  • 1 Post By littleloogy
 Old 03-02-2014, 05:21 PM   #1
MS3SHAY's Avatar
Posts: 2   (View Stats)
MS3SHAY is an unknown quantity at this point
Default Can not reach target boost
since installing the cs stage 2 sri and tih I have been unable to reach the target boost of 16.5psi..i have checked and double checked all clamps and connections and went as far as replacing the boost control solenoid thinking I may have damaged in some way during install. I have the proper map flashed for what I have and even double checked with cobb to be sure it was the proper map and there tech support was less than helpful all they had to say was that the was something mechanically wrong with the car but I find that hard to believe seeing as I was reaching boost levels before the install and reflash. I have attached a datalog of a third gear pull with a shift and short run in fourth.. please any input or ideas will be appriciated
MS3SHAY is offline   Reply With Quote
 Old 03-02-2014, 05:34 PM   #2
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
sounds like you're on a load based tune perhaps.
07 MS3
The original Genpoo Hater
 Old 03-02-2014, 06:00 PM   #3
littleloogy's Avatar
Posts: 4,005   (View Stats)
The tune says +/-2psi with 16.5psi being the target. If you are within 2 psi... Then you may not have a problem.
Sent while cleaning my spill valve again...
memin likes this.
 Old 03-02-2014, 06:15 PM   #4
MS3SHAY's Avatar
Tune state +/- 1.5 psi which I'm assuming is for variances in altitude or actuator wear and I'm hitting 14.7-15.1 depending, which is close but it still has me confused as I was hitting 16.5 consistently until the install and new flash.. Anyone know what changes I could make to the tune to raise the boost target so I can make the 16.5psi ? I have accesstuner race and some tuning knowledge(aem) just not familiar with this platform and software
Report: Toyota Prius line may not reach 2013 sales target Haltech Automotive News 0 04-22-2013 12:30 PM
Not hitting target boost btrend MazdaSpeed 3/6 - Troubleshoot/Diagnostics 34 04-14-2013 09:28 PM
BMW says it will reach 2 million car sales target ahead of forecast Haltech Automotive News 0 03-13-2012 06:50 AM
stage2 boost target myslow1 2010 MS3 - ECU Computer Tuning 6 12-12-2011 03:16 PM
Can't Reach Boost Target Above 5200 rpm RichieRichness MazdaSpeed 3/6 - ECU Computer Tuning 31 05-15-2011 02:17 PM
Page generated in 0.25614 seconds with 23 queries
