  • 1 Post By Blackspeed
 Old 07-23-2011, 11:43 PM   #1
psmith22's Avatar
Posts: 30   (View Stats)
psmith22 is on a distinguished road
Default Boost creep?
I've had my AP for about a week now and running a stage 1+ map right now (also have a COBB cat back and a sri) and I've been noticing that if I get on it I can hit 20 pounds but tonight it showed 21 pounds on the AP. Now even though its been the first cool night since I've had the AP and maybe thats why it ran better my friend brought up that it might be boost creep and I will need a boost regulator. So before I go out buying regulators and controllers I just want to make sure that I really need them. So are there any tests I can run to make sure? Hopefully it was just a good night and not anything wrong.
Thanks for any help
psmith22 is offline   Reply With Quote
 Old 07-23-2011, 11:44 PM   #2
DONOTBUGME's Avatar
Posts: 2,631   (View Stats)
Groans: 266
Logs and list of mods can help. Usually you can tune it out with the atr
DONOTBUGME is offline   Reply With Quote
The Following User Says Thank You to DONOTBUGME For This Useful Post:
AZSPEED3 (07-24-2011)
 Old 07-23-2011, 11:50 PM   #3
psmith22's Avatar
I'm planning on putting on a down pipe in the next week and I'll be getting a professional tune after that so will that clear any problems as well?
 Old 07-24-2011, 11:50 AM   #4
I gotthatzumzum's Avatar
Posts: 552   (View Stats)
I gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the world
Hopefully the tuner knows what he's doing and see's if there is any issues like that... But exactly what donot said... pull some logs and post them here, but until then we can't tell you really whats going on with what little info your giving us.
i wish more than like 2 colors didnt look stupid on my fucking brightest red ever car
I gotthatzumzum is offline   Reply With Quote
 Old 07-24-2011, 12:11 PM   #5
KR....i haz it
Blackspeed's Avatar
Posts: 2,845   (View Stats)
Blackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the world
Groans: 166
Im willing to bet that you are seeing boost spikes and not boost creep.
Boost creep is when the wastegate cannot bleed enough boost which causes the pressure to rise. Bost spike are when you initially mash the gas, the boost comes on too fast for the ecu to correct right away.
Im assuming you have the stock turbo in which case it has no problems with boost creep
Cobb SRI | Cobb Turbo Inlet | Cobb AP |ETS TMIC 3.25" | CS Inserts |
CS Test Pipe | NGK IV22 | Blitz TT | MSD DH | TWM full replacement | PTP cdfp
While the other forum is GREAT for technical/mechanical information and how to, that place is filled with single-minded (if you aren't driving fast, you're doing it wrong), arrogant, and professional douchebags.
Blackspeed is offline   Reply With Quote
The Following User Says Thank You to Blackspeed For This Useful Post:
rfinkle2 (07-24-2011)
 Old 07-24-2011, 12:18 PM   #6
zpele's Avatar
Posts: 1,654   (View Stats)
zpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the world
Groans: 354
Groaned at 213 Times in 109 Posts
Like was already said, a 'professional tuner' could be shit. Just make sure you do your research before you pay an arm and a leg for something that you can learn to do yourself.
2012 Shelby GT500 - Roush Axleback ~ JLT Oil Separator ~ JLT 123mm intake ~ Ngauge ~ Lund Tuned ~ smaller pulley ~ xpipe (loud as fuck now)
2007 Mazdaspeed6 (SOLD) - COBB SRI ~ Gutted Stock Midpipe ~ HKS BPV ~ JBR RMM ~ AWR PMM ~ AWR TMM ~ Juggernaught Rear Diff Mount ~ Dreadnaught Rear Diff Mount ~ ACT Stage 2 Clutch ~ ITV22s ~ AP(self fucking tuned in a week fuckers) ~ Autotech Internals ~ eBay Downpipe ~ Poke Sub thingy
zpele is offline   Reply With Quote
 Old 07-24-2011, 12:22 PM   #7
What Blackspeed says is most likely your case.
If you are logging anything more than 0 (yes zero) wgdc, you are fine, and need to just get the tuner to cure a boost spike.
 Old 07-24-2011, 01:37 PM   #8
psmith22's Avatar
Alright thanks for the help. I'll log some tonight and post it up if it happens again.
 Old 07-24-2011, 11:47 PM   #9
psmith22's Avatar
I'm pretty sure Blackspeed was right with the boost spike because I threw a light today and the code was a communication code so I figured the ecu just can't keep up. Thanks for all the help
Boost Creep? Silver Ecstasy MazdaSpeed 3 - Engine, Transmission & Driveline 17 02-14-2012 04:28 PM
Boost creep? DubVms3 MazdaSpeed 3/6 - Turbo Induction 4 03-11-2011 04:12 AM
Boost Creep RocketScientist MazdaSpeed 3/6 - Turbo Induction 3 08-02-2010 11:13 AM
GT35R, 17psi, internal, no creep, SB ftmfw Laloosh MazdaSpeed 3/6 - ECU Computer Tuning 75 11-07-2008 04:32 PM
Boost creep with ATP turbos dadasracecar MazdaSpeed 3/6 - Turbo Induction 34 08-08-2008 04:19 PM
Page generated in 0.28957 seconds with 25 queries
