 Old 02-12-2020, 12:55 PM   #1
Barra's Avatar
Posts: 3   (View Stats)
Barra will become famous soon enough
Default Cranks, doesn't start after carpet removal
I'm not sure what I did here. A few weeks back I had a insulated mug roll off the front passenger seat, popped open , and emptied an entire coffee on the passenger carpet. After a week of smelling like rotten milk I pulled up the carpet to find it has flowed all the way to the back and soak into the thick underfoam of the carpet. I pulled the seats, center console, and the entire carpet out to clean them off and wiped down the entire floor pan both driver and passenger side. I was realized halfway through wiping it down that the battery was still connected but I was only spraying 409 on the floor pans and didn't spray any electrical connectors.
I let everything dry out for 4 days then reinstalled everything. The car powers on fine, all dash electronics work fine. Car turns over but does not start. Fuel pump fuse is intact. CEL after a few seconds of powering on blinks, so it seems like a misfire and I can smell fuel at the tailpipe. I'm at a loss however as to anything I could have done under the carpet that would cause the car not to fire. Any ideas?
Barra is offline   Reply With Quote
 Old 02-12-2020, 05:28 PM   #2
Police - Grammarhead
Vansquish's Avatar
Have you pulled codes? That might be helpful.
 Old 02-13-2020, 02:32 AM   #3
Barra's Avatar
Not yet. Won't have access to a scan tool until this weekend.
The Following User Says Thank You to Barra For This Useful Post:
MSMS3 (02-13-2020)
 Old 02-13-2020, 08:30 AM   #4
Jeff23spl's Avatar
Posts: 2,233   (View Stats)
there isn't much pass the dash related to engine, especially for a 3 with the ecu in the engine bay...Somes connectors in the kick panels but not much
Do you have any sort of remote starter or safety installed, i would try to look there first.
You should check for sparks, maybe you got another problem that just appear at the same time. turn up 4 coils with plugs installed with a grounding strap and check for spark while cranking.
you can take a look at the tiny ground above the hpfp too....
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 02-13-2020, 01:51 PM   #5
MSMS3's Avatar
Posts: 2,825   (View Stats)
Dumb question, but did you rinse out the 409 with enough water that it could have gotten to any of the wiring harness up under the dash, or the OBD2 plug just above the driver’s knee?
Might need to let it dry out more.
A code scan would be really helpful.
 Old 02-25-2020, 08:12 PM   #6
wingcmdr's Avatar
Posts: 16   (View Stats)
wingcmdr has a little shameless behaviour in the past
Do these cars have a fuel cutoff in the cabin like the late 90's explorers do? If so make sure you didn't bump it and trip it while cleaning. I know on the explorers its on the passenger side against the firewall under the dash/glovebox
wingcmdr is offline   Reply With Quote
 Old 02-25-2020, 10:37 PM   #7
Anaphra's Avatar
Location: Chico CA for school. Originally From the Bay Area
Posts: 34   (View Stats)
Anaphra will become famous soon enough
The 5.0 explorer's? Those are pretty cool NGL
2009 CWP GT MS3
Damond Motorsports RMM PMM and TMM
Autotech HPFP
Cobb SF Intake
Cobb AP
Autotech HPFP
Corksport RSB+FSB
Corksport Adjustable Short Throw
Corksport Metal Skid Plate
Koni FSD
Anaphra is offline   Reply With Quote
 Old Yesterday, 01:41 AM   #8
Barra's Avatar
Sorry for the late update. I pulled codes but it didn't list any. It did have a number of faults on many sensor pre-checks including O2 sensor, EGR, and a couple others.
I ended up charging the battery back up (was at 11.95v) and that seemed to fix it. It struggled to start but eventually fired up. I still am not sure what happened. It was getting fuel and turning over. Maybe the voltage was just poor enough that it cranked but didn't spark? I have NO idea why that would ever happen.
It's been almost a week and it's been running fine.
 Old Yesterday, 05:41 AM   #9
wingcmdr's Avatar
Yep! My daily, until the MS6 is back up, is my 97 Mountianeer (5.0 AWD)
« KR super high | - »
Ms6 cranks but no start eroler1 Mazdaspeed3/6 General Discussion 2 11-08-2018 11:50 AM
07 Mazdaspeed 6-cranks but doesn't start Ctown2Ctown MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 11-11-2017 03:24 PM
MS6 Cranks but won't start HELP!!! KingJames MazdaSpeed 6 - Engine, Transmission & Driveline 16 03-23-2015 06:38 AM
Car cranks, won't start 15driley15 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 04-23-2014 04:51 PM
Car cranks but doesn't start after valve clean InfamousSpeed6 Mazdaspeed3/6 General Discussion 11 11-29-2012 06:17 PM
Page generated in 0.27331 seconds with 25 queries
