a 1985 Buick Century with the left blinker on.
LOL @ just making noise. OP sucks.
Last edited by Raider; 07-15-2013 at 07:40 AM. Reason: MSF Database - Automerged Doublepost
HawkeyeGeoff (01-25-2015), Vansquish (07-15-2013)
 Old 07-15-2013, 07:48 AM   #9
daafisch's Avatar
Posts: 3,553   (View Stats)
Groans: 58
 Old 07-15-2013, 07:49 AM   #10
Vansquish's Avatar
I'm going to ignore most of what you said above, as while I generally find out-of-the-box thinking to be laudable, when it comes to safety equipment I categorically don't believe it's a good plan.
As for your dealer, it sounds like you need to find another one.
Logic would dictate that if the light turned on the following applies:
1. Something caused the light to illuminate.
2. In order for something to cause the light to illuminate, something must be triggering the circuit or malfunctioning somewhere in the circuit, as the non-failure condition is "light off."
3. If there's nothing on the seat and the light is still on, then see 2), but start leaning towards malfunction.
4. If the passenger weight sensor harness clip has failed, maybe it's the harness clip/harness that needs replacing.
5. If not 4), then it's probably either the SRS module (in the center console), or the passenger weight sensor itself.
6. If not 5, then it is also possible that the passenger airbag harness may be malfunctioning.
7. If any of 2-6, then the airbag is likely set to NOT DEPLOY on impact. Basically, if that light turns on, it makes ZERO sense that replacing the bulb will cause the fail-state to be erased.
If you're upset that I suggested onlinemazdaparts.com because you think I'm a ricer (and that because this is an "import" platform, that we can't "think outside the box"), then you need to do a little research first. That website IS a Mazda dealership. They just happen to have good over-the-phone service and cheap OEM parts prices.
Rob777 (10-10-2014)
 Old 07-15-2013, 07:55 AM   #11
I am not sure if he is referring to the light near the cig lighter, but I am thinking it is the dashboard illumination, where that indeed signifies a problem.
 Old 07-15-2013, 07:59 AM   #12
Vansquish's Avatar
It sounds like he's talking about the one in the center console, as that's what he describes pulling apart for access.
SLOWHATCH (07-15-2013)
 Old 07-15-2013, 08:02 AM   #13
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
Raiser judging by his quick how to, its the one by the cig lighter.
The Following User Says Thank You to skeeter149 For This Useful Post:
 Old 07-15-2013, 08:43 AM   #14
He probably left his dentures on the seat and the jar spilled, shorting the sensor.
Vansquish likes this.
 Old 10-10-2014, 12:35 PM   #15
bplus's Avatar
bplus has a little shameless behaviour in the past
The glove box and the passenger airbag light bulb (next to the cig lighter) are the same part. Same power requirement. When that passenger airbag bulb blows, it causes the airbag malfunction light on the cluster to stay on. Why is that so unbelievable?
bplus is offline   Reply With Quote
The Following User Says NO Thank You to bplus For This Un-useful Post:
Vansquish (10-10-2014)
 Old 10-10-2014, 01:21 PM   #16
Vansquish's Avatar
1. Great necro-thread revival for your first post. Maybe next time, you can do a little more silent reading instead of posting unnecessary, and irrelevant information.
2. The failure mode for the light is "on." What does that mean? Current flows through the circuit to the bulb when a failure condition occurs. That could be when there's weight, but less than 66lbs of it on the front passenger seat, in which case the airbag is DEACTIVATED. If there is no failure condition, such as when there's more than 93lbs on the seat, the lightbulb doesn't turn on, and the airbag is ACTIVATED.
3. The OP wrote that, "The airbag light ( Gen1 MS3 2007) showed up now and then over the past year, and recently stayed on all the time. After a new bulb didn't work, I switched the glove box bulb with the passenger airbag light (bulb). Driven for two days now and the aribag light is gone! Hopefully a longterm fix! Now on to the CEL !"
That means that BOTH the bulb in the console, and the bulb in the instrument cluster were working. THEY WEREN'T BLOWN!!! So, proceeding from this, his solution of replacing the bulb in the console with another working(?) bulb from the glovebox was a totally pointless exercise, and would've merely masked any problem that might've caused the bulb to illuminate. Moreover, the fact that there was a MIL indicates that there WAS in fact a problem NOT caused by a fucking lightbulb.
