  • 1 Post By Raider
 Old 01-31-2012, 10:11 AM   #1
Val
Val's Avatar
Posts: 11   (View Stats)
Val will become famous soon enough
Default blown engine...
so here it is, zoom zoom boom. Doing 40km/h in a school zone, big "POW", got to the garage and apparently a connecting rod went through the bottom of the engine block. garage says there was enough and correct amount of oil....
had issues with the car about a month ago. Didnt start, then change battery spark plug so on...
Mazda says I have to provide all the oil change receipts. i bought the car used about a year ago. Car has currently 40k km on it.
My question to you guys : Since I bought the car used from a dealership, i shouldnt have to provide oil changes from the former owner, should I ?????
If so, I'm kinda screwed
VAL- Speed3 08 : Turbosmart BOV / COBB SRI / COBB AP / SURE Anchors / SURE Recirculation hose / COBB TIH / SURE engine mount / remove side molds / eyelids
Val is offline   Reply With Quote
 Old 01-31-2012, 10:13 AM   #2
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
Just in the time you have owned it.
tapatawk
 Old 01-31-2012, 10:14 AM   #3
btstarcher's Avatar
Posts: 4,852   (View Stats)
Return to stock before you take it to dealer. Especially the stock tune.
The Following 2 Users Say Thank You to btstarcher For This Useful Post:
IshiKage (02-01-2012), Raider (01-31-2012)
 Old 01-31-2012, 10:17 AM   #4
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
I was told I'd need oil change receipts from previous owner to validate warranty coverage at Ontario Mazda.
"Exclusivity" - CP-enis
Demodded.
The Seals
Chimmike (01-31-2012), Raider (01-31-2012)
 Old 01-31-2012, 10:21 AM   #5
Val
Val's Avatar
I don't have the stock air filter neither the BPV :S
I'm in Edmonton...
 Old 01-31-2012, 10:27 AM   #6
Tokay444's Avatar
Groans: 793
Good luck.
If you get past the oil change receipt ordeal (Mazda will have record of all oil changes done at any dealer anyway), and the try to say you mods caused the problem, make sure you get them to prove it, and get it in writing, and signed by the service manager and then take it to a real shop for a proper diagnosis. Get their's in writing and slap Mazda in the face with it.
They CANNOT void your warranty for mods that DO NOT cause the issue at hand.
Hopefully you have some sort of monitoring/logging device that could have shown all your vitals to be in check while the car was running.
Demodded.
The Seals
SKiZ0TT (01-31-2012)
 Old 01-31-2012, 11:13 AM   #7
Val
Val's Avatar
So I just noticed that the garage put in 5w20 ...... would that be enough to blow the engine up?
 Old 01-31-2012, 11:16 AM   #8
predapio's Avatar
Posts: 8,939   (View Stats)
Groans: 309
No, not at all.
Hope it works out for you.
What a lovable bunch we are!!
The Following User Says Thank You to predapio For This Useful Post:
 Old 01-31-2012, 11:19 AM   #9
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
No, not at all.
correct and nope. GL OP. Yer gonna need it.
07 MS3
The original Genpoo Hater
 Old 01-31-2012, 11:29 AM   #10
Wrong oil (5-30 per manual). If you donate for VIP access, a guy is selling stock MS6 intake for $10 plus shipping. BPV can be found cheap too. I would sell you mine, but it is on loan for a guy getting warranty work here.
Donate, and here is the guy's FS thread for the intake.
http://www.mazdaspeedforum.org/forum/foru...x-20-a-103161/
Dealers can be dicks and demand proof since ownership. You can go to carfax and see if the PO had the dealer service, it will show (even if dealer says no proof seen).
Stock out before you go in, and since the wrong oil is in there, pray they do not send it for analysis.
 Old 01-31-2012, 11:37 AM   #11
deadlandxtreme's Avatar
Posts: 1,117   (View Stats)
Groans: 82
Welcome to the Mazda engine window club!
Hope you're able to get things worked out. Donate to get the VIP status. Trust me! They will help finding the parts and knowledge of the masses will help with future or current troubles.
