 Old 05-14-2018, 06:56 PM   #1
JDL360's Avatar
Posts: 19   (View Stats)
JDL360 will become famous soon enough
Default Burnt ECM
Wassup guys so my speed6 died on the highway yesterday. Blew the 15 amp engine ignition fuse. Found voltage at coil #2 signal wire and traced it back to a burnt computer. Question is has anyone rewritten the VIN to a used computer and Ware you able to un mary your access port it keeps saying to connect to the car.
CorkSport SRI & TIH, CorkSport high pressure internals, ETS TMIC
JDL360 is offline   Reply With Quote
 Old 05-14-2018, 07:52 PM   #2
andale927's Avatar
Posts: 193   (View Stats)
andale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant future
You should contact Cobb and explain the situation.
2013 Mazdaspeed 3 w/ Tech - Purchased Jan 2017
Power:
BNR S4 v2 Turbocharger | JBR 3.5" Aluminum Intake | JBR Battery Box | GFB Respons BPV |Depo Racing Catless Downpipe | Bosch 3 BAR MAP | JBR 3 Port EBC | Treadstone TR8 Kit w/ Piping | Autotech HPFP Internals | Ultimate Racing Catback | Cobb Accessport V3 | Devils Own Meth Kit (D05) | Custom Tru-Cool Oil Cooler | FREEKTUNED E30 Mix+Meth
Handling:
KW V3 Coilovers | CS Camber Plates | SPC Rear Camber Arms | Michelin Pilot Sport 4S 235/40/18 | Full Damond Motor Mounts | JBR Weighted Shift Knob | JBR Shift Bushings | JBR Rear Sway Bar | Damond Short Shift Plate
Other:
Cobb Polyurethane Exhaust Hangers | Speedline Hood Struts | Corksport CF Hood Scoop | Damond OCC Stage 1 | Corksport E-Brake | Corksport Steering Wheel | Avid.1 AV-20 Wheels 18x8 +35
andale927 is offline   Reply With Quote
Burnt oil smell gmpetrov MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 05-27-2017 07:35 AM
another burnt valve thebestdj07 Mazdaspeed3/6 General Discussion 11 10-19-2014 05:56 PM
Burnt Clutch? jeffreyj MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 10-19-2012 08:44 PM
Burnt my seat Snotrocket Interior 38 04-04-2011 06:50 AM
Oil smells burnt? SRTie4k MazdaSpeed 3 - Engine, Transmission & Driveline 13 11-16-2009 08:17 AM
Page generated in 0.23637 seconds with 22 queries
