 Old 12-08-2009, 04:51 PM   #1
camdensms6's Avatar
Posts: 97   (View Stats)
camdensms6 is a glorious beacon of lightcamdensms6 is a glorious beacon of lightcamdensms6 is a glorious beacon of lightcamdensms6 is a glorious beacon of lightcamdensms6 is a glorious beacon of light
Groaned at 15 Times in 2 Posts
Default Apexi Turbo Timer Install Problem. PLEASE HELP ME!!
Ok so i have just gotten my TT and ive followed the wiring diagram to the T and my TT is still not working. Is there anyone who has installed their own TT on speed 6 because I really need to get this thing working correctly.Also on a side note when i put a ground on the TT it will blink like once or twice and then it will just go off.Its as if the ground is not sufficient BUT i even tried using the negative cable on the battery after i tried every possible ground area avail. Still same issue. PLEASE PLEASE help me i do not want to pay to have such a simple install performed.
camdensms6 is offline   Reply With Quote
 Old 12-08-2009, 05:41 PM   #2
Addikted To Boost's Avatar
Posts: 1,837   (View Stats)
did you follow one of the installs on this forum? Did you test your wires with a multimeter before tapping them?
09 MGM MS3
 Old 12-08-2009, 06:25 PM   #3
camdensms6's Avatar
Yes sir i did . i went to SUF and followed an install there. Turns out on the 6 you have to pretty much have "2" pos hook ups for this TT. Its working great now and all is well thanks again.
How to: Install an Apexi Auto Timer w/ O2 AF on an MS3 theurgy MazdaSpeed 3 - How-To's 33 11-17-2013 02:38 PM
How-To install a turbo timer in a speed3 mazdaspeedjay MazdaSpeed 3 - How-To's 19 04-06-2012 06:09 PM
Apexi Turbo Timer SneakyP86 MazdaSpeed 6 - How-To's 26 10-23-2011 08:19 PM
Page generated in 0.25576 seconds with 21 queries
