 Old 10-16-2019, 04:39 PM   #1
hellis's Avatar
Posts: 3   (View Stats)
hellis is an unknown quantity at this point
Default Blowing engine ig fuse
I blew a engine ig fuse today. Replaced all 4 coil packs, disconnected both O2 sensors, still blows. The weird thing is, if only 4 coils are plugged in, the fuse doesn't blow. Looking at a wiring diagram there's a ignition capacitor. Does anybody know where that's located or ran in to this issue even after replacing coil packs?
hellis is offline   Reply With Quote
 Old 10-16-2019, 09:03 PM   #2
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
It's location is shown in the picture you posted. It's just a small black plastic square with a bolt holding it in place.
 Old 10-17-2019, 08:20 AM   #3
hellis's Avatar
Thanks, but i was looking more for where its located, ie. "A bolt holding it in place" on the block, head, firewall, intake, transmission, or any other metal surface on that side of the engine bay.
 Old 10-17-2019, 12:08 PM   #4
Jeff23spl's Avatar
Posts: 2,233   (View Stats)
it's on the top plate just above the egr. the connector is the same as the EBCS but with just 1 wire.
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 10-18-2019, 04:06 PM   #5
hellis's Avatar
Default FIXED
Fixed it. The issue had nothing to do with the coils. The common ground underneath the air filter was corroded and the ground spot was rusted. going to run a dedicated ground to it. So if anybody's ms6 (and probably any first gen 6) died out and keeps blowing fuses, check the ground point under the air filter (ps. bring a good set of vice grips to get the stupid rubber head bolt out.)
ECM Fuse keeps blowing? Tru3 2010 MS3 - Troubleshoot/Diagnostics 1 08-05-2018 07:58 AM
2013 keeps blowing fuse ltoddiv 2010 MS3 - Troubleshoot/Diagnostics 6 08-17-2017 11:35 AM
Engine IG Fuse keeps blowing dawgincustoms MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 05-15-2017 04:01 PM
Eng Bar fuse keeps blowing after water splashed into engine bay Dawey1 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 03-28-2011 01:19 PM
Need your help! Fuel Injector Fuse keeps blowing flz33 MazdaSpeed 3 - Engine, Transmission & Driveline 7 12-23-2008 09:09 AM
Page generated in 0.26431 seconds with 23 queries
