  • 1 Post By Vansquish
  • 1 Post By SaveMelMac
 Old 11-20-2019, 10:01 AM   #1
Witness's Avatar
Posts: 39   (View Stats)
Witness is a jewel in the roughWitness is a jewel in the roughWitness is a jewel in the roughWitness is a jewel in the rough
Default Boosting 17 pounds at idle - HELP
Hey guys/gals
I've been lurking on this forum for a year now and you guys have helped me a lot with my 2007 speed3. Now I have a problem that I could not find the answer to anywhere.
At idle, my AP is displaying 17 pounds, and if i lightly tap the throt it goes to 22 pounds
Do I have a bad ebcs? is the wastegate stuck closed? what could be causing this?
Mods:
Stock Turbo (previously a GTX3071r)
Wiseco Pistons
Manley H-Beam connecting rods
Autotech high pressure fuel pump internals
ARP cap bolts
ARP main studs
Balance shaft delete kit
Corksport 3.5 BAR MAP sensor
JBR EGR delete kit
COBB front mount intercooler
COBB rear motormount
COBB electronic boost controller
COBB access port V3
COBB blow off valve
Catless downpipe
thanks!
Witness is offline   Reply With Quote
 Old 11-20-2019, 10:31 AM   #2
SaveMelMac's Avatar
Posts: 485   (View Stats)
I would verify the reading with some type of mechanical boost gauge first.
The Following 2 Users Say Thank You to SaveMelMac For This Useful Post:
55suarod (11-26-2019), Witness (11-20-2019)
 Old 11-20-2019, 10:36 AM   #3
Police - Grammarhead
Vansquish's Avatar
I would make sure that the units on the AP are displaying correctly, and if so, I would reflash the tune and see if the same symptoms persist. Logically speaking, you can't be at 17psi of boost at idle.
 Old 11-20-2019, 10:45 AM   #4
Witness's Avatar
The car accelerates faster then it normally would, and at the very beginning of boost, i hit boost or fuel cut immediately
 Old 11-20-2019, 10:53 AM   #5
Witness's Avatar
The units for sure are PSI, I've tried a retune. Maybe ill try a third retune today and see if it wants to cooperate
 Old 11-20-2019, 10:58 AM   #6
Vansquish's Avatar
Why don't you take a datalog at idle, a datalog under acceleration, and post both? That should help us troubleshoot what's going on.
 Old 11-20-2019, 11:38 AM   #7
Vansquish's Avatar
@Witness;, OK. I've got a couple of questions about your hard parts.
You wrote that you used to have a GTX3071r and that you've got a CS 3.5 Bar MAP sensor. If you haven't swapped the 3.5Bar sensor out for a stock (2.5Bar) sensor, but you are using a tune designed for a stock turbo vehicle with a stock sensor, your MAP sensor will not read properly. You have to have the appropriate MAP scalars set in ATR for stock sensors (2.5 Bar), or for aftermarket sensors like yours.
So my questions are:
What tune are you running? Please be precise (i.e. don't just say "stage 1").
Are you trying to run a stock turbo tune with a 3.5 Bar map sensor?
Jeff23spl likes this.
 Old 11-20-2019, 12:53 PM   #8
Witness's Avatar
I do have a 3.5 bar map sensor, and I'm running the COBB OTS stage 3 93 v250 tune
I attached a log at idle
 Old 11-20-2019, 01:04 PM   #9
Vansquish's Avatar
Originally Posted by Witness View Post
I do have a 3.5 bar map sensor, and I'm running the COBB OTS stage 3 tune
Well, that's your problem.
You cannot use an OTS map with an aftermarket MAP sensor. You have to modify the MAP scalar in order to safely run the 3.5 bar map sensor with the rest of the OTS stage 3 tune. The OTS tunes are only set up to use OEM MAP sensors which are 2.5 bar instead of 3.5 bar.
Using a 3.5 bar map sensor on an OTS tune will result in precisely the behavior you are experiencing. You will have uncontrolled boost, boost cut at inappropriate times, and false boost readings at idle (and everywhere else in the rev range).
You need a custom tune.