Now, if a circuit discontinuity caused by a burnt out light-bulb causes a failure mode during the initial system check and that illuminates the airbag MIL, then sure, I can believe your diagnosis. (I'd have to check the shop manual to see if that's an accurate description of the car's behavior, and I don't have that in front of me at the moment.) However, your suggestion makes absolutely no sense when we consider that both the airbag light and the glovebox light were functioning before the swap occurred.
 Old 10-10-2014, 02:20 PM   #17
bplus's Avatar
Thanks for the clarification. My airbag MIL is on constantly, no code is showing up, and the passenger airbag light at console never lights up (burnt out?). If you find an answer to that let me know.
 Old 10-10-2014, 02:23 PM   #18
Vansquish's Avatar
If the airbag MIL is on, then the airbags will not work if you get in an accident. You should go somewhere like Autozone and have them pull the OBDII code so you can figure out what the failure is.
 Old 10-10-2014, 02:30 PM   #19
bplus's Avatar
I was told by my mechanic that no code is showing up when scanned. Is that b.s.?
 Old 10-10-2014, 02:57 PM   #20
Vansquish's Avatar
If the airbag light on the gauge cluster is illuminated, there's probably a code.
 Old 01-24-2015, 11:41 AM   #21
leka's Avatar
Posts: 144   (View Stats)
leka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to behold
hello, I accidentally broke my airbag light in the center console, and My airbag In the speedometer is on all the time, could the light in the center console be the Cause?
Also should I go oem ?
Mazdaspeed 6 2006
Sp63 Longblock with Mahle and manly, ported head, keyed crank and cams, stiffer springs, GTX2867R IWG, Freaks intake 4 inch,Autotech Internals, Stratified Ebc + GA, CP-E injector seals, CS Custom pipes FMIC, Snow performance stage2 100% meth, Cp-E decatted downpipe, Custom Catback with VareX mufflers, EGR Delete, SURE TMM+PMM+RMM, South Bend Clutch Stage3 Daily, CS rear diff mount, TurbineTech Front diff mount, CS rear swaybar, Racingbeat rear Endlinks, Matt Damond PS cooler, JBR OCC Stage 2, Bosch 3 bar MAP w/ PNP Harness, BC coilovers, Tenzo R Type M 19" 235/35, Sure Shortshift, Xcarlink, Speed performance Aux fan control, Synchronic DV BOV, DBA front rotor, Ebc yellow stuff(FR), EBC greenstuff (R), Stoptech brakelines and Finally, Tuned By Lex @ Stratified
Current INFO : tuning is paused due the winter.
Waiting to be installed: Cp-e exhaust manifold stock flange with MVR 44 external wastegate and dump tube.
leka is offline   Reply With Quote
 Old 01-24-2015, 04:56 PM   #22
Could be. Get a replacement and hook it up.
 Old 01-24-2015, 04:59 PM   #23
leka's Avatar
I Can't find the OEM bulb online, I could need some help to find it, who will be my Hero ?
I tried all the OEM sites that I know
Mazdaspeed 6 2006
 Old 01-24-2015, 05:02 PM   #24
Just the bulb? Oh take it out and look at it. Grab same one from a parts store.
 Old 01-24-2015, 05:56 PM   #25
leka's Avatar
Got it!
Mazdaspeed 6 2006
 Old 01-25-2015, 02:29 PM   #26
leka's Avatar
It worked, if the light in the center console is broke or disconnected, the airbag light will be triggered and will be illuminated
Mazdaspeed 6 2006
 Old 01-25-2015, 02:47 PM   #27
brandon3212's Avatar
Posts: 425   (View Stats)
Usually anything to do with a safety circuit is all wired together. If any 1 part fails the whole system stops working.
07 Speed 3
 Old 10-29-2019, 10:00 AM   #28
markrodriguez0721's Avatar
markrodriguez0721 is an unknown quantity at this point
The bulb Part No. is H450-55-431. It's marked "TOSHIBA A12V 1.7W" on the globe. My dealer had it cheaper than online. They charged me $5.92 USD.
markrodriguez0721 is offline   Reply With Quote
Airbag light help! Mcklveen02 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 04-01-2012 03:03 PM
Airbag Light? amandapanda MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 02-15-2012 04:49 PM
Airbag dash light flasing codes bigserb3 Mazdaspeed3/6 General Discussion 7 01-16-2012 03:59 PM
Another Airbag Light Question seanmiller09 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 08-19-2011 08:37 AM
Airbag light flashes treyclash 2010 MS3 - Car Audio & Electronics 1 12-17-2010 10:58 AM
Page generated in 0.47274 seconds with 30 queries