 Old 01-31-2012, 09:59 PM   #12
toeknee's Avatar
Posts: 20   (View Stats)
toeknee will become famous soon enough
hi welcome to MSF
when i called the first mazda dealership in calgary they wanted 150 to transfer warranty, i called the second dealership they just transfer it no problem no fee.
i wish you the best of luck getting it fix, but PG is selling a stock one for 5g.
everything is stock for me, i wish i could help and switch out parts for ya.
toeknee is offline   Reply With Quote
The Following User Says Thank You to toeknee For This Useful Post:
Val (02-01-2012)
 Old 01-31-2012, 10:24 PM   #13
MS309's Avatar
Posts: 673   (View Stats)
MS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the world
Which dealership are you dealing with in Town ?
'11 CWP Speed3
More torque than your right arm.
MS309 is offline   Reply With Quote
 Old 02-01-2012, 01:49 AM   #14
Val
Val's Avatar
I'm dealing with Sundance Mazda. They told me that they have to inspect the damage first. the car will get towed there later on today.
I'll update the thread as soon as I can.
 Old 02-01-2012, 02:06 AM   #15
Val
Val's Avatar
GL OP ?
what else would of caused a connecting rod to punch through the engine block?
 Old 02-01-2012, 05:36 AM   #16
tbot's Avatar
Posts: 2,821   (View Stats)
Groans: 40
GL = good luck OP = original poster
And high load under low rpms, aka 6th gear at 40 and foot down.
U said u wear doing 40...what gear were u in and was it when leaving the school zone and u didn't down shift?
Sent from my ADR6425LVW using Tapatalk
The Following User Says Thank You to tbot For This Useful Post:
Val (02-01-2012)
 Old 02-01-2012, 05:42 AM   #17
Groans: 82
OP read this fun little story and hopefully it will be similar:
ZOOM ZOOM BOOM
 Old 02-01-2012, 06:28 AM   #18
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Cause a rod to get thrown thru the block? Hydrolock, locked up bearing, as someone else mentioned, too much load, if it was cyl 3, that one is known to be a little leaner than the other cylinders due to better IM flow thru that runner, could be a number of reasons. Just because you "had enough oil" in there according to the shop doesn't mean anything.
07 MS3
The Following 3 Users Say Thank You to Chimmike For This Useful Post:
deadlandxtreme (02-01-2012), rfinkle2 (02-01-2012), Val (02-01-2012)
 Old 02-01-2012, 08:59 AM   #19
Val
Val's Avatar
3rd gear, constant speed
ZOOM ZOOM BOOM
for some reason I can't access it
Update : the car is on the way to the dealership.... fingers crossed...
 Old 02-01-2012, 09:04 AM   #20
If you took it in modded at all, prepare to be raped by voided warranty over bullshit excuses. Sucks, as for $40, essentially, you could have the stock parts. If voided over the mods, the new motor will be thousands.
Stealth01 (02-01-2012)
 Old 02-01-2012, 09:11 AM   #21
Stealth01's Avatar
Posts: 6,910   (View Stats)
Groans: 201
LOL if you didn't stock out, you're screwed. Your warranty will be denied whether you have oil change receipts or not.
And whatever caused you to blow could have occurred weeks ago. You could have bent a rod with a det event, over-revving, or whatever, and it just blew today. However, the wrong oil probably contributed.
Either way, with all those mods still on the car, you're stuck. Sorry.
Stealth01
2006 Mazdaspeed6 GT
 Old 02-01-2012, 09:22 AM   #22
bigriver's Avatar
Posts: 1,123   (View Stats)
bigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the world
40kmh = 25 mph, in third gear. Did you stomp on it in a school zone? Mind boggling.
2012 mazdaspeed 3, black mica w/ tech package, AFE drop in dry filter, Autotech internals and CS rmm inserts. .
bigriver is offline   Reply With Quote
 Old 02-01-2012, 09:36 AM   #23
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
yea, especially the BPV. they will somehow convince you that you "increased the boost" with it.
get it stock, then get it fixed.
