| MazdaSpeed 3/6 - Troubleshoot/Diagnostics MazdaSpeed 3/6 - Troubleshoot/Diagnostics - Have a problem with the car? CEL Code? Want to discuss other issues? Come on in! |
![]() Join Date: Nov 2014
Rep Power: 0 ![]() Thanks: 1
(Thread Starter) | Not Ranked : 0 score Sent from my iPhone using Tapatalk |
![]() Join Date: Nov 2010 Location: Annapolis, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,335
Groans: 45
| Neutral : +1 score First of all, don't let those fucks take your HPFP. Sounds like you may have a faulty ground wire. |
| The Following 7 Users Say Thank You to Vader For This Useful Post: | chaser27 (08-27-2015), Code Monkey (08-27-2015), cyclist20 (08-27-2015), daafisch (08-27-2015), littleloogy (08-27-2015), MS3Shadow (08-27-2015), snailD (08-27-2015) |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 492
Groaned at 20 Times in 11 Posts
| Not Ranked : 0 score jump starts fine? probably just starter |
| Not Ranked : 0 score Tap starter wires with hammer, it will start up. Common. |
| The Following User Says Thank You to Raider For This Useful Post: | snailD (08-27-2015) |
![]() Join Date: Aug 2012 Location: Ripon, CA
Rep Power: 2958 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,390
| Not Ranked : 0 score stealership just wants to steal that bad ass CPE pump from your car. Fuck those guys, Sent from my iPhone 6 |
(Thread Starter) | Not Ranked : 0 score Does not jump start. Sent from my iPhone using Tapatalk It starter goes, but does not turn on. Sent from my iPhone using Tapatalk Last edited by GR4YF0X; 08-27-2015 at 11:23 AM. Reason: MSF Database - Automerged Doublepost |
| Not Ranked : 0 score What is the PSI Key On Engine Off? (using an AP) |
Ground wire looks fine and I used a terminal brush to make sure contacts were good. Sent from my iPhone using Tapatalk I don't have an accessport. Anything else I can use to read that? Sent from my iPhone using Tapatalk Last edited by GR4YF0X; 08-27-2015 at 11:26 AM. Reason: MSF Database - Automerged Doublepost | |
![]() Join Date: Jul 2013 Location: Westchester, IL
Rep Power: 4924 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,635
| Not Ranked : 0 score OBDII Bluetooth adapter and the Torque app on a phone or tablet.
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP |
| Not Ranked : 0 score Doubt CPE FP and starter went out at the same time. You have: 1) slow to turn over then start 2) no turn over 3) turns over and starts 4) turns over and does not start Sounds like the little ground wire on the hpfp deal is loose, or ground is corroded up and bad overall. |
| The Following User Says Thank You to Raider For This Useful Post: | Vader (08-27-2015) |
![]() Join Date: Oct 2011 Location: Tijeras, NM
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score Check the whole length of wire to the starter. Sometimes the wire can corrode inside the insulation and the starter will check fine but the wire will not carry enough current to fully engage the solenoid and starter. However, the "no sounds" is indicative of no current to the solenoid. You should at least hear some clicking of the solenoid. Get it away from the dealer.
__________________ Silver 2012 MS3 , 2007 Corvette Z06 , 2008 Hayabusa MS3 Mods Sure PMM, DMM, REM (all TORQ S3 Street in Stealth Black), Sure Sway Bar, JBR Sort Shifter Cobb - AP V3 SRI, TIH, 3-port Boost Controller, SS 3” DP Corksport TMIC CP-E full HPFP with warranty All Freektuned with two tunes, one for 15psi and another at 20psi |
| Not Ranked : 0 score It is super common for the connectors to have corrosion. The fix, as I first posted, was to tap em. |
| The Following User Says Thank You to Raider For This Useful Post: | kritz (08-27-2015) |
![]() Join Date: Apr 2009 Location: Danbury, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,851
Groans: 58
| Not Ranked : 0 score Check the ground that connects to the HPFP, that little wire fucks with a lot of people. While you're at it check the other chassis grounds too. |
| The Following User Says Thank You to daafisch For This Useful Post: | Raider (08-27-2015) |
Groans: 45
There is one on the HPFP. A weird little sense one, on the starter itself. And a few others I can't remember. Your issue, is almost assuredly a faulty connection of some kind. All the info you have provided, points to a faulty connection.
__________________ Last edited by Vader; 08-27-2015 at 12:13 PM. | |
| The Following User Says Thank You to Vader For This Useful Post: | Raider (08-27-2015) |
![]() Join Date: Nov 2010 Location: Lido Beach,NY
Rep Power: 8624 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,845
Groans: 95
| Not Ranked : 0 score Double tap. Get some electrical contact cleaner spray as well, but best practice is to replace the connectors and or wire.
__________________ Nator is what it does. |
| The Following User Says Thank You to kritz For This Useful Post: | Raider (08-27-2015) |
| Starter problem? | mrjoshyman | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 7 | 03-27-2015 08:15 PM |
| GM gets 75 more ignition-switch claims; 4 more death claims approved | Haltech | Automotive News | 0 | 02-19-2015 03:00 PM |
| Starter issues | plak424 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 2 | 02-25-2013 06:40 PM |
| Installed HPFP and now car won't start | buckeyepost | Mazdaspeed3/6 General Discussion | 19 | 08-31-2011 07:53 AM |
| Auto Starter? | Birdie | MazdaSpeed 3 - Engine, Transmission & Driveline | 2 | 06-07-2010 10:37 AM |
