 Old 09-07-2011, 11:23 AM   #1
Mikey's Avatar
Posts: 2,049   (View Stats)
Mikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the world
Groans: 104
Groaned at 45 Times in 36 Posts
Default Car will not start
installed my internals and everything went smoothly drove it around all good no issues. Next morning the car would not turn over. The lights would come on likes its all good then nothing. I sent the AP and ECU to COBB uninstalled the AP sent it back and still nothing. (ECU was not reading the AP) COBB said AP and ECU are good. Check all my fuses in the engine bay and in the car. I am about to take my battery to get it check just in case.
Any ideas would be greatly appreciated. All she does is turn the lights on. The car does not even try to turn over.
2007 Cosmic Blue
Built HTA 3076 Corn Fed with shot of Meth and Freektuned
Mikey is offline   Reply With Quote
 Old 09-07-2011, 11:25 AM   #2
Checked the clutch pedal sensor dealio? How old is your battery, do the lights dim when starting?
 Old 09-07-2011, 11:28 AM   #3
Mikey's Avatar
Groans: 104
not that i noticed. What am i looking for when checking the clutch sensor? never fucked with that.
2007 Cosmic Blue
 Old 09-07-2011, 11:51 AM   #4
Not exactly sure. I think there is a connector, as well as a relay involved. Some friends have bypassed it for remote starters though.
Did some searching
http://www.mazdaspeedforum.org/forum/foru...ect-140-3i.gif
http://www.mazdaspeedforum.org/forum/foru...eed-3-a-68088/
 Old 09-07-2011, 03:26 PM   #5
Mikey's Avatar
Groans: 104
well for some reason she decided to start but now the car is smoking by spark plugs.. FML
2007 Cosmic Blue
 Old 09-07-2011, 08:05 PM   #6
Mikey's Avatar
Groans: 104
found the issue. It was one of the ignition coils. Its fried to shit. Freaked me out due to the smoke. Didn't think those things would smoke like that and fuck they are not cheap. $125 a piece,
2007 Cosmic Blue
 Old 09-07-2011, 09:19 PM   #7
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
shit! sounds epic, but at least it was a relatively easy fix.
smoke would have freaked me out too.
 Old 09-08-2011, 04:17 AM   #8
kmac's Avatar
Posts: 1,792   (View Stats)
coils don't normally melt them selves down. It's normally affiliated to to a short to ground or a stuck coil driver in the pcm. The reason they normally smoke is because they are not cycling and just running max output and overheating.
The Following User Says Thank You to kmac For This Useful Post:
Raider (09-08-2011)
 Old 09-08-2011, 04:54 AM   #9
Coils also don't prevent it from turning over, either. Smoking coils might be a symptom of a larger problem.
kmac (09-08-2011)
Car Won't Start boost2dms6 Mazdaspeed3/6 General Discussion 62 08-30-2011 07:07 PM
Car won't Start funka09 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 06-30-2011 12:17 PM
Car won't start Mrpheer MazdaSpeed 3/6 - Troubleshoot/Diagnostics 29 06-05-2011 10:35 PM
Where to start? booya620
Cobb ATR Support
17 04-02-2010 08:37 AM
Gen MS3 Won't Start Now...! 3Sleeper 2010 MS3 - Engine, Transmission & Driveline 10 02-19-2010 01:31 PM
Page generated in 0.28968 seconds with 23 queries