The Following 3 Users Say Thank You to Vansquish For This Useful Post:
C-love (12-03-2019), cyclist20 (11-21-2019), MSMS3 (11-21-2019)
 Old 11-20-2019, 01:15 PM   #10
Witness's Avatar
sweet, that helps me out a lot. Whats weird is that the car was running okay, and yesterday out of nowhere, i started hitting boost cut and looked at the AP and saw the numbers. Could it be that the MAP sensor is not the only reason or this? If it were shouldn't the car have been like this since the day i put the stock turbo back on?
 Old 11-20-2019, 01:18 PM   #11
Vansquish's Avatar
@Witness;, I don't know what else to tell you. Unless you were driving it differently before, I can't explain why the behavior would've just appeared seemingly out of the blue. The MAP sensor cannot read properly on the OTS tune, so that would never have changed.
If you have ATR and can modify your maps, you can set the appropriate scalar yourself. The information on what to do is on the site somewhere. If not, you can find it on CS's site.
Edit: I looked, and it appears that the scalars are:
A: 210
B: 0.35
OS: 4.26
 Old 11-20-2019, 01:52 PM   #12
Witness's Avatar
A: 210
B: 0.35
OS: 4.26
So if I install a OEM 2.5 bar MAP sensor and run it on the stage 3 tune, it should be okay?
 Old 11-20-2019, 04:05 PM   #13
ANS
ANS's Avatar
Posts: 4   (View Stats)
ANS will become famous soon enough
Yes, it should be ok !
ANS is offline   Reply With Quote
 Old 11-21-2019, 07:30 AM   #14
Jeff23spl's Avatar
Posts: 2,237   (View Stats)
the changes could be related to colder temp. You were driving wrong beffore but maybe not enought to hit overboost level and now with more air density you reach it and start looking at why this happen...
As explain, ots are for oem map sensor but also for oem turbo and just give average results....you are always better with proper tune to your exact mods and engine wear..
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
MSMS3 (11-21-2019)
 Old 11-21-2019, 08:13 AM   #15
Witness's Avatar
Does anyone know what brand OEM MAP sensor i should get? I see a duralast brand that goes for $200 so i want to make sure its the right one. I see cheaper ones as well but they dont say what pressure they operate at.
 Old 11-21-2019, 08:27 AM   #16
tegxsi's Avatar
Posts: 1,281   (View Stats)
Groans: 87
Stock are all 2.5bar... if it's compatible with OEM then it should be fine.
I think $200 is way too much.
2018 Audi RS3
2007 Acura TSX 6MT
 Old 11-21-2019, 08:32 AM   #17
Witness's Avatar
Do you have a website i can use to order? On the autozone website it shows map sensors that are compatible but operate at 1 bar
 Old 11-21-2019, 10:32 AM   #18
SaveMelMac's Avatar
Just go on rock auto and look up your car. All the map sensors listed will be the 2.5 bar stock sensor. Or go to any parts store and ask for a map sensor. Don’t even bring up asking what bar it is they are all going to list the stock 2.5 bar
The Following User Says Thank You to SaveMelMac For This Useful Post:
Witness (11-21-2019)
 Old 11-21-2019, 10:45 AM   #19
SaveMelMac's Avatar
Or put the money towards a custom tune and you can keep your current map sensor
Vansquish (11-21-2019), Witness (11-21-2019)
 Old 12-03-2019, 07:25 AM   #20
Witness's Avatar
for anyone that comes in here with the same problem, it was the MAP sensor. Thanks everyone
The Following User Says Thank You to Witness For This Useful Post:
MSMS3 (12-03-2019)
My 2008 Speed 3 will not hold an idle and rides rough at low rpm and low idle Dgms3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 17 11-23-2016 03:42 PM
idle and over boosting help h3lp clark kent MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 07-29-2014 06:13 AM
Over boosting? travis9935 MazdaSpeed 3/6 - Turbo Induction 55 01-02-2012 12:35 PM
only boosting 10 psi triple_threat MazdaSpeed 3 - Engine, Transmission & Driveline 11 08-11-2009 09:08 AM
Page generated in 0.43403 seconds with 26 queries