The Following User Says Thank You to socks For This Useful Post:
 Old 02-01-2012, 09:41 AM   #24
JustanotherMS3's Avatar
Posts: 268   (View Stats)
JustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the world
Groaned at 45 Times in 11 Posts
Op I'm in Edmonton too. An if you want I can lend you my stock air box and bpv, I can drop by this weekend and I can help you stock out if you want
Edit. Sorry. Didn't see that your already bringing it there. My offer still stands. So if you want the parts let me know
Currently own:
2012 Sunburst Orange Civic SI Coupe W/Tech package
Basically stock with an Injen SRI (much thanks to madspd6)
wheels will be here in a week or so: 18x9 +25 Fast Hayaku powder coated White (basically TE37 knockoffs)
Previous car... 2011 Velocity Red MS3 W/Tech
-Engine/Power Mods:
FREEK TUNE IN PROGRESS/UR CBE/UR Race Pipe/Injen SRI/COBB AP/AutoTech HPFP Internals/Stage 2 Driver Mod/Turbo Smart Duel Port/JBR SSP/JBR SSB/Razo Weighted Shift Knob/
-Wheels and suspension:
Lowered on H&R Springs
18x8.5 +30 offset XXR 522 in Gold.
JustanotherMS3 is offline   Reply With Quote
The Following 3 Users Say Thank You to JustanotherMS3 For This Useful Post:
Easter Bunny (02-01-2012), Raider (02-01-2012), Val (02-01-2012)
 Old 02-01-2012, 11:22 AM   #25
Val
Val's Avatar
the car went to the dealership with a sri and a bov ... I have all of my oil change paperwork. They asked me to provide proof of oil chandes from the previous owner as well.
thanks a lot @JustanotherMS3 for your offer
the dealership will inspect the car and I'll have somewhat of a diagnostic this afternoon.
as of right now....it is not looking good.... :S
 Old 02-01-2012, 11:24 AM   #26
Too late for stocking now. Pray they do not void ya over the silly intake and BOV we warned you to replaced.
unsubscribing to fail thread.
deadlandxtreme likes this.
 Old 02-01-2012, 11:25 AM   #27
Groans: 82
I had my fully back to stock but they could tell things had been swapped out. The only saving grace I had was that all the OEM parts were there to go back on and the car had been to that dealership for inspection less than 6 months ago. So in the end, they had little proof to argue otherwise. They event went so far as to send detailed pics to Mazda for approval. Good luck man, you will need it for sure.
 Old 02-01-2012, 12:29 PM   #28
socks's Avatar
Groans: 125
i think playing dumb was your saving grace matt
 Old 02-01-2012, 12:32 PM   #29
Groans: 82
^ +1 for that!
 Old 02-03-2012, 08:29 AM   #30
Val
Val's Avatar
So I'm getting a new engine !!
The Following User Says Thank You to Val For This Useful Post:
Tokay444 (02-03-2012)
 Old 02-03-2012, 08:31 AM   #31
Groans: 82
Welcome to the club.
 Old 02-03-2012, 08:46 AM   #32
btstarcher's Avatar
Sweet! Lucky bastard...
 Old 02-03-2012, 08:56 AM   #33
jeopardy98's Avatar
Posts: 1,920   (View Stats)
jeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the world
Something is fishy...
Bone Stock 2012 BM Non-Tech for 2500 miles. (250 whp/265 wtq Moore Auto). Currently: K04/Cobb AP/AT internals/Magnaflow CBE/M2 DP/Cobb SRI/HTP TIP/CS boost tubes/CS recirc hose/TS BPV/SU TMIC/GS EBCS/JBR EGR delete/Coolant bypass/Thermal TB gasket/NGK 6510's/JBR SSP/JBR Knob/JBR 88 RMM/JBR SSB/DDM 35w 5000k HIDs/PAC Gateway iPod integration and Sirius. (301whp/360wtq Moore Auto). Finklefied Hypnotic tune. 14.1@106 Mason Dixon- Driver mod needed.
jeopardy98 is offline   Reply With Quote
Blown engine stupidslow_ms3 Mazdaspeed3/6 General Discussion 53 05-06-2011 07:40 PM
another blown engine b-ron MazdaSpeed 6 - Engine, Transmission & Driveline 28 12-16-2008 08:29 AM
Page generated in 0.49307 seconds with 35 queries
