 Old 01-13-2020, 10:10 PM   #1
LBC_Shadow's Avatar
Posts: 7   (View Stats)
LBC_Shadow will become famous soon enough
Default Broken Vaccum Line
I broke the vacuum like from my turbo inlet to my engine or where ever that small vacuum line goes on the back side near the turbo and i was wondering if that part is something i buy or do i buy vacuum line and cut a new one at the same length...?
LBC_Shadow is offline   Reply With Quote
 Old 01-14-2020, 07:40 AM   #2
Police - Grammarhead
Vansquish's Avatar
That line goes to your EBCS. You're probably going to break the nipple on the EBCS when you try and connect a new line to it, so be super careful. The plastic nipple is shitty and brittle. You can just buy vacuum line and cut it to length though.
 Old 01-15-2020, 06:09 PM   #3
LBC_Shadow's Avatar
So i have replaced this and the issue is still present. Anyone in Sacramento, CA that can help me check for a boost leak?
 Old 01-15-2020, 07:10 PM   #4
Vansquish's Avatar
What issue are you trying to solve? All you said is that you have a busted vacuum line.
 Old 01-15-2020, 08:23 PM   #5
LBC_Shadow's Avatar
Sorry must have been a different thread.
When my car is on more than half throttle it will even out whatever RPM it is at and start to buck, almost like its hitting the fuel cut-off. This happens in 1st at 5k happens in 3rd at 2k, gear and RPM do not matter. Originally I thought it was this boost line but that was not the case. No engine codes are thrown. Was running stage0-1-2 all have same issue with 2 being the least bad of the 3. New spark plugs and ignition coils gapped to .028. I am out of Ideas after my O2 sensor tomorrow so throw those suggestions into the ring!
 Old 01-16-2020, 06:14 AM   #6
Jeff23spl's Avatar
Posts: 2,233   (View Stats)
what is your boost level ? are you boosting above boost cut setpoint because the vaccuum line is'nt sending air to wastegate ? if it would be the vaccuum on the other side of your EBCS, it would overboost. Or is your turbo pill hole blocked and there is no air coming from there to fill the wastegate to open ?
you need to list your mods and a best is a datalog
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
Vansquish (01-16-2020)
 Old 01-16-2020, 06:41 AM   #7
Vansquish's Avatar
Yeah, what he said. ^^^
Post datalogs of your problem. Make sure you include:
Accelerator Pedal Position
Actual AFR
Boost (psi)
Boost Air Temp
Calculated Load
Coolant Temp
HPFP Actual Pressure
Inj. Duty Cycle
Intake Temp
Intake Valve Adv.
Knock Retard
Long Term Fuel Trims (LTFT)
MAF Voltage
MAF Airflow
RPM
Short Term Fuel Trim (STFT)
Spark Advance
Throttle Position (not throttle duty cycle)
Vehicle Speed
Wastegate Duty
Vaccum recomendations? MS6FL Car Detailing 21 12-18-2011 06:37 PM
Broken clutch line repair AequitasVeritas Mazdaspeed3/6 General Discussion 4 09-11-2011 01:24 AM
vaccum at idle? v277480 2010 MS3 - Engine, Transmission & Driveline 18 03-12-2011 03:19 PM
ap vaccum triple_threat MazdaSpeed 3/6 - ECU Computer Tuning 2 01-13-2010 09:49 PM
Broken fuel line clip vbt101 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 10 01-05-2010 12:19 AM
Page generated in 0.27033 seconds with 22 queries
